sleag40
I've no longer space for any more!
May 23, 2019 20:15:18 GMT
Didn't think I was gonna get back on this until the weekend, but managed to snaffle a couple of hours on it this evening. Rear valance fettled up, zinc primed on the back, and tacked on. Also plug welded the valance to the lower rear quarters. I'll get it fully welded next time, hunger got the better of me this evening.
1994 Volkswagen Polo G40 1992 Volkswagen Polo G40 1988 Vauxhall Cavalier GLi 1977 Vauxhall Cavalier GL 1967 Lambretta SX200 1966 Lambretta TV200 1964 Lambretta LI150
May 23, 2019 20:45:54 GMT
Now your sucking diesel
sleag40
May 25, 2019 17:52:29 GMT
Indeed, its getting there now. Valance now welded, tidied up and zinc primed. With that done, the driver's side rear door came off so I could sort out the gap between the arch repair panel and the new outer sill. I'm gonna finish off the welding on the front part of the wheel arch + top of the sill next, then hopefully get the spit assembled on Monday. I think I may have overestimated the amount of welding gas required - I've used about 15% of it so far!
Last Edit: May 25, 2019 17:56:38 GMT by sleag40
teaboy
Make tea, not war.
May 25, 2019 18:22:18 GMT
Nice work pal, it’s really coming on.
sleag40
May 27, 2019 11:17:08 GMT
Nice work pal, it’s really coming on. Thank you kindly! Most pleased with recent progress. Offside sill now finished off The spit is now assembled, hopefully I'll get some bracketry made up and get it all attached this afternoon.
May 27, 2019 17:19:06 GMT
Looking good
sleag40
May 27, 2019 19:09:27 GMT
Cheers! Bracketry now completed - used a bit of box section at the front in the bumper bracket holes. Doubled up some 2mm plate for the rear - again using the bumper mount holes. Everything was then aligned and tightened before starting to wind it up. Seen here with the axle stands removed, and a bit of a tilt on. Next time, I'll wind it up enough to roll it right on its side - hunger ended the session again.
1988 Mk2 Cavalier 1.8GLiMercdan68
@forddan68
Club Retro Rides Member 68
May 27, 2019 19:16:29 GMT
Fantastic update, this car is really coming along great
May 27, 2019 22:40:03 GMT
Really good solid progress
Keep an eye on the bolts on the rotisserie. The ones clamping round the open box section. I've come unstuck where it squashes it surprisingly easy
sleag40
May 30, 2019 18:17:07 GMT
I've only wound it up a few inches so far - I may need to drop it back onto the axle stands so I can go up a notch on the pivot points. Even so, it made plug welding the bottom of the rear valance easier. Next on the to do list is to make up a jig to ensure that the spring plates go on in the correct place once the chassis rails have been repaired. After that comes the utter joy of cleaning all the sealant, paint and rust off the underside so it can be repaired/repainted + resealed.
May 30, 2019 18:23:17 GMT
That makes it easier to work on! nice spring pans but pretty much the same as all Cav mk2s! I used to find neat cellulose thinners sprayed on neat over the underseal used to soften it up a treat
May 30, 2019 19:05:12 GMT
upper spring perch not looking in its finest flush of youth :/ i have to do mine on the silver gte. nasty area too as theres a Z plate which spans the chassis rail above it to the boot floor.
sleag40
Not much time on this recently, but I came up with this from a few bits of scrap. It bolts in tightly to the rear beam mounting point, and accurately indicates where the centre of the spring plate should be. As an added bonus, when the bend is redone the other way, it works for the other side too.
sleag40
Stole a bit of shed time this afternoon - the nearside spring plate now resides in the pile of jettisoned junk by the door. Once all the rotten metal was cut out, a piece was fashioned to repair the inner section of the leg. And that's as far as I got today. New spring plates should be here by next weekend, so theres plenty of time to ensure there is some decent metal to weld them to.
Last Edit: Jun 2, 2019 18:13:49 GMT by sleag40
sleag40
Been fishing + done a bit of gardening instead of toiling away in the shed this week. The arrival of these convinced me that it was time to get back on it. The piece made at the weekend was tacked in Then fully welded, and zinc primed. Got half way through making the outer chassis leg piece before I had to vacate. I'm making this out of 2mm sheet, and its obviously a lot more difficult to form into shape but should have it ready to mount the new spring plate at the weekend.
rickygolf83
Scotland
Mk2 Golf 8v & 16v, VR6, Nova Antibes, Mk4 1.8t & mk4 Gt Tdi 130
Nice update, looking forward to seeing how you tackle the spring plates and the end result
must be a dream to roll that sucker 90 deg and avoid upside down welding
i know vauxhall used that textured rubberised underseal in high impact areas, but it makes you wonder how longer the cars would last if they had top coated the underside in body colour
Brigsy
Epic progress, looks like its coming together great
820
Great work, I have owned a couple of Mk2's over the years, a saloon and hatch both good cars that felt solid on the road. Got a soft spot for these so its nice to see so much dedication going into yours.
sleag40
Not really my day today - first up, my big "working under cars" lighting rig has stopped working. Not the worst thing that could have occurred, but still a PITA (It's been on its last legs for a couple of weeks now). The outer chassis leg repair piece was finished, then welded in. I was just about to reach for one of the new spring plates, when I noticed that further up the chassis leg, near where it is spot welded to the floor, the metal looked a little dodgy. After hitting it with the knotted wire wheel, a couple of tiny holes appeared about an inch below the joint with the floor. I had to cut it out, and it was pretty awkward to do that due to its position being partially obscured by the inboard wheel tub. No big light means no decent pictures, (I'll hopefully get it sorted tomorrow) but the rest of the day was spent cutting out the poxy section of chassis leg, then making up this piece to replace that which has been removed. Hopefully I'll get that welded in tomorrow, then the spring plate can go on - completing this side of the car.
