Reluctant Sale
1993 K’reg Mk1 Golf 1.8 Clipper Convertible with private plate.
MOT 4 months can give her 12 month at an extra cost.
Body/Chassis
Electric/hydraulic tanned hood fully working. Hood doesn’t leak and comes with its original cover. Rare genuine rear wind deflector. Super reliable Mk1 Golf with every electrical and mechanical part working as it should. Rust free solid shell in rare metallic green and totally original as only few made and similar to the Corrado’s. Factory original colour coded under arches. Complete Bugpack G1 Bush Kit, Polybush front ARB set, pair of rear anti roll bar clamps and clips, polybush rear ARB set and front Spax lowering springs. BBS rep wheels with 7.5” front and 8” rears. With new tyres. New rear wheel bearings and front brake vented discs fitted.
Engine/Running Gear
Bullet proof 1.8 carb engine with uprated manual choke webber carb. Cripton tuned engine when webber carb was fitted. Quick revving and responsive performance. No typical cold start problems with the pierburg carbs. Recently serviced with new plugs, air filter, fuel filter, oil filter, oil, rotor arm and distributor cap, anti freeze reverse light switch, water temp senders, water flange, oil pressure switch, radiator expansion task + cap, Front engine mount, webber carb mount, drive belt and rear exhaust back box. Engine has always been serviced regularly.
Interior
Totally original interior with only little wear on the driver seat. New interior mats. CD player with Bluetooth.
History
Stacks of pervious history, 2 keys - Single key opens all.
Car’s only been driven in the summer and is always garaged over winter. Only covered 2k miles in a year. Due to lack of use I have her up for sale. She is 24 years old and will have a few odd marks here and there.
Picture do not give the car any justice, viewing is highly recommended, please no time waster. Please make contact if you require any further information. Viewing highly recommended.
Contact 07903865177
Location Leicester
Price £4995
www.ebay.co.uk/itm/201791126785?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
Body/Chassis
Engine/Running Gear
Interior
History
Contact 07903865177
Location Leicester
Price £4995
