mk2cossie
Club RR Member Number: 77
TVR differentialmk2cossie
@mk2cossie
Club Retro Rides Member 77
I'm after either a BTR or GKN diff from a TVR, ideally in 3.45:1 ratio but I'll settle for near that at the right price Not fussed about hydratrack or the other type. WHY fellow retroriders?
Last Edit: Feb 4, 2016 21:05:41 GMT by mk2cossie: Speeling mistooks
mk2cossie
@mk2cossie
Feb 10, 2016 12:47:50 GMT
Any one at all? If its any easier they are fitted to Griffiths, Cerbera, Chimera and I believe he Tuscans as well
steveg
Feb 10, 2016 12:55:46 GMT
Are they the same as the ones fitted to Jags or were they the earlier ones ?
mk2cossie
@mk2cossie
Feb 10, 2016 17:55:25 GMT
Are they the same as the ones fitted to Jags or were they the earlier ones ? No, later than the Jag diffs i do believe. The driveshaft flanges are 6bolt cv joint fitment instead of 4bolt as per the Jag diffs
steveg
Feb 10, 2016 19:27:45 GMT
Ah right, I thought the rear suspension was Jag on them and it might be somewhere else to look.
mk2cossie
@mk2cossie
Feb 19, 2016 13:24:16 GMT
Cheeky Friday bump Not in a hurry for one, but still after one
mk2cossie
@mk2cossie
Jun 11, 2016 11:42:12 GMT
Still hopeful that someone may have one kicking about that they keep tripping over
mk2cossie
@mk2cossie
Sept 26, 2016 13:01:58 GMT
To the top again, must be someone on here with one collecting dust surely
mr
Got the car from 105 bhp at the crank to 152 at the wheels.nitrous going on next.....if it ain't broke,keep bolting on go faster parts until it is........ www.fordgranadaclubuk.freefo.de
mk2cossie
@mk2cossie
Or even on eBay. But I don't want to splash out 500quid on a second hand diff with unknown history and possibly in need of a rebuild
mr
why not have yours rebuilt? I assume its for rtw. being an auto and not having more than 200 bhp id have thought itd be fine to just have your current one rebuilt,perhaps with heavy duty bits if available. they're not fragile,mines done 175000 miles and 65k of those were at my hands ( and I was never known for driving it nicely) and it still works ok. guessing yours has probably lasted longer than that already and will have survived even more miles ,so a standard one cant be that bad.
mk2cossie
@mk2cossie
Oct 12, 2016 13:11:46 GMT
207bhp thank you very much And no LSD option for them either, and I don't fancy a Quaife unit at 700plus and then getting it rebuilt as well And with a LSD equipped granny, I will have 2wd in the snow and ice, not just spinning up one
mr
my bad,thought it was around the 180 mark dammit....I thought I was only 28 horses behind you.....may need to address my nitrous jetting now........ what about an xr4i diff? someone on the now defunct gso site put a mk3 diff in his mk2. had to make a carrier for it but seeing as your having the diff mount made up now it would prob be easier
