Nov 20, 2016 21:26:16 GMT
in the short term , just to make it look a bit less abandoned , why not get some paint (any paint) on it? even just a quick roller applied job in one colour to make it at least look a little more cared for and road worthy? I got paint but i don't have the time to do it, just one more week of school and then i can work on the car every day at almost any hour... But for now the clean windows should do the trick.
Nov 20, 2016 21:29:59 GMT
ideal. empty out all the crud from the inside , clean up the dash and throw a dose of shiny shiny on all the interior and exterior trims and you will make a 100% improvement to the look of the old thing! those front seats look mighty comfy.
Nov 20, 2016 21:35:17 GMT
ideal. empty out all the crud from the inside , clean up the dash and throw a dose of shiny shiny on all the interior and exterior trims and you will make a 100% improvement to the look of the old thing! those front seats look mighty comfy. I took out all of those bottles after i took the picture. Those seats are the second most comfy seats i've ever sat on, the first are from a pegaso 1234.
Nov 21, 2016 18:33:24 GMT
Nov 21, 2016 20:57:58 GMT
what are the legalities of parking a car on the public highway in your part of the world?
Nov 21, 2016 20:59:02 GMT
fad
Nov 21, 2016 21:23:49 GMT
Looking forward to seeing the progress buddy!
Nov 21, 2016 23:27:10 GMT
what are the legalities of parking a car on the public highway in your part of the world? I only know that there are some streets where you can't park a car and they are marked with a sign like this. Which means something like "do not park here"
perhaps spend a little time researching in more detail where you can and can't leave your car , at least you will have peace of mind knowing the relevant traffic law.
Nov 25, 2016 20:32:13 GMT
Nov 25, 2016 20:49:54 GMT
not sure what products are available to you but you will need to go over them first with a very lightly abrasive cutting compound (I use 3m finesse it) , then a decent polish (autoglym super resin polish , which is still very very slightly abrasive) then if you are really keen a top coat of wax/silicon polish to keep uv & weather at bay.
Nov 25, 2016 20:51:05 GMT
Nov 25, 2016 21:48:20 GMT
not sure what products are available to you but you will need to go over them first with a very lightly abrasive cutting compound (I use 3m finesse it) , then a decent polish (autoglym super resin polish , which is still very very slightly abrasive) then if you are really keen a top coat of wax/silicon polish to keep uv & weather at bay. The less abrasive thing i have is p 600 sand paper
Nov 25, 2016 22:29:04 GMT
noooooooooooo... too coarse! you only need to use polishes , unless you have access to very fine production paper 1500g or finer. if you cant obtain any proper automotive cutting & polishing liquids you could try some household abrasive cream cleaner (go very gently and maybe a small area underneath the lens where it wont be seen). wash off with clean water after.
Nov 25, 2016 23:06:09 GMT
noooooooooooo... too coarse! you only need to use polishes , unless you have access to very fine production paper 1500g or finer. if you cant obtain any proper automotive cutting & polishing liquids you could try some household abrasive cream cleaner (go very gently and maybe a small area underneath the lens where it wont be seen). wash off with clean water after. What about one of these sponges?
Nov 26, 2016 17:38:13 GMT
never tried one but I doubt it'll do much. you really need a slightly abrasive liquid and a soft cloth (washed out old t shirts are perfect). do you have any metal polish.... at a push you could try a toothpaste? the very fine "cut" is what you want to remove the surface oxidation without scratching the plastic too deeply.
eurogranada
Nov 28, 2016 13:38:52 GMT
That sponge will scratch no doubt. Using a used one will scratch less, but strikey is right: use compounds with very fine abrasives. But even then, looks like you'll never be able to restore them both to the same colours. I'm sceptical at the very least. Although I've been pleasantly surprised before. On the Granada lenses it's not only the plastic that discolours, it's also the paint on the inside that flakes off... Good luck, but if you do try, use the proper stuff, even if you have to buy some!
Nov 28, 2016 14:49:56 GMT
Nov 29, 2016 21:35:46 GMT
Nov 30, 2016 23:26:32 GMT
Early morning pic
