This was a bedford I was thinking of buying.
LOL...
MOT history of this vehicle
Test date30 November 2011Expiry date29 November 2012
Test Result Pass Odometer reading3,803 miles
MOT test number 8377 2423 1377 Test date 28 June 2011Test Result Fail
Odometer reading 3,801 miles
MOT test number 7078 4907 1199Reason(s) for failure
Nearside Front position lamp(s) not working (1.1.A.3b)
Nearside Rear position lamp(s) not working (1.1.A.3b)
Offside Rear position lamp(s) not working (1.1.A.3b)
Offside Rear fog lamp not working (1.3.2b)
Nearside Registration plate lamp not working (1.1.C.1d)
Nearside Stop lamp not working (1.2.1b)
Offside Stop lamp not working (1.2.1b)
Direction indicators not working (1.4.A.2c)
Hazard warning lamps not flashing in phase, with ignition on (1.4.B.1f)
Hazard warning lamps not flashing in phase, with ignition off (1.4.B.1f)
Nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)
Offside Windscreen wiper does not clear the windscreen effectively (8.2.2)
Windscreen washer provides insufficient washer liquid (8.2.3)
Nearside Obligatory mirror seriously damaged, affecting the rear view (8.1.2a)
Fuel cap/sealing device missing (7.2.4a)
Fuel cap/sealing device mounting flange/sealing method defective (7.2.4c)
Rear registration plate obscured (6.3.1d)
Offside Front Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Nearside Front Brake pipe excessively corroded (3.6.B.2c)
Offside Rear Brake pipe excessively corroded (3.6.B.2c)
Brake hydraulic reservoir fluid level below minimum level (3.6.G.1b)
Nearside rear brake recording little or no effort (3.7.B.5a)
Offside rear brake recording little or no effort (3.7.B.5a)
Nearside rear parking brake recording little or no effort (3.7.B.6a)
Nearside Front rear brake juddering severely (3.7.A.5b)
Brake pedal has insufficient reserve movement (3.3.A.5)
Nearside Front Upper Suspension arm has excessive play in a ball joint (2.4.G.2)
Offside Front Upper Suspension arm has excessive play in a ball joint (2.4.G.2)
Nearside Rear Suspension spring mounting prescribed area is excessively corroded (2.4.A.3)
Offside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Nearside Front Track rod end ball joint has excessive play (2.2.B.1f)
Nearside Rear Tyre has ply or cords exposed (4.1.D.1b)
Service brake: efficiency below requirements (3.7.B.7)
Advisory notice item(s)
Nearside Front Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
general bodywork and underbody in advanced state of corrosion
Thats 33 fail points, an advisory and a rather worrying parting opinion
LOL...
