Oct 15, 2017 17:28:58 GMT
I'm not usually a Chevy guy but this thing, over there, in that condition- AMAZING. Oh please put a modern ish Landy Disco under it.. At the moment, with the way legislation is potentially headed over here, anyone that is seriously contemplating major mods on a vehicle like this really needs to do their homework before committing. Even if you transplanted the entire chassis/suspension/ steering and drivetrain from a single donor, which in the past could have been passed off as the original 1990s Defender/Discovery/Rangerover with a rebody, at the moment it looks like it could still be considered a significant change, so triggering a set of test criteria that getting a 1950s body through would be challenging. I'd love it though, if I didn't already have too many things to do. It's probably worth seeing how it settles, but I've been reading a lot about the legislation changes, and so far I haven't seen anything to stop the re-body approach. The changes look to mainly focus on how to define which vehicles are MOT exempt, but this will of course catch those cars that didn't follow the rules. Exactly the reason I'm looking to follow the rules!!. That said, as noted above, "Custard" was meant to be a relaxing between jobs build and instead is actually surplus to requirements. I do love it though, so am not rushing to sell.
Oct 15, 2017 17:49:49 GMT
Those who took careful note of the pictures above will have noted that the right hand door was not closed. It turns out the lock had been activated while the door was open and had rusted into position. I figured I better deal with this. I tried to remove the screws (all clutch head), but they were all too far gone, so I had to drill them out. Some pics of the progress below. PS: I really struggled to get the mechanism out as one of the welds had broken and it was catching on the sheet metal inside the door. Once I realised this, it all below easier. The contents of the bottom of the door!! The lock mechanism as removed: I'd tried freeing it up with Duck Oil, but when I realised that wasn't going to work I decided to try electrolysis for the first time in my life (I don't know why I haven't done this before!!!). Having Googled for instructions I realised I had all the bits except Soda Crystals, so dashed to the supermarket for those and then set to. The parts needed: Assembled: Soda Crystals: All connected up and starting to brew: (The instructions said about 1 tablespoon of Soda Crystals to a gallon of water). The result (This might not look a lot better in a picture, but some of the parts became moveable after this): I then soaked the whole thing in Duck Oil for a while, but on removing it realised this wasn't going to be enough, so I dismantelled the parts of the lock that I could by bending out the tabs that had been folded over (The following pictures were taken mainly for my own reference on re-assembly): As you can see the pieces that were touching solidly were still covered in rust, whereas outer surfaces had benefited from the electrolysis. So I grabbed my workshop metal sieve and dropped all the small loose parts into that, mixed up a new batch of Soda Crystals (stronger this time) and started a new session of electrolysis. Here's the start: And two hours later: I took all the bits out, it had helped a lot, but the process puts a black film on them. I cleaned them off and then started them on a new session, I'll show pictures of the final result next time. What I can say is that the rotating bits that have not be dissembled are now playing balling and rotating freely after a bit of playing back and forth.
vulgalour
Club RR Member Number: 146
Oct 15, 2017 18:08:53 GMT
That looks promising. How did the sieve fare being a different metal to the rest?
Oct 15, 2017 18:37:35 GMT
i was going to say straight off from your first picture 1 table spoon for a gallon is way too weak, more like half a bag in that bucket. looks like its chugging now !
That looks promising. How did the sieve fare being a different metal to the rest? Doesn't look like it was touched.
i was going to say straight off from your first picture 1 table spoon for a gallon is way too weak, more like half a bag in that bucket. looks like its chugging now ! Yeah, I'm pretty generous now. At £1.19 for a bag, the cost isn't an issue
MiataMark
Club RR Member Number: 29
Oct 18, 2017 13:04:07 GMT
What did you use as a power supply? I've been using a Scalextric transformer but not sure it is powerful enough.
melle
South West
It'll come out in the wash.
Oct 18, 2017 13:59:10 GMT
I find Deox-C a bit easier easier than electrolysis for small stuff.
Oct 19, 2017 20:11:02 GMT
What did you use as a power supply? I've been using a Scalextric transformer but not sure it is powerful enough. I have a benchtop power supply that used to be used in a laboratory (got it on Freecycle years back), had it set to about 15v and 1A.
dikkehemaworst
Club RR Member Number: 16
Oct 19, 2017 23:09:17 GMT
What did you use as a power supply? I've been using a Scalextric transformer but not sure it is powerful enough. I always use my battery charger. Works great!
Oct 20, 2017 10:23:17 GMT
needs some kind of regulation i think. when i used my gunson battery charger the gauge was full whack off the scale of 9 amps and the charger got stinking hot. fitted a 12v festoon bulb inline which sorted it
Dec 10, 2017 16:38:09 GMT
Road trip with craigrk and his son Kyle to fetch a straight Chevy Straight 6 260ci motor, auto box and rear axle from a '53 Chevy truck to go into one if his three cars. The 47 Aerosedan or his wifes 49 or his 50 pickup truck. Off to Colchester in Essex by 07.30 to meet them in Dartford and then onward. The snow started just after I left home. By the time we met....... Craigs new to him 4x4 Ranger. Slowly got more whited out. And speeds reduced quickly to below 50mph. Happy days. As we progressed the speed dropped right down to stop and start and an average of 25mph max. Saw a lot of carnage and slippy stuff and cars in ditches with black ice. But unable to stop on the motorway to change to high range four wheel drive despite trying on the fly. Then from nowhere With traffic as slow it was we took more than an hour longer than planned by Satnav. Got there. Loaded Teenager waiting while we looked at Barry the selkers stuff. Motor etc were in this before. Making our way back the traffic was even worse. Snow lovely though. So this has taken 7 hours so far. Craigs door to door including offloading the parts should take him to an 11 hour day. Did we have fun Yes we certainly have. In the mean time I am now decided that Prozac is for sale and I want a 2x4 Super cab (not 4x4 Double cab) Ranger in reasonable condition. Probably a Mk2 around 2002-2006 truck. Interesting colour hoped for too.
Dec 10, 2017 18:14:20 GMT
Not much to say other than thanks to grizz for effectively do my thread update for me. In retrospect, enjoyed the ballet lesson (pirouette) in the Ranger, thankfully nothing too serious in the way of damage. Road trip with craigrk and his son Kyle to fetch a straight Chevy Straight 6 260ci motor, auto box and rear axle from a '53 Chevy truck to go into one if his three cars. The 47 Aerosedan or his wifes 49 or his 50 pickup truck. <--SNIP--> <--SNIP--> Did we have fun Yes we certainly have. In the mean time I am now decided that Prozac is for sale and I want a 2x4 Super cab (not 4x4 Double cab) Ranger in reasonable condition. Probably a Mk2 around 2002-2006 truck. Interesting colour hoped for too. Safely made it home having deposited the engine, box, axle, prop and exhaust at the workshop waiting to be fitted next year. Oh, and if anyone has a suitable super cab Ranger for grizz , please let us know.
Speedle
Dec 11, 2017 11:44:53 GMT
Excellent choice in transport vehicle! As it's "new to you" I would recommend the following from one Ranger owner to another Change the cambelt if it's not been done recently. 30min job if that, and I'd never even attempted one before owing mine. Check the rad for signs of distortion, overheating is usually the only killer of these engines and 9/10 its the rad to blame, I changed mine last year when I found a small leak, when I removed it I found the rad had a nice curve to it... Check the rear diff seal, they like to weep but it's a cheap and easy fix. Also the diffs like to rust and get pin hole leaks (in extreme examples) so clean and protect it ASAP as you cannot just replace the casing it'll be a whole new axle(which sucks) Get the arch covers off and check for rust! Like yesterday! They rot like you wouldn't believe under those but if you catch it quick you can save the wings, I've just had one of mine replaced at great cost... Finally, Milner4x4 are excellent for cheap parts. They also sell poly bush kits for these, which are well worth the investment, especially the front roll bar (which is not much at all) Feel free to drop me a PM or get in touch is you need any help with anything. I've done most things to mine including clutch changes and the like and fitting parts from later MK3-4 rangers
Excellent choice in transport vehicle! As it's "new to you" I would recommend the following from one Ranger owner to another Change the cambelt if it's not been done recently. 30min job if that, and I'd never even attempted one before owing mine. Check the rad for signs of distortion, overheating is usually the only killer of these engines and 9/10 its the rad to blame, I changed mine last year when I found a small leak, when I removed it I found the rad had a nice curve to it... Check the rear diff seal, they like to weep but it's a cheap and easy fix. Also the diffs like to rust and get pin hole leaks (in extreme examples) so clean and protect it ASAP as you cannot just replace the casing it'll be a whole new axle(which sucks) Get the arch covers off and check for rust! Like yesterday! They rot like you wouldn't believe under those but if you catch it quick you can save the wings, I've just had one of mine replaced at great cost... Finally, Milner4x4 are excellent for cheap parts. They also sell poly bush kits for these, which are well worth the investment, especially the front roll bar (which is not much at all) Feel free to drop me a PM or get in touch is you need any help with anything. I've done most things to mine including clutch changes and the like and fitting parts from later MK3-4 rangers Speedle, thanks for a great note. I'll climb into that list of checks as soon as I get back from Christmas holidays. On a positive note the Cambelt was replaced in May (need to confirm what that means in mileage terms, but I expect sub 10k given annual mileages) - this was one of the first things I checked on the service history.
This is a long shot. But a worthy long shot because it is about keeping a car on the road. My mate CraigRK has been offered a compete front axle for his 1950 Chevy truck that he is keeping standard. Problem is that it is in Sheffield, he is down South near Guildford. The next few weeks to end May is crazy for him and he cannot collect and does not know anyone who can collect and hold it for him. CAN ANYONE HELP PLEASE?? If so, please PM me or call Craig directly on +44 7718 526539 Message he sent me: Do you know anyone in the Sheffield area who could collect and hold it. I’m not going to get there before end of May at the earliest Happy to call him, but I don’t have anyone I could ask to hold it, so it would be a short conversation given his wife’s understandable sentiments. This is where the axle is located: S10 5DP Not sure if post code is right. Photo of item. Thank you all.
the electrolysis looks promising. gotta try that. I like the idea of adding a 12v bulb in line to calm the charger down....I'm assuming it added some resistance in the line so the charger thought it was charging a battery. I think my little charger puts out 1.5 amps max, or something like that....its very basic....so might work as is.
to clean out a stubborn lawnmower fuel tank, I resorted to a solution of hydrochloric acid used for cleaning, well everything...brick, metal, ect...but it will continue to eat away anything it touches (except plastic buckets), and is noxious. all it took was about 1 minute in solution with a few ball bearings inside and wow..super clean. it had to be treated right away with Red Devil or Tank Cote....as the process seemed to invite new surface rust immediately. anyway...
glad you got that door lock working again!
JP
May 14, 2018 13:57:59 GMT
the electrolysis looks promising. gotta try that. I like the idea of adding a 12v bulb in line to calm the charger down....I'm assuming it added some resistance in the line so the charger thought it was charging a battery. I think my little charger puts out 1.5 amps max, or something like that....its very basic....so might work as is. JP i have an old gunson battery charger which is 9amps, the needle flicked right off the scale when i tried electrolytic rust removal, charger got very hot. plus the solution is frothing like mad (which is hydrogen, dangerous) so it definitely needs calming
Last Edit: May 14, 2018 14:00:24 GMT by darrenh
Jan 20, 2019 10:45:03 GMT
Waiting. Patiently craigrk Any updates? Any of your fleet for sale yet? One guy does not need that many toys. Despite the rules.
Jan 22, 2019 18:54:30 GMT
Waiting. Patiently craigrk Any updates? Any of your fleet for sale yet? One guy does not need that many toys. Despite the rules. Hi grizz, stop being so impatient. Well, in fact, some of the fleet is for sale, some more urgently than others, but first, a story!! Some will remember that this story started here: SWMBO on the other hand likes big engines and shiny (especially on her fingers - but that's not a story for this forum). (Bodes well for me if I go bald I suppose...). Her previous car is nowwas my daily: Here's her currentprevious daily driver. And yes, the 63 does denote engine capacity! At 510bhp it makes for a pleasant Sunday cruiser. The intention was to use the ML500 as a body swap chassis donor for the Chevy 3600. Well blowing the head gasket(s) on the ML500 put paid to that and the ML63 was never going that way during to being a monocoque. So what is the next best thing?
