Oct 31, 2018 19:24:22 GMT
removed rear carpet as this just slides about every time i go round a corner replaced with 5mm rubber matting removable rear brace fitted between wheel arches, the only function of this is to help stop stuff sliding about
Last Edit: Oct 31, 2018 19:25:22 GMT by vauxviva
Oct 31, 2018 23:38:53 GMT
this is getting cooler and cooler! those lamps, LED is the bomb. And that console takes the biscuit. What is it from, the rev counter?! Thanks The rev counter is from a 1980's bayliner Capri speed boat Looks factory. Top work
it been a couple of months since i bought the led headlights but i put them to one side as i knew it wont be a easy job fitting them but i have now started work headlight bezels need the hole enlarging to fit the slightly bigger light i need to make totally new headlight mountings because i can no longer mount them on the plastic bezels as in previous posts due to the extra weight of new lights i don't think the clear plastic lenses will look right, too modern and will look out of place, so i bought some new Unipart headlights so i can use the glass lens i have had to modify the led light for the glass lens to fit but i think it looks much better than the clear lenses after the headlights are fitted i have a autoplas rear louvre to fit on rear window which i will make quick release so i can choose to have it on or off also got some new front discs and pads to fit
Last Edit: Mar 10, 2019 19:21:32 GMT by vauxviva
Feb 10, 2019 23:56:44 GMT
Just read through this entire thread, the work and effort it your metro is nothing short of amazing! Love these little cars had a gti when I was 17 and a mk2 which now belongs to my brother, which is stance and banded with 10k on the clock.
Keep up the good work man definitely following it now.
Thanks confusedbear been working on the headlights for a month now, its been a time consuming job getting the headlights lined up in the right position made harder by the limited space i have to work with, they only just fit new adjustable headlight mounts have been made headlight mounts are now finished, just got the bezels to finish off headlight bezels are being modified to accept the bigger lights, hole has been enlarged and lip has had to re remade while the front is stripped I'm going to repaint the engine bay with another coat of raptor, also paint the cam cover and inlet and re wrap/tidy the wiring loom
Last Edit: Mar 10, 2019 19:21:53 GMT by vauxviva
headlights finished engine bay, inlet and cam cover painted, loom rewrapped in black cloth tape
Auto-Plas rear louvre fitted custom made steel mounting brackets, quick release so easily removed louvre plastic was faded so its been painted so i don't have to keep applying trim gel two pack plastic primed, painted black and matt lacquered mg spoiler repositioned and modified to allow the louvre to fit the top of the louvre tucks under the spoiler so top brackets are not needed
Looks spot on. Great rear quarter shot there
14 Audi A3 Sportback - Easy driver 05 Audi TT MK1 3.2 DSG - Damn quick 73 Triumph 2000 - Needs work 03 Range Rover 4.4 V8 petrol. Had to get it out of my system.
rickygolf83
Scotland
Mk2 Golf 8v & 16v, VR6, Nova Antibes, Mk4 1.8t & mk4 Gt Tdi 130
Cracking wee car !
Read a bit when the thread when you first started it and caught up this morning!
Hope to see this at Goodwood or the Gathering this year!
Feb 26, 2020 20:06:43 GMT
Feb 27, 2020 18:05:45 GMT
i have made some more louvre brackets, i wasn't happy with the first set i made the new brackets are smaller and are less noticeable when i don't have the louvre on old brackets new brackets
mat88
Yorkshire and The Humber
Feb 28, 2020 13:10:23 GMT
I've never seen a metro I wanted (other than the old mg I stole the engine from for mmy mini years ago). But I love this. It's brilliant!
Bookmarked!
Mar 30, 2020 14:40:56 GMT
mat88 Thanks for comment mike satur mgf fcc coilover conversion kit fitted two rear mgf units fitted to the metro front these are made for mgf but fitting to a metro is possible as the k series metro and mgf share the same subframe with a few minor differences fitting this kit was straightforward but i modified the top arms to give me extra camber adjustment my old hydragas setup, individualised valves, gaz adjustable shocks new mike satur coilover conversion kit painted with aerosol stonechip before fitting old suspension removed and subframe area cleaned to remove all the old grease from top arm new ball joints fitted porta power used to give clearance for the new turret, only needed a extra 5 to 10mm
Last Edit: Mar 30, 2020 14:46:33 GMT by vauxviva
Apr 15, 2020 17:46:27 GMT
glenanderson
Club RR Member Number: 64
Apr 15, 2020 17:56:56 GMT
Clever. Details like that make all the difference.
Apr 15, 2020 17:58:15 GMT
That's well cheeky that is. Luv it!
SamV8
South West
Apr 26, 2020 19:44:42 GMT
That coil kit looks a smart bit of work
Apr 27, 2020 20:20:08 GMT
Love the badge creation
I love the little details on this, I would never have guessed it started out as a too modern looking imho mk3 if I hadn’t gone back to the first page.
Hopefully I’ll get chance to read through from start to finish.
I think I’d missed the thread completely although I recognise your twin aerials so maybe that photo was in another thread.
Absolutely love this car.
Very nice build...
