Just after a bit of advice. You will have to bear with me in the sketchy details as in only going on what I've been told by the previous owner.
Basically I bought a fiesta xr2i just before Xmas. It's the 1.8 early Zetec/efi engine model. Apparently the head gasket went on the previous owner, he and a mate removed the engine and stripped the head off. The head was sent away to an engine specialist who did a full rebuild on it. The head was returned and re-fitted by previous owner and mate. Engine was cleaned up and put back in but never ran again. Before I bought it I was told the engine wouldn't even turn over.
I got it recovered home and charged the battery. The engine does Infact turn over but very slowly. Anyway left it a few weeks over Xmas then had another look at it today, first thing first we tried tow starting it as it needed to be moved from my mums house to mine round the corner anyway. Engine turned over freely on tow in gear but didn't fire, may have been down to the fact the battery didn't have an ounce of charge in it.
Got it back to mine and charged the battery again. Same thing turned over on the key but very slowly but now has a tight rubber stretching sound at the same time. Next step took all four plugs out and the engine turned over freely, put no1 plug back in and still turned over fine, no2 plug back in still fine, no3 plug back in and starts getting tight again and struggles, no4 back in and back to square one.
Any idea's? Got spark and fuel, can't check compression at the min as my tester hasn't got the right thread adapter.
