gt
Jul 11, 2016 15:05:30 GMT
mine does around 32mpg however i drive it which is good because i like to thrash it, good thing about these cars is doesn't really matter how hard you drive them there is nothing on the car you can break that will cost a lot of money. the panasports have a really low offset on them, i did have a set of 14" bbs lightweight alloys on mine but the had a 46 offset and sat inside the arches to much so they had to go. hoping to find a torsen for mine but they seem to fetching silly money at the moment.
Jul 11, 2016 15:08:43 GMT
Jul 11, 2016 15:27:21 GMT
Me too - I generally hate black wheels on anything! Seemed a shame to waste 2 cans of paint though so had to be done! They aren't 100% black so I can live with them being that dark! I'll certainly have a look into the codes, my friend (also has an eunos) bought a timing gun and has done the 14 degree mod to his. I'm not interested in doing it to mine, I like the power being right at the top of the revs. However He did have a look at mine and reckoned the timing was all over the shop. Could be down to the fact the timing gun was a tenner eBay special! I plan on high comp/cams/itb's over winter so on the lookout for a long nose crank 1600 block to start a build with. mine does around 32mpg however i drive it which is good because i like to thrash it, good thing about these cars is doesn't really matter how hard you drive them there is nothing on the car you can break that will cost a lot of money. the panasports have a really low offset on them, i did have a set of 14" bbs lightweight alloys on mine but the had a 46 offset and sat inside the arches to much so they had to go. hoping to find a torsen for mine but they seem to fetching silly money at the moment. I did find some spacers on the front, which I thought i'd stick on the rear - fill the arch a bit more! Only to find that the wheel's then didn't clear the front calipers. So They must have a pretty low offset! I've tried to find out what panasport's they are but had no luck in finding a match online. As for the Torsen, The one I've bought is a Type 2, from a Mk2 Sport. Not quite as harsh as the original type 1 from the mk1 eunos (if you believe what you read online) But they can be pricey. It's almost worthwhile finding a rotten/cheap mk1/mk2 and taking the dif off, selling the donor car on with an open diff in it's place.
Jul 11, 2016 15:50:00 GMT
Going to pick these two Watanabe 14x6 Splits up this weekend too. Absolute steal on eBay. Although they are a +40 offset so don't know how they will look on my car. Was going to use these on the rear with the panasport on the front. I will do if they fill the arch a little better. If not, i'll keep my eye out for 2 more to make a full set.
Jul 16, 2016 18:28:46 GMT
De cat mocked up. And it's back on the road! Decat extension piece made up. snug fit All clamped up now and sealed perfect. It's erm,,,,, LOUD. Also found a holesaw at work, oh dear. Race car points. Then thought screw it, I'll let gary grinder loose on the back bumper too. Need's a bit of tidying up, remove the tow hooks, the huge plates they attach to (and look stupid now) and fab up a nice new tow point that can't be seen. Also found some little spacers in my mums shed, stuck them on the rear to fill the arches a little more. Last but not least, a quick reminder.
Last Edit: Jul 16, 2016 18:29:47 GMT by nicklincs
Jul 21, 2016 16:54:35 GMT
Was this being driven thru Market Rasen about 3 this afternoon? If its not yours,it must be its twin!
Jul 26, 2016 12:45:35 GMT
Was this being driven thru Market Rasen about 3 this afternoon? If its not yours,it must be its twin! No wasn't me bud! optimusprime
