Here you go;
1. All doors, provided on the vehicle for the entry and exit of occupants, shall be designed as to allow easy and safe use. Doors shall have both intermediate and fully latched positions and their latches shall be designed to prevent the doors from opening accidentally. However, latching in an intermediate position is not required if a safety-bolt with an audible warning device is provided as specified in paragraph 2(b) below.
For the purposes of this item, “longitudinal plane” means a vertical plane parallel to the longitudinal axis of a vehicle. Paragraph 3 shall not apply to doors which do not give direct access to a seat designed for normal use while a vehicle is travelling on a road. This includes any door, for which the longitudinal plane passing through the extreme inboard projecting point of such a door is more than 300mm distant from the longitudinal plane passing through the nearest edge of such a seat. 2. Where hinges are used, the hinges shall be fitted at the front edge of the door. However, they may be fitted at the top or rear edge if either—
(a)a device is fitted which automatically closes the door at least to the intermediate latched position if it is unlatched when the vehicle is moving in the forward direction; or
(b)a safety-bolt is fitted to prevent such unlatching and an audible warning device is provided which activates an audible warning if the vehicle is driven without the bolt in place.
The latching requirements in paragraphs 1 and 3 shall not apply to any power-operated door if the force applied by the power actuator is sufficient to keep the door completely closed even when any load is applied as described in paragraph 3.
3. On hinged doors, the latch and striker assembly shall be capable of withstanding any load which is likely to be applied in the course of normal driving (i.e. excluding crash impacts) in both the intermediate and fully latched positions. However if a safety-bolt with an audible warning device is provided as specified in paragraph 2(b) above, the requirement need be met only with the bolt in place.
Phil H
Club RR Member Number: 133
Can everyone else hear the sound of an audible warning device being weighed?...
Last Edit: Dec 6, 2018 20:47:23 GMT by Phil H
Here you go; 1. All doors, provided on the vehicle for the entry and exit of occupants, shall be designed as to allow easy and safe use. Doors shall have both intermediate and fully latched positions and their latches shall be designed to prevent the doors from opening accidentally. However, latching in an intermediate position is not required if a safety-bolt with an audible warning device is provided as specified in paragraph 2(b) below. For the purposes of this item, “longitudinal plane” means a vertical plane parallel to the longitudinal axis of a vehicle. Paragraph 3 shall not apply to doors which do not give direct access to a seat designed for normal use while a vehicle is travelling on a road. This includes any door, for which the longitudinal plane passing through the extreme inboard projecting point of such a door is more than 300mm distant from the longitudinal plane passing through the nearest edge of such a seat. 2. Where hinges are used, the hinges shall be fitted at the front edge of the door. However, they may be fitted at the top or rear edge if either— (a)a device is fitted which automatically closes the door at least to the intermediate latched position if it is unlatched when the vehicle is moving in the forward direction; or (b)a safety-bolt is fitted to prevent such unlatching and an audible warning device is provided which activates an audible warning if the vehicle is driven without the bolt in place. The latching requirements in paragraphs 1 and 3 shall not apply to any power-operated door if the force applied by the power actuator is sufficient to keep the door completely closed even when any load is applied as described in paragraph 3. 3. On hinged doors, the latch and striker assembly shall be capable of withstanding any load which is likely to be applied in the course of normal driving (i.e. excluding crash impacts) in both the intermediate and fully latched positions. However if a safety-bolt with an audible warning device is provided as specified in paragraph 2(b) above, the requirement need be met only with the bolt in place. Thanks for that. I need to re-evaluate.
Dec 11, 2018 20:34:24 GMT
In order to keep the car 100% UK road legal I have decided to keep the original door locks/latches (but doing away with the exterior handles), albeit heavily lightened :-)
Dec 11, 2018 20:47:52 GMT
Check with the safety regs with regards to loosing the outer handles as it may be a requirement to allow emergency personnel access for recovery during an incident?
Dec 11, 2018 20:49:29 GMT
Check with the safety regs with regards to loosing the outer handles as it may be a requirement to allow emergency personnel access for recovery during an incident? There will be a way of opening the doors, otherwise I wouldn't be able to get in! :-)
Darkspeed
Club RR Member Number: 39
Dec 11, 2018 21:09:07 GMT
My cars have none of that and passed SVA - where are those regs from? There is a big difference for what can be sold to the public under type approval and what is required or possible to do when in the hands of a private individual.
As for MSA regs - all you need to be able to do is exit the car in a good time. There is nothing to be gained by making the car difficult to get out of in an emergency or making it hard for others to get to you. If strapped in a burning wreck I would like to think that that rescuer would see an obvious access point in order to extract me.
Dec 11, 2018 22:13:53 GMT
My cars have none of that and passed SVA - where are those regs from? There is a big difference for what can be sold to the public under type approval and what is required or possible to do when in the hands of a private individual. As for MSA regs - all you need to be able to do is exit the car in a good time. There is nothing to be gained by making the car difficult to get out of in an emergency or making it hard for others to get to you. If strapped in a burning wreck I would like to think that that rescuer would see an obvious access point in order to extract me. Agreed, that's why there will be an aluminium push button on the outside of the door and some way of pulling the door open.
Dec 11, 2018 22:20:51 GMT
Biva Regs are a little tighter than those regs - they are construction & use regs. Either way it's not really a good idea to remove good 2 stage burst proof latches.
Biva Regs are a little tighter than those regs - they are construction & use regs. Either way it's not really a good idea to remove good 2 stage burst proof latches. Spoilsport :-) But good advice.
jamesd1972
Club RR Member Number: 40
Going to have to find some weight to loose some elsewhere ! Are you close enough to being in one working lump (not finished I get the feeling this will be always in development !) that the driver weight has to be looked at now! Going to be a miserable Christmas avoiding all the mince pies ! Getting ever closer James
Dec 12, 2018 17:16:01 GMT
Going to have to find some weight to loose some elsewhere ! Are you close enough to being in one working lump (not finished I get the feeling this will be always in development !) that the driver weight has to be looked at now! Going to be a miserable Christmas avoiding all the mince pies ! Getting ever closer James I will keep looking :-) I have been monitoring my weight (or should I say my wife has) for some time and it has been stable at 85kg. However, I am sure, with some sacrifices, I will be able to shave 5kg off of that :-)
jamesd1972
Dec 12, 2018 17:35:09 GMT
Hows the to do list looking though ? 2019 first run for us to look forward to ? James
Dec 14, 2018 21:54:29 GMT
Dec 14, 2018 22:13:51 GMT
Hows the to do list looking though ? 2019 first run for us to look forward to ? James Errr..... The list has expanded (of course) eg, window clips, lock lightening, tighten rear hub nuts, but of the original list: Secure intercooler - DONE
Modify radiator brackets to allow repositioning - DONE.
Fit air filter box - FIRST FITFinish air intake pipework Fit header tank pipes Get header tank filler cap New pipe from overflow bottle to header tank. Make new exhaust heat shields in CF - DONE
Fit wiper motor (either fix original or replace) - DONEFinish front bulkhead and add heat shield material Finish engine bay bodywork Secure and adjust steering rack/rod ends for bump steer Finish front clip Fit injector rail and injectors Connect up loom. Adjust position and wire lengths where necessary Repostion ECU support bracket - DONEFit dash cover and cut hole for access Fit screen wash jets and piping Weld in additional roll cage tubing behind seats Fit roll cage cushioning Fit interior panels Make doors and glass - IN PROGESSSecure glove box door Secure switch panel - DONESecure centre console and tidy up edges Make front screen Make and fit new roof and rear screen Sort out fire supression system Fit EGT and Lamda sensors Fit oil filler cap Get and fit plug leads Fit plugs Secure fuel tank and nitrous bottle - DONEGet new electric bottle opener (or fix old one) Fit fuel filler cap Fit rear lamps Finish droop limiters Tighten ALL nuts and bolts, marking as I go. Door locks and hinges - IN PROGRESSGet seat belts and fit Parachute bracket Under floor trays, side splitters and strakes - IN PROGRESS
Rear view mirror - IN PROGRESSFit and wire up remote tyre temp sensors Change front springs - BOUGHTMake new radiator bottom hose Fit hose clips to header tank hoses and secure Fit exhaust box and cover - IN PROGRESSFit heat shield material behind exhaust box Fit boot - DONEBond in floors - DONEBolt on exhaust manifold and turbo Fit turbo support strut Reposition alternator/battery cable Repostion loom through bulkhead and fit grommets/covers - DONEFinal fit of loom, adjusting wire lengths where necessary Connect battery Sort out wheels and tyres
Last Edit: Dec 14, 2018 22:18:00 GMT by nalesutol
jamesd1972
Dec 15, 2018 18:44:51 GMT
Still a big list ! Best get cracking. Keep up the updates. James
Dec 19, 2018 16:20:49 GMT
Latest part of the car arrived today :-) Just under 2.3kg as it stands.
Dec 19, 2018 18:23:24 GMT
Bet it will weigh less soon
Dec 19, 2018 20:21:03 GMT
Bet it will weigh less soon If I decide to use it, yes :-) However, I won't do any lightening until I am sure that I am going to use it so that it is resalable.
Dec 20, 2018 11:47:26 GMT
"Agreed, that's why there will be an aluminium push button on the outside of the door and some way of pulling the door open." "...some way of pulling the door open..." you already have one of these it's called a 'handle' why not loose some weight on existing items (external handle) ? Still an impressive build either way, keep up the good work ! ...
Last Edit: Dec 20, 2018 11:49:01 GMT by westbay
