VW/Audi Central locking Vacuum pump, VDO part no 443862257a £20
Apexi VAFC 2 Vtec Air Fuel controller £120
also, Custom plug and play loom for the VAFC2 for DC2 ITR, might fit other OBD2a hondas £40
Proform valve spring tester 0-300 lbs SOLD
Rover V8 Jetronic 4cu ECU, removed from a TVR, has richer mapping than std, £120
Rover V8 Steel Rocker Arm assembly, reputed to be good for 7000rpm unlike the standard aluminium numbers according to 'How to Powertune the Rover V8' book, £150
Rover V8 ARP Head stud kit, 20 bolt NEW condition SOLD
FSE powerboost valve adjustable fuel pressure regulator NEW no box, for 5/16 or 8mm fuel hose connections, £30
MSD Ignition lead crimping tool, produces very good crimps on 8mm or 8.5mm ign leads, needs a vice to operate, NEW, £18
Philips +30% brightness HB4 bulbs £3 each
Speedo cable repair kit, 120" long inner cable that you cut to length and crimp on the supplied end with the supplied crimp tool £15
Jag XJ12 Rear brake pads also fits others see pic, SOLD
Metric Ratchet Spanner Set NEW, very similar in looks and quality to the Halfords Pro line ones, £25
DEI Reflect a gold offcut, approx 12" by 24" £23
Motul Gear 300 4 x 1 litre bottle available, £10/bottle
Thermotec heat barrier self adhesive shield 12"x24" part no 13575 £20
Thermotec Micro louvre heat shield, good for making turbo heat shields or similar, 1 foot by 2 foot, part no 11710 £40
Jag XJ6 4.2 ecu bosch 0280001109 £40
All items can be collected from near Leeds or posted at cost, heavy stuff will be £9.50 parcelforce, light stuff 3 quid ish royal mail.
