Jan 16, 2019 21:14:09 GMT
This is going to look stunning when finished and a credit to you, I hope you bring it to the UK at some point, I may then get to see it in the flesh! Cheers. I may take it to the UK but it may take some time as doing holiday trips in the summer, i prefer the MG i think we all are hoping to get our greasy eyeballs on this one when its done...there would certainly be a warm welcome in cornwall if you make it this side of the channel. i'm sure i can be pretty certain in the assumption that your english is perfect compared to 99.9999 percent of native english speakers dutch would be. my late step-father was fluent but he was definitely in a minority. how soon before it hits the road now?? Thanks Strikey. The Rover will hit the road when the salt is gone. I was working on my daily Rover P5B this week due to the MOT and i can see on this Rover what salt does with polished aluminum Did some more work to the Rover. All SS trim on the body and door has been fitted and also all the door panels but did not make any pictures. Nex job was to fit a radio. Am not a big music fan and i believe it does not make sense to fit a expensive radio to a classic car so i fitted a cheap modern radio which i had. It will be fitted in the center glove compartment. This is not deep so the radio has to point down a bit. Made a cardboard template and copied this to a 1mm SS plate and bended this in the right shape On the front i glued a thin layer of foam followed by a layer of black vinyl I also had to fit a speaker in the passenger area under the front parcel shelf. Made a bracket out of SS plate and made a fair number of holes in a piece of vinyl Glued the vinyl to the bracket and fitted the bracket with speaker to the parcel shelf Checked my daily P5b for the MOT. Put the car on axle stands, removed the wheel to check the brakes and suspension. All looked well except for 1 steering ball joint rubber that was perished. but i have a few new ones and one was quickly fitted Checked all lights, heater fan, window wipers, washer horn ect and there was 1 fog light not working which was replaced. Thats it for now Peter
Jan 22, 2019 18:04:41 GMT
The daily P5B passed the MOT test. The tester found the rear direction indicator glasses not amber enough (a bit too white). Luckily he had 2 orange bulbs which were fitted and everything was oke. I was very happy because it is wintertime now and last week and this weekend i checked the car outside but now its a bit too cold to work outside It really is amazing how well this car behaves. Very reliable and hardly ever needs repairs although it living outside Peter
Last Edit: Jan 22, 2019 18:07:44 GMT by petervdv
Was on holiday for 1 week and received a parcel from Auto electrical spares with a oil pressure sender, a lot of bulbs and some fog lights some bulbs were not easy to find locally and AES had the Original Lucas code mentioned on their site which matched with the work shop manual and althought packed in Lucas boxes all had low prices. Also ordered a spare distributor cap and some 5 and 10 A fuses which were gone out of my box of fuses whilst installing and checking checking the electrical system. One of the bulbs not easy to find was the underbonnet bulbs which are in a plastic housing and therefore have 2 contacts underneath The bulbs were fitted and i adjusted the switch and the lights are working Some festoon bulbs also were in the package and after finding 4 unmarked housings which were cleaned and the 8 replated parkers were found and all 4 were fitted insode the SS trim with a bit of Tectyl Also found some piggy back connectors which i had never seen. These can be very usefull with roadside repairs to do temporary instelments or for testing purposes One of my front fog lights is not working. It is a Lucas sealed beam unit and its not easy to get a replacement. Used replacement go for Euro 30,- to 60,- with the remark "function not checked" so it could easily be not working also. AES had a a Wipac 5,5" light set for Euro 35,- which makes more sense. These are not special fog lights but have normal halogen bulbs and they can be removed from their housing and fit into the Rover ring I like the Original glass better then the wipac one but do not want to pay silly money for a used example Found out that the electric fuel pump is still leaking a small bit. I have ordered a new one so fitting this will be the next and one of the last jobs Peter
what size are those original lamps?
what size are those original lamps? These are Lucas FT6 sealed beams and the largest diameter is 144mm Peter
somewhere i have a box with some old sealed beam units in it , not sure exactly what though. i broke a toe yesterday so clambering through my "storage" will be out of the question for a day or two but when I'm more mobile i will try and have a look to see what i can find for you. i would have thought an ingenious fella like yourself would have been exploring cutting the lenses off both types and swapping them over? just a thought.
Would be nice if you could have a look and i am willing to pay for it. Trust someone fron the RR forum much more then someone from Ebay. Have thought about interchanging glasses but the sealed beam is an entire glass unit so no metal reflector and a glued lens to it like the Wipac one. I do have 3 sealed beams that do not work so will have a try replacing the lenses
Peter
if i have anything you would be welcome to them (forum karma). if you have a dead sealed beam unit spare , get yourself a cheap continuous rim diamond blade for a 115mm grinder and have a play to see of you can create a lens?
if i have anything you would be welcome to them (forum karma). if you have a dead sealed beam unit spare , get yourself a cheap continuous rim diamond blade for a 115mm grinder and have a play to see of you can create a lens? Cheers Strikey for the idea of the diamond cutting disc. In the plastic storage box of the grinder, i found an unused diamond cutting disc and managed to cut the "reflector" os the sealed beam. It is a cutting dic with cut outs which did not make a very smooth surface but it was good enough. Used a good safety glass and a breath mask as chunks of glass come off. Used a diamond covered stift in the Dremel to clean up the edge of the lens Have an old small electric kitchen oven and used this to heat up the Wipac light unit to split the metal reflector from the glass lens which went well Had to cut a small piece of the Wipac reflector and then it fitted well in the Lucas lens. Glued the Wipac reflector into the Lucas lens with 2K glue and fitted the lens /reflector to the ring with some clips after putting some Tectyl on it. Next job was to fit a Facet solid state fuel pump. I had ordered it with a straight output and this was not handy so had to order a 90 deg ones Made some brackets of SS sheet so the pump can be fitted underneath the car without drilling additional holes It is pretty crowded there as the Rover has a cable opered reserve tap for the petrol. Next job is to paint the aluminum plate black on the boot which holds the number plate and the jack but i want some higher temperatur for that. Thats it for now Peter
darn, i had a good idea for once!! with a continuous rim blade you would probably have achieved a cleaner cut but at least the theory worked.
Mar 16, 2019 16:50:29 GMT
Not much done on the Rover. The hobby time was used to clean up the parts shed. As the Rover is nearing completion, a lot of spares have to go. As these cars are mechanically very solid, there is not a huge demand for spares and in Holland there are not that many cars so a fair bit of parts were "sold" as scrap metal. The shed is rented and it does not make sense to rent it only for a bunch of spares I had approx 20 crates filled with smaller parts and after sourting, 5 are left filled with spares and 15 empty ones Also have 3 sets of rims. The daily Rover has Jensen alloys which i like very much so i also have a set of these alloys for the project Rover and also have 2 sets of the Original Rostyles in decent condition which i will keep. The Jensen alloys for the project Rover need some work but are in pretty decent condition but require some polishing and black paint I started working on the steering wheel of the project Rover. There is an Original one fitted but this has a diameter of 40cm and as i am 2.00 meter tall, on long journeys, i would prefer a smaller one. The large diameter was usefull on the early 6 cilinder models where PAS was an option but on the V8 models PAS is standard. There are no aftermarket steering wheels for the Rover and i would like to retain the horn ring which has a beautifull Rover sigh on it. The idea is to use the Original centerpiece , shorten the arms, make a new steel rim and cover this with walnut veneer. First step was to remove the plastic or bakalite from the steering wheel and grind of the rim Figured out that reducing the diameter with 6cm would make the situation much more comfortabel so i cut a piece of the rim and tacked the rim on the shortened arms. Underneath a picture of the bare wheel on top of an Original steering wheel And trial fitted the modified steering wheel to my daily Rover It still looks right and improves comfort a lot so i will stick to the 6cm diameter reduction. Thats it for now Peter
Mar 16, 2019 16:59:28 GMT
who else would even think of doing that??
Mar 29, 2019 19:36:06 GMT
who else would even think of doing that?? Did some more work on the steering wheel. The Original steel base of the rim is made of round steel but this is not suitable to glue the veneer on. So i wanted to make the rim base out of f 10 x 10mm steel. Making this round is not so easy so thought about making it out of 5 pieces of 2mm thick steel plate. The disadvantage of this option was that i had to buy a whole sheet of 2 x 1 m. Another option was to make a walsh. Had a few old bearing, some steel and a bearing puller and made a walsh. It works very well and soon i had a neat round piece of 10 x 10mm Welded the 2 ends together and made a 45 deg edge to the inner rim Made a jig for welding the spokes to the rim and welded The veneer is 0,6mm thick and very fragile so i glued 2 sheets together which also reduces the cutting and number of gluing steps from 50 to 25 Made some cutting jigs out of 4mm aluminum and started cutting pieces. The pieces are wider and the overlap is sanded of after glueing Some gluing pictures. The first layer of veneer is glued with epoxy glue to the steel and then white wood glue is used And the steering wheel after each edge has been covered with a layer of veneer Thats it for now Peter
Last Edit: Mar 29, 2019 19:40:55 GMT by petervdv
820
Exactly the word I was repeating in my head as reading. Brilliant work, you make it look too easy.
That's rather mind-blowing. John
eurogranada
Amazing!
Cheers guys! Did some work on the steering wheel. After lots of glueing sessions, the thickness of 20 and 22mm were achieved. No pics of those. Then with 80 grid sandpaper sanded the square rim to aa round rim. As expected the layers could be seen and i wanted to add another layer and try to glue it onto the now round rim. Took 2 identical veneer sheets and cut out 2 moon shaped pieces which were eachothers mirror images And connected the 2 pieces with special thin tape Then ordered a 10 inch trailer innertube and used this as a clamping tool for the round rim. This would have been impossibel to do with clamps On the picture underneath you can see that the veneer nicely wraps around the rim And a picture of the last veneer layer after the glue hardened Then with a sanding paper grid 80 and a suitable tube i made the notches into the back of steering wheel rim All notches done Then took some sanding dust with wood glue to fill up some cracks Thats it for now Peter
Peter, Why bother starting with an entire car to restore, when you have the talents to build from scratch and/or modify spare parts into better than factory, custom parts? Mind-blowing..., Lance
