Feb 15, 2017 13:22:09 GMT
Hi all
Just picked up a 2004 ford ka 1.3 duratec
Smart little ka but has a misfire on cylinder 4 according to my code readers
Changed plugs leads and coil pack and it was still missing
I then have it a few seconds of high revs and it has now settled down to an even tick over with only the occasional miss
Ka had been standing a couple of months and only driven a few miles to mine
Anyone got any suggestions?
Cheers
Toyota HiAce Super Custom Ltd (My thing) Isuzu Trooper (her thing) Audi a4 1999 (boys thing) Toyota Yaris Caravan - (festi thing)
Feb 15, 2017 13:31:07 GMT
Sticky injector?
Nick
Feb 15, 2017 13:39:02 GMT
Could be is that a replace or some injector cleaner?
mk2cossie
Club RR Member Number: 77
Ford ka misfiremk2cossie
@mk2cossie
Club Retro Rides Member 77
Feb 15, 2017 13:54:06 GMT
What state are the spark plugs in? May just want them replacing as well as the coil and leads that has already been done
Feb 15, 2017 14:29:03 GMT
Burnt valve try doing a compression test on it Especially if it's slightly lumpy on idle but once going miss clears up
fad
Feb 15, 2017 14:39:31 GMT
It's cos Jesus hates Ford KAs.
Feb 15, 2017 16:52:51 GMT
Plugs brand new it's getting a lot better every time I start it was hoping for a quick fix still more that usable the way it is . . If i was not aware of it before it got better would probably not nice now
fad
Feb 15, 2017 17:07:16 GMT
My other halfs astra does this after being stood sometimes. Dragging it out by the scruff of its neck for a spirited drive and "forgetting" it has a 4th and 5th gear normally wakes it up.
Feb 15, 2017 17:50:04 GMT
New leads? The metal caps can be troublesome
Feb 15, 2017 20:13:57 GMT
Hi there
I would go with a sticking exhaust valve.
My daughter has had several ka's whilst at uni and all have had a similar issue if left standing for a few months. Two out of three have burnt an exhaust valve. Strangely,both were on number 3 cylinder.
Cheers - mike
Feb 15, 2017 21:33:36 GMT
I think the issue is lack of use so will pop it in for mot and get some miles done.
I can live with the feeling of misfire ap long fuel economy is good
Oh and already fitted new leads
A little thrashing will sort it out I'm sure
Cheers
Bm
Ford ka misfireChasR
@chasr
Club Retro Rides Member 170
Feb 15, 2017 21:59:32 GMT
What brand are the leads? Some leads are horrific. The Motorcraft leads or Beru leads trump the lot for performance and durability but they are pricey! I'd also be tempted to check compression as well. Hi there I would go with a sticking exhaust valve. My daughter has had several ka's whilst at uni and all have had a similar issue if left standing for a few months. Two out of three have burnt an exhaust valve. Strangely,both were on number 3 cylinder. Cheers - mike If that was an Endura engined Ka, not doing the valve clearances on time would cause the same issues if left long enough would cause burned out exhaust valves.
froggy
Feb 15, 2017 22:11:42 GMT
Injector , done lots of these , 2 8 mm bolts and prise the rail up a bit at a time with a bar along the rail . Spin it on the starter and you'll see it spitting unlike the others
Feb 15, 2017 22:17:25 GMT
What ^^^^froggy^^^^ said. Give it fresh fuel and an Italian tune up for starters. Worst case remove and get the injector cleaned/replaced
froggy
Feb 15, 2017 22:42:27 GMT
These are semi sequential injection so at lower rpm the inj fires as the valve opens so the misfire can sometimes only show up at idle if the inj isn't too badly clogged , never bothered trying to clean them as there's plenty of scrap ka,s about . You can move the subject inj to prove it if it sprays very close to the others the fault code will move with it
Feb 16, 2017 19:18:58 GMT
Will look to change injector 4 but not buying brand new seen the price of them!
Feb 16, 2017 19:41:20 GMT
Just had a Google no where near as expensive as I thought 😆
Feb 21, 2017 18:11:03 GMT
Bottle of injector cleaner with a total of about fifteen litres in tank . . Driven for about ten miles in one gear lower than usual (high revs but not thrashing it) all is spot on now!
Cheers 😆
Oh and passed mot today too
fad
Bottle of injector cleaner with a total of about fifteen litres in tank . . Driven for about ten miles in one gear lower than usual (high revs but not thrashing it) all is spot on now! Cheers 😆 Oh and passed mot today too See. Italian tune-up every time!
Feb 23, 2017 20:27:49 GMT
It's getting better each day! 😆
