Not quite, but a good attempt... As above, close but no beer. The above two are the closest attempts. To increase the suspenders as Grizz suggests, here's a pic of my other fridge (99p) on Ebay a few years ago. Oh, and the new one's use has no relation to the old one's use. This is an older pic, this fridge is a cabinet for my 3D Printers. The one printer is depicted below.
Wow, if I get grizz right, that will be a really large 3. p.....r - btw. the topic I want to contact you about! Wrong, this has a very different purpose, but I see a sudden trend developing. Patience grasshopper.... The competition will continue until either it is guessed or I have completed the work (might take a week or two) and I post of pic of the end result...
Spray/powder coating booth? Very very cool car btw.
Jul 10, 2016 20:51:20 GMT
So, it's been quite a week, not much Chevy time after the fantastic news of getting it running as reported in the post reference below: The story behind the above will be updated in later instalments... As promised, here goes, with a quick recap: So Dad had advised that I remove the plugs and pour some diesel into each cylinder and leave it to soak for 24 hours. Then crank the engine over by hand as much as possible to free things up and lube things. I used Duck Oil instead which is a fantastic penetrating oil, and of course had the luxury of a hand crank handle rather than having to use a ratchet on the crank pulley. Later on Sunday I checked the wiring and cranked the engine over a number of times with the plugs out. I also check the points gap, power to coil, distributor, oil, water, etc. I got my son to help and we cranked the engine over a number of times on the starter. I then hooked up a small fuel tank and popped the plugs back in and could get it to fire even though it seems to want to. I wasn't sure about the strength of the spark, and managed to break a plug lead (they were very perished). I was suspecting the coil, but chatting with Dad on Sunday evening, he was convinced it was the points, even though I had operated them manually with screwdriver and seen them spark. I also took the time to put the battery on charge overnight to top it all for more cranking. Top banana! Look forward to hearing what Dad's trick was! Cheers Matt So, when I got home on Monday evening, I grabbed some emery paper and carefully sanded the points (a magneto file would be better, and Dad also recommended carefully wiping the surfaces clean with a lot free cloth - like a hanky). Due to the broken plug lead, I popped next door to Joe (another petrol head with a penchant for US motors) to see if he could lend me one. With a good lead from Joe, I suddenly had a strong spark and the Chevy barked properly. I quickly headed back to Joe for more plug leads and he lent me the brand new set he had bought for this: Following the new plug leads and filing the points, it all fired up as you saw. Here are the old leads and new box. I subsequently started it a few times during the week, once to get this picture of the oil pressure. I have since placed an order with Rock Auto for some new parts, including a new set of plug leads for Joe. On Thursday evening Joe warned that he might need the leads back as his electrically minded friend was coming to visit on Friday. Friday evening Joe confirmed that he had taken the leads back, and more Chevy good news in the street. His '55 van is running as well. So currently between us we have one set of leads, I'll leave them with Joe as mine should be here in 10 days or so.
Jul 10, 2016 21:02:26 GMT
I do love Joe's van.
It is soooo rat that it is actually like methylated spirit drinker or crack head who has hit rock bottom, who just walked into an upmarket country club expecting to be served.
Nobody will serve him.
This van is up there.
Craig's dad on the other hand is very clever man, and has a lifetime of knowledge to share.
Talk of living vicariously through another persons experiences.
Jul 10, 2016 21:10:18 GMT
Spray/powder coating booth? Very very cool car btw. Sorry, wrong again, but I like your thinking. I'm thinking old chest freezer and cookers (for elements) for powder coating booth. On the car front, thanks! Wrong, this has a very different purpose, but I see a sudden trend developing. Patience grasshopper.... The competition will continue until either it is guessed or I have completed the work (might take a week or two) and I post of pic of the end result... I decided to let you all out of your misery. Some guesses were close, but people probably don't know enough about my hobbies (or the insanity that is my mind) yet to guess. First, some progress pics: As delivered. My colleague (Dan) from work collected it and dropped it off for me. We left it lying like this overnight so that I could strip the refrigeration units from it before moving it. I then ratchet strapped a homemade trolley to it and having moved the motorhome and towed the Chevy out of the way, my boy, Kyle, helped me trundle it down to the garage. I then returned the Chevy to it's rightful place (Kyle steering - he's driven the Chevy more than me since I've had it). I then spent a few hours continuing to strip out the fridge and re-wire it so that only the lights work (failed at that, think the lights are faulty, will look again sometime), and finally Kyle helped me manhandle it into it's final home. This space below, where the motor, etc used to be will become a big deep drawer for general storage in the garage. So, what is this for? I will be putting a clothes rail and some shelving in it, and it will then be the "Wardrobe" for my motorcycle gear. SWMBO wants the bike gear out of the house as it is quite bulky, and I don't want it getting dusty with normal garage detritus. So I figured a fridge is sealed and I can see in it. Before you start commenting about the fact that gear could be damp, etc. I do actually plan to cut some holes in and fit filters and fans to make it draw controlled air through the unit. Oh, and a Coke fridge is simply cool!!! Especially those door handles.
Jul 10, 2016 21:26:15 GMT
Six degrees of separation.
Who on here knows about that concept??
I sent Dennis in St Louis Missouri that pic of the fridge in position, and his reply within seconds via FB Messenger was "Those things are made in a factory a mile form my shop"
Mad ehhhh?
PS. I do feel like a stalker on this thread as I keep finding stuff to post about.
Last Edit: Jul 10, 2016 21:27:19 GMT by grizz
Jul 10, 2016 21:31:20 GMT
3rd and final update for the evening (I didn't get much time last week, so tonight is catchup time!!!). Remember this post? TOP SECRET EHHHHHHHHH Shhhhh!!! You never know who's looking!!!! More news in about 4 months or so... Well, I know it hasn't been 4 months yet (and still not ready to let the cat out of the bag) but... What most of you guys probably didn't know is that I have a 2CV in storage which was meant to be sold before the Chevy arrived. When the re-commissioning in preparation for the sale when badly, I got fed up with it and pushed it into my storage unit and pretended I was an Ostrich (I.e. Stuck my head in the sand and ignored it). Well, today I decided to do something about it. The 2CV has to go so that I have some space back in the storage unit. So this evening quickly went out and snapped some pics (here's one): I then spent some time writing up an Ebay listing. The plan was to then copy that and post it up here on RR in case someone here likes the idea of a French project. When done with the listing I submitted it and while getting my head straight on what to next, and email popped into my inbox, entitled "You've sold your eBay item: Citroen 2CV6 Special White B-Reg - Project". So, the listing lasted all of 21 minutes. The buyer has already phoned me and will be coming around with cash tomorrow night to collect his new toy. And the good news is that the Buy It Now price I set means it broadly washed it's face which I thought might struggle. I still have a pile of 2CV bits (mainly for older ones and vans, but some new parts) to sell. A taster of these is included in the listing I have for a new galvanised 2CV chassis: Ebay listing
What does this all have to do with the SECRET? Well, the storage is needed.
Last Edit: Jul 10, 2016 21:43:34 GMT by craigrk
Jul 10, 2016 21:42:20 GMT
I do love Joe's van. It is soooo rat that it is actually like methylated spirit drinker or crack head who has hit rock bottom, who just walked into an upmarket country club expecting to be served. Nobody will serve him. This van is up there. This is such a perfect description. Pictures simply don't do this van any justice. In person it looks even worse than you'd think. Which means it looks fantastic. When it's on the road I really want to try to borrow it, just to go to work one day and wind up my colleagues. I'm definitely on the first refusal list for this van. Craig's dad on the other hand is very clever man, and has a lifetime of knowledge to share. I know he's my dad, but this is so true. My whole life I have seen Dad simply go with his gut. He just knows the answers and lives that conviction. Others try to see the evidence to try to draw conclusions and he just knows. And he's right! Blows my mind, always has done. It meant that without formal training as a mechanic, main dealers would often send vehicles to him when they were eventually stumped, and he would fix them in no time. Sometimes without even seeing the car, just being asked the question. Wish I could get him to come visit. He would love the Chevy. Talk of living vicariously through another persons experiences. Live away, that's what we're all doing here!!
Jul 11, 2016 17:16:46 GMT
Last Edit: Jul 11, 2016 20:46:58 GMT by craigrk
fer4l
Testing
Club RR Member Number: 73
Jul 11, 2016 18:33:50 GMT
I had a similar need recently when trying to double up a parking space with one car above another. There are loads of good (and dear!) ramps out there, but none that really fitted the bill for me (no electricity etc.)
I was going to make 15' ramps, pivoted a little off centre front to rear on (very) sturdy triangulated and linked supports, with positive stops at the ends a bit like MoT ramps have, use a 12v trailer winch and pulleys to pull the car on / control descent rolling off, and vertical poles at each corner to lock in and stop anything having any chance of collapsing once in position etc.
Happy to dig out my sketches if of interest
Cheers
Matt
Jul 11, 2016 20:48:19 GMT
I had a similar need recently when trying to double up a parking space with one car above another. There are loads of good (and dear!) ramps out there, but none that really fitted the bill for me (no electricity etc.) I was going to make 15' ramps, pivoted a little off centre front to rear on (very) sturdy triangulated and linked supports, with positive stops at the ends a bit like MoT ramps have, use a 12v trailer winch and pulleys to pull the car on / control descent rolling off, and vertical poles at each corner to lock in and stop anything having any chance of collapsing once in position etc. Happy to dig out my sketches if of interest Cheers Matt Sketches would be interesting even if I don't do that. Need ideas just to figure out a plan.
Jul 11, 2016 20:49:56 GMT
What does this all have to do with the SECRET? Well, the storage is needed. Happy buyer made an escape towing B60 home behind his 602cc Van.
Jul 12, 2016 17:54:12 GMT
Quick update. Remember this? Well, Joe told me he didn't get a key with the van, so when they started it last Friday they had to hotwire it. In case anyone was taking note and wondering about the Burger King cup on the back seat in the pictures on the first page of this thread, here is what was in it... Joe borrowed the keys and and trying a number managed to find one that fits his van. Result! What I didn't tell you before is that the key the seller provided with the Aerosedan didn't work, and I also found one through trying them all.
fer4l
Testing
Jul 12, 2016 19:59:49 GMT
Here you go. Ignore pivot point - only a rough sketch. Hatched bit is back of car trailer to give a bit of a head start E&OE! Oh and if this doesn't work maybe 4 oil drums off ebay at a fiver each and some scaffold planks?! Cheers Matt
Jul 12, 2016 22:23:38 GMT
To all who have tried to help me solve my problem with raising and supporting the vehicle for cleaning/painting underneath, I have just posted this update in the questions thread, thanks!! All, thanks for the great suggestions. It got me thinking and working out what could work and what would not. The Tip-Jack/car rollers wouldn't work as the drive is too narrow Things like the one-side lift I wouldn't be comfortable with due to the slope of the drive High axle stands are a great idea, but need to ensure I have something stable enough on the sloping drive. As I said in response to the Tip-Jack suggestion, it would be ideal if I could tip the vehicle lengthways rather than sideways. Well, that got me thinking. What about if I could get a narrow enough car trailer. Put the car on the trailer, that would raise it. Fair enough, I'd be tripping over trailer axles, but I could handle that. A further major plus for a trailer is that a) it's easy to get home (I don't have a van), I can simply tow it home; and b) it should be easy to sell again in the future. So, off to Ebay to do some searching, and guess what. Found a trailer listed in the last hour in the next town along (7 miles away) for what looks like a bargain price. So, I've hit the BIN button and will discover what I've bought later in the week, Hope I t works out else I'll have a trailer for sale. (Pictures will be on my main thread later). Of course, I will still have the problem of jacking the vehicle to remove the wheels for doing the brakes, but that's a problem for another day. I will post pictures later when I can download them. I might even be able to cobble together a variation of fer4l's idea by combining this with my new engine crane (Oh Yeah! Did I tell you about this? The colleague who fetched the fridge for me, also delivered the engine crane that he sold me for a knock down price)
fer4l
Testing
Jul 12, 2016 22:43:39 GMT
Sorry managed to double post sketch as opposed to one of the available ramps Trying again...but cheap trailer and a 'ferkoff' hoist would do just as well Cheers Matt
Sorry managed to double post sketch as opposed to one of the available ramps Trying again...but cheap trailer and a 'ferkoff' hoist would do just as well Cheers Matt I like these and had looked at some on Ebay, considering distance and needing to rent a trailer or pay someone to get them home, the trailer is a lot cheaper (and more useful - hmm! Projects!!!)
93fxdl
Enter your message here...
Saw this And thought of this build Ttfn Glenn
Jul 13, 2016 15:49:43 GMT
Saw this And thought of this build Ttfn Glenn Very Nice. No way is this going to achieve anything remotely close to that. I love what Boyd could do with cars.
