Feb 13, 2016 19:42:06 GMT
Feb 13, 2016 20:10:24 GMT
Good luck trying to press them in!
Pressing in wheel studsDez
@dez
Club Retro Rides Member 34
Feb 13, 2016 20:14:56 GMT
the shank of the stud should be the same diameter as the hole, not the spline.
Last Edit: Feb 13, 2016 20:15:22 GMT by Dez
Feb 13, 2016 20:28:40 GMT
the shank of the stud should be the same diameter as the hole, not the spline. Exactly, which makes me think that the shank is probably about 12mm. The studs go straight from thread to splines and the splines are too fine to get the caliper in to measure the shank diameter. Outer spline diameter is 13mm-ish. Hole is 12mm, so for the shank to be the same diameter as the hole, the splines would have to be about 0.5mm tall.... seems about right?
@dez
Feb 13, 2016 20:35:00 GMT
what thread are they? M12? id guess the shank is somehwere between 12 and 12.5mm.
Feb 13, 2016 20:40:49 GMT
Thread of the studs I have is M12x1.5. The studs that the Matiz would originally have had are M12x1.25
@dez
Feb 13, 2016 20:44:10 GMT
post a pic of the stud.
tbh, a lot of it is 'feel' for what will work as the spline profiles can be so different from manufacturer to manufacturer, but that only comes with experience. but id say 12mm will probably be too tight, 12.5 is more likely. do you have a proper press or are you hammering them in?
Feb 13, 2016 20:49:50 GMT
Technically neither- the intention was to take them to someone with a proper press. Pics shortly...
Feb 13, 2016 21:26:55 GMT
Pic attached I think? Managed to break my phone in the process. Johnny- what makes you say that? Bigger hole required?
You do not press them in!
You put them in place, put the wheel nut on the thread and tighten it up. The stud will be pulled into place.
Simples
Wilk
Feb 14, 2016 10:06:19 GMT
With the sizes provided earlier you'd strip the threads before the studs were fully seated... Been there seen the t shirt Plus if they don't seat all the way there's a chance the wheel will work loose over time
Feb 14, 2016 11:41:54 GMT
Pic attached I think? Managed to break my phone in the process. Johnny- what makes you say that? Bigger hole required? Yep. Bigger hole. If you say the splines are 13.3mm ish, if I had to hazard a guess I would say the hole would be around the 13mm mark. That's hole size, not drilled out with a 13mm drill and now 13.5mm. Lol. 1 mm on that sort of diameter will never go in, not in a month of Sunday's. Press them in. Tightening them in with a nut is a recipe for disaster. Good chance you stretch the threads, and you are not allowing the straight splines to bed in straight, you are trying to twist them as you go
Last Edit: Feb 14, 2016 11:45:37 GMT by Deleted
Feb 14, 2016 12:51:56 GMT
hairymel
avatar by volksangyl
Club RR Member Number: 207
Pressing in wheel studshairymel
@hairymel
Club Retro Rides Member 207
Feb 14, 2016 19:16:18 GMT
whats that burning smell?
oh curse word :-(
Feb 14, 2016 20:17:03 GMT
Awesome thanks. Your google-fu was obviously much stronger than mine, I'd struggled to find a definitive answer! Those ones I just linked to will be just the ticket then Now I need to try and find the second hub that I can't see anywhere...
hairymel
@hairymel
Feb 14, 2016 20:39:26 GMT
its probably in the same 'safe' place most of my stuff has disappeared to
oh curse word :-(
Feb 14, 2016 22:49:14 GMT
I have seen a case where If you use a hole which is too small to press a stud into you can distort the hub, it took us a while to find out what was going on!
Feb 15, 2016 20:16:05 GMT
its probably in the same 'safe' place most of my stuff has disappeared to Found it hiding in plain site in the middle of the garage floor....! Couldn't see anything of yours I'm afraid though
