Nov 29, 2016 21:04:11 GMT
Ok so I made some progress today. I fitted the new (donor) shackle and the car seems to have settled down somewhat, not perfect but close enough for now. I also drained, flushed and refilled the rear shocks and measured both arms and also the drop links on both and they compare so good news I think. It might be worth checking the ride height at the front. Some MGBs of this era were built on a distorted jig and the front nearside chassis leg is 6mm higher than the offside. If yours is one of those, then it can look like the back is high on the offside even when you've fixed all the obvious things. In the past, I've put a 6mm alloy shim between the crossmember and the chassis leg to get the geometry and corner weights right.
V8 MGB GT sprint and track V8 Ford Pilot Woodie project 1971 Early Bay VW camper
nigxl
Nov 29, 2016 21:46:13 GMT
Thanks for that, I know that the front suspension has been replaced maybe badly. Would 6mm make such a difference?
Nov 29, 2016 22:04:43 GMT
Yes it does because it is so far inboard and the effect at the wheel is magnified. I first found it when I measured the camber on a rubber bumper B and there was twice the camber on the nearside compared with the offside. I then measured the ride height and it was around 10mm different left front to right rear and the corner weights were miles out.
Nov 29, 2016 22:50:26 GMT
you know that there are shims between the body and the front wishbones to address any camber issues?
nigxl
I'll probably be fitting the rear shocks either today or tomorrow, once that's done I'll sit her back down on her wheels and see what she looks like. At the moment she looks Ok with axle stands under the rear springs.
Nov 30, 2016 10:44:38 GMT
That's looking a lot better!
vulgalour
Club RR Member Number: 146
Nov 30, 2016 15:00:49 GMT
Looks promising.
Davey
Resident Tyre Nerd.
Nov 30, 2016 16:42:43 GMT
That's better than factory anyway! :-P
nigxl
Nov 30, 2016 20:07:12 GMT
yeah i'm pretty happy with it for now. Been stripping and cleaning the carbs today, no wonder it wouldn't start they were hanging with varnish and crud. Just spent nearly £200 on carb repair kit and new fuel pump, no going back now.
nigxl
Last Edit: Dec 1, 2016 10:19:19 GMT by nigxl
nigxl
Looking for headlights for the MGB and rear bumper or maybe a sebring rear end if anyone has one.
Nathan
1978 MGBGT project ( now sold )Nathan
@bgtmidget7476
Club Retro Rides Member 1
Being a RB model you'll need to make a closing section for below the rear lights if you want the Sebring rear.
nigxl
Thanks Nathan, I have seen the fibreglass rears with the closing section moulded in, thinking that may be the way to go
adam73bgt
Club RR Member Number: 58
I've got a sebring rear valance which I've been in two minds about fitting to my car, it may be available as I'm probably not going to use it
Its down at my unit at the moment, I can see if I can get some photos of it for you?
nigxl
Nice one Thanks Adam, will PM you my e mail address.
vulgalour
If you're not fussed about keeping sealed beams (which I assume this is still on), you can get halogen compatible headlights easily and cheaply from that there eBay. You want a pair of 7" units and you should find the aftermarket ones are all generic fitting. The main difference really is the lens shape and material so decide if you want a modern flat plastic look or an older domed glass look before buying.
nigxl
If you're not fussed about keeping sealed beams (which I assume this is still on), you can get halogen compatible headlights easily and cheaply from that there eBay. You want a pair of 7" units and you should find the aftermarket ones are all generic fitting. The main difference really is the lens shape and material so decide if you want a modern flat plastic look or an older domed glass look before buying. I'm happy with whatever as long as it fits Thanks
nigxl
New stuff arrived.
nigxl
Glad I decided to buy new needles.
nigxl
And so it begins: Before And after So there it is, a step by step guide to rebuilding HIF4 SU carbs and I ended up with hardly any bits left over .
