Jan 12, 2017 21:33:36 GMT
Last Edit: Jan 12, 2017 21:37:01 GMT by mattmk1
Impressive stuff.
Of course if it was me, spoon and face direct interface...... bypass the middle man.
Jan 13, 2017 14:04:26 GMT
Interesting Go on
Caravans are cool
Jan 28, 2017 18:22:20 GMT
Cool are you making the moulds too?
Jan 31, 2017 21:45:26 GMT
Brilliant mate,
What chocolate do you use? I've tried milky bars and galaxy etc but they wont seem to properly harder/cure.
VW nut 1984 MK2 golf type 19e
Feb 10, 2017 18:25:25 GMT
Cool are you making the moulds too? Not yet but it would be good to invest in a vacuumer former, wouldnt take too much
Feb 10, 2017 18:30:56 GMT
Brilliant mate, What chocolate do you use? I've tried milky bars and galaxy etc but they wont seem to properly harder/cure. Best locally available stuff is ASDA cooking chocolate... its got the best cocao butter content. I now use anything labelled as couverture, I bought 1kg bag from Home Chocolate facotry its about £5 a kg, but worth it The hardest part is fine tuning the tempering process, in order for the correct type of crystals to form (gives a glossy finish and increases melting point) you need to heat the chocolate, I split into 1/3 & 2/3 then cool one part, reintroducing to bring down the temperature and create the desired finish
