Oct 26, 2016 15:56:28 GMT
As part of trying to have a bit of a sort out in the garage I decided to stop and fit these. needless to say the garage sort out failed
I fitted these UK lights last week and was quite please with them.
I did a first trial fit with these Walk / Don't Walk lights this afternoon.
I'm not sure which ones to keep and finish off and get wired up correctly
which ones would you guys go with ?
awoo
Oct 26, 2016 18:35:54 GMT
I would say the American ones are more interesting, personally
Oct 26, 2016 21:21:27 GMT
I would say the American ones are more interesting, personally They certainly look a lot better in the dark I've just been out and tried them.
Oct 26, 2016 21:27:58 GMT
Could you rig the don't walk ones up to a security light?
Oct 26, 2016 21:30:10 GMT
I'd say American because they're a rarer sight on a British road.
Could you rig the don't walk ones up to a security light? the original plan was to wire them up through a movement sensor so the "Don't Walk" comes on when someone approaches the door. ideally I would like the "Walk" light to come on after say a 90 second delay. I will need some help on the wiring as my electrical skills are limited but I'm sure it can be done
Could you rig the don't walk ones up to a security light? the original plan was to wire them up through a movement sensor so the "Don't Walk" comes on when someone approaches the door. ideally I would like the "Walk" light to come on after say a 90 second delay. I will need some help on the wiring as my electrical skills are limited but I'm sure it can be done Yeah that's what I meant
Could you rig the don't walk ones up to a security light? the original plan was to wire them up through a movement sensor so the "Don't Walk" comes on when someone approaches the door. ideally I would like the "Walk" light to come on after say a 90 second delay. I will need some help on the wiring as my electrical skills are limited but I'm sure it can be done If you do this it will only be a while before kids start playing with it and some adults
VW nut 1984 MK2 golf type 19e
[/quote]If you do this it will only be a while before kids start playing with it and some adults [/quote] very unlikely where we live, plus I have the trump card..............the switch
