rodney
Mar 17, 2017 15:18:55 GMT
so I'm having random nutty thoughts , i might be buying a 1999 jag xkr supercharged coupe at a cheap price if all goes well ,
if for any reason i don't stick to my plan of fixing it up then id love to fit the 380 bhp v8 into something ,
has anyone done a jag swap like this and know much about the wiring side?
I'm assuming ill need more than the loom ecu and key chip?
or is there a aftermarket managment that would work well? its an auto so ill take the box and managment for that out too
froggy
I looked at this a few years back and as far as I could see you would need to keep the abs system to get it to work with the wheel speed sensors for the gearbox /traction control to function . Returnless fuel system as well so needs the pump assembly from the tank. Probably why it's not a very popular engine for transplants
alecf
Mar 19, 2017 12:59:11 GMT
Here's one in the back of a comp safari racer. At this stage was mated to a 4 speed auto with manual paddle shifts now has a quaiffe sequential.
ian65
Mar 19, 2017 17:55:51 GMT
check the engine number to see if this is a Nikasil engine or a warranty replacement.... 1999 cars were Nikasil and suffered plenty of engine problems... also, get a blow-by test done on it.... these supercharged V8's are complex engines, 32 valve quad cam... they have a well known issue with timing chain tensioners disintegrating / timing gear issues and also water pump impellers breaking up.... A good engine is a joy ( although demands proper and regular maintenance) but a tired one will smash a hole in the bottom of your bank account and drain it in no time. What I'm trying to say is make absolutely sure the engine is good with a maintenance record backed up by a paper trail before you go to the expense of an engine swap and stand alone ECU's etc.
fad
Mar 19, 2017 17:57:33 GMT
check the engine number to see if this is a Nikasil engine or a warranty replacement.... 1999 cars were Nikasil and suffered plenty of engine problems... also, get a blow-by test done on it.... these supercharged V8's are complex engines, 32 valve quad cam... they have a well known issue with timing chain tensioners disintegrating / timing gear issues and also water pump impellers breaking up.... A good engine is a joy ( although demands proper and regular maintenance) but a tired one will smash a hole in the bottom of your bank account and drain it in no time. What I'm trying to say is make absolutely sure the engine is good with a maintenance record backed up by a paper trail before you go to the expense of an engine swap and stand alone ECU's etc. Unless he found the donor in a hedge... then crack on!
ian65
Mar 19, 2017 18:00:27 GMT
good luck with that then
Mar 22, 2017 21:37:18 GMT
As far as I'm aware they're night impossible to get running happy without everything from the original car, and even then can be iffy.
£1200 or more for an emerald ECU setup will see it running on its own, but it's not a cheap option.
A BMW M62 or Toyota 1uz-fe would fit the same bill, be less of a headache, and be cheaper.
rodney
hello people , the car is cheap and I know the car , I think it needs a coil pack and possibly a cat , its sitting on a mates drive waiting for the logbook to come back before I part with some money ,
rodney
also due to the standing for a while , the few issues and the fact a mate has it its a very very cheap car
gavs1
Do it bud, as long as you keep the odb port so can check for codes as you go can't see you going wrong
Have you measured to check it fits as they are very wide ?
rodney
Apr 17, 2017 19:31:45 GMT
well ive gone and bought a 1800 sierra , I'm thinking the lexus ls400 engine is the way to go on that , still waiting on the jag paperwork before I can commit to the jag
rodney
this project may still be in the pipeline , I'm struggling to find a cheap lexus ls 400 for a donor for my sierra so I may still take the plunge with the xkr , not sure if there is any parts to convert to manual though
I thought the jag v8's are the same family as the v6's, in which case can you not use a s type V6 manual box?
rodney
Jul 11, 2017 18:57:19 GMT
hmmm....thats something to look into
Jul 12, 2017 22:06:59 GMT
Click picture for more
