m30rmf
Hi My work vehicle is a lwb Citroën relay 2.2hdi 100 odd bhp last off the old shape on a 2006, the fuel consumption is around 20ish to the gallon which is a tab expensive. The exhaust tip is caked in soot so suggests running very rich in my mind, what can I do too rectify this if anything? Thanks in advance
get it on a diagnostic machine, they're fully electronic and have a few vacuum control solenoids for egr a doseur and thd turbo unless its a variable vane unitm
m30rmf
get it on a diagnostic machine, they're fully electronic and have a few vacuum control solenoids for egr a doseur and thd turbo unless its a variable vane unitm Anybody in the East Midlands got the diagnostic software needed for a handful off beer tokens?
lilbob
We run the fiat ducato maxi vans at work ours are 2014/2016 vans and i don't think we are getting much more than 25-28 mpg but saying that ours are fully loaded and not driven gently
2.2hdi relay fuel consumptionChasR
@chasr
Club Retro Rides Member 170
As said, get it onto a machine to check the codes out . What is your oil level like?
m30rmf
As said, get it onto a machine to check the codes out . What is your oil level like? Was bought off a gent in his 70s that had it from new, think he checked every level an tyre pressures every week...oil just below max line and doesn't seem too move..
oli123
change the mass air flow sensor
most likely cause of this
other than that, run some inejctor cleaner through it and give it a really good thrashing, all the way to the redline and hold it there whilst driving for a good 10 seconds to get them hot and burn the curse word off
although don't do that if the cambelt hasnt been done recently
Cars so far I've had: 1995 Corsa B Van 94 Golf MK3 2.0 Driver 98 BMW e39 520i 98 Focus TDDI 04 Honda Accord exec 99 BMW 728i 02 Corolla T sport 98 Focus 1.8 Zetec 98 Subaru Impreza wagon 06 Merc Cls 320cdi 07 Yaris 99 BMW 328i 04 Volvo S60 T5 98 Golf MK3 Wagon 1.8
djoptix
Citroen BX 16 valve
As others have said, you need to get it on a Lexia to find out what's going on.
Having said that, the 2.2 was never as economical as the 2.0, so if you're booting it everywhere in a heavy van then you could probably get close to the 20s even if there wasn't anything wrong with it.
OMG i totally would have that car if a) you lived closer b) i had the dosh c) i could sell this rusting mk1 Civic d) my benefits come through e) my wife would let me f) my mum would let me g) you'll MOT it
m30rmf
Feb 12, 2017 17:14:49 GMT
Slight update on this one, due to starting issues over last few days and knowing somebody who has recently bought a snap on solus he plugged it in and checked the live data, coolant temp cold was showing 215°c!!!! So new temp sensor ordered, hopefully will solve a few issues....anybody any ideas off what to expect when this has been Changed?
