Feb 22, 2017 12:28:17 GMT
Any rotary guru`s out there, my grandsons RX7 as just started playing up its not firing on the top spark plugs, there is a good spark so its not electrical I put new plugs in and it made no difference , put some old plugs in and they were getting wet so its getting fuel, With the new plugs in you can pull the top plug leads of even with the engine revving high and it makes no difference, what it does do now and didnt before it started playing up is backfire when revving high , at one point it made a knock and a clatter then the noise went away Any advice welcome as i cant find any answers on the no pistons forum Thanks Dave
Feb 22, 2017 12:49:47 GMT
You say there is a good spark, is this on the leading and trailing plugs? As you also say it's not firing on the trailing (top) plugs
Have you swapped plug leads from leading to trailing (at both ends) to eliminate the leads? Have you checked the coil packs?
Feb 22, 2017 16:50:13 GMT
Hi thanks for the reply , there is a good spark on all the plugs so no problem with coil packs or leads , its just not firing on the top plugs no matter how high it revs, I put new plugs in just in case they were breaking down makes no difference , think I will do a compression test see what that shows Thanks Dave
Feb 22, 2017 20:36:32 GMT
Stock ECU? Are you on FDUK? Might get a better response, I've not had an FD for about 7 years now and have forgotten most of the bad stuff and only remember the noise and power.
lightyearman
GYJDM - Grimsby based Japanese car club - Find us on Facebook
Feb 22, 2017 21:19:50 GMT
My 13B is an NA injected unit from an FC RX7 but I had similar problems at one point, after changing both coils, rotor arm and dizzy cap it turned out two plugs had completely died and one was weak as a weak thing. 4 new plugs and it was sweet as a nut.
'89 Honda CRX siR Glassroof Flint black fully restored track beasty '90 Nissan S13 Pignose - pass the mig wire '86 Mini - matt orange, 13" Wellers, Project 2018 '97 LDV Convoy home built camper/tramper van '04 Saab 9-5 Aero HOT. Anyone want it? '91 Honda VFR400 NC30 17,000 km from new '87 Honda XR80 4 stroke baby crosser '03 Mini Cooper S - honestly, they are fun... '15 VW T5.1 LWB daily brick
ian65
Feb 22, 2017 21:40:15 GMT
what year is the car? is it running a carb or fuel injection? Dizzy or crank angle sensor? The trailing plugs mainly clean up emissions... it should still run ok on just the leading.
Last Edit: Feb 22, 2017 21:50:26 GMT by ian65
Feb 23, 2017 10:50:47 GMT
Hi Ian its an 89 (G reg ) fuel injected with dizzy, he had to use it yesterday its still the same totally gutless i pulled out one of the new top plugs this morning before going to work and it looks like its not been burning totally clean in the middle with just a trace of engine oil on one side so maybe its not getting enough fuel
