hopeso
Nov 28, 2016 22:01:47 GMT
Not really a retro question as such but I have a mind to purchase an Audi A4 1998/1999/2000 1.8 SE. However I can't find a forum such as this one that deals with the A4. The Audi forum doesn't seem to have much traffic. Anyone on here run one or has in the past can point me out what to look for. I am in Northern Ireland so the pool of cars available is not that large so may have to travel for a good one. Budget is a grand.
BT
Nov 29, 2016 19:13:17 GMT
Personally I would avoid the 1.8 and try to get the 1.9 TDI. I have had a few of the 1.9 versions and have been very happy. I am very fond of the Audi brand and the 1.9 in itself. Excellent economy, pokey and just generally a good engine.
The 1.8 in the turbo form at least suffers very badly with oil pressure issues. Small deposits of gunk get into the end of the pick up pipe and block the strainer and as a result cause a drop in oil pressure. Usually it's just a case of dropping the sump off and cleaning out the pick up pipe, however in the A4 it means either the engine has to be lifted out, or the subframe has to be dropped down, the way the sump is in the A4 it can not be removed because of the subframe. You can get at it from the front but it means rad and air con all has to come out along with the smal panel and everything else. If that is a problem with the non-turbo I don't know, but for that fact alone and having had to deal with it I would go for the 1.9TDI every time.
hopeso
Nov 29, 2016 22:06:51 GMT
Thanks for that. Just the sort of information I am looking for.
BT
Nov 29, 2016 22:48:36 GMT
Also check the dash pods. Audi of that era are prone to having dead pixels in the DIS. They also suffer gauge faults with almost anything. I warned a good friend to check this when he bought his A3. He didn't notice the huge giveaway that the Rev counter wasn't working and once I had picked him up off the floor he told me the repair bill was over £300 although that was a few years ago.
Due to them suffering with dash faults people like to replace the clocks with clocks from another vehicle, when they do this they tend to buy lower mileage clocks so do check the mileage as a lot of the once I've checked in the past have got discrepancies with the mileage.
hopeso
Couldn't find a good car local to me. Every car I have looked at had been worked to death and needed work. Plenty over 100 miles away but nothing that made me want to travel for 2 hours just to check it out. Most Audi a4 seem to have over 200,000 miles on them so they are durable but quite possibly worn out.
However whilst looking at gumtree I found very local a Volvo S40 1600cc xs model with a full years MOT, recent new exhaust and 4 fresh tyres and a full service history too. Cheap at £475 but I am well pleased.
