Apr 18, 2017 21:26:12 GMT
Spent a little more time sorting the door aperture out before doing some final offsets / measurements & checks Took the door back off and removed the sill & B post The old sill section was open at each end so just used to fill with all the curse word thrown at it by the wheels To combat it happing again I welded blanking plates to either end of the new section Sill refitted and commenced welding up carefully to avoid any heat distortion A post repair starting to go in Then the B post and a clean back of the welds - the door was refitted several times to ensure the aperture gaps remained consistent Once cleaned up I then refitted the door and the rear shroud - all ok so off the came again and I put the dressed welds / bare metal into construction primer I have some repairs to undertake to the bulkhead in the morning and then the car can come back off the stands and be turned around in preparation for the structural repairs on the nearside
Last Edit: Apr 18, 2017 21:40:25 GMT by Deleted
Apr 19, 2017 21:40:45 GMT
Last Edit: Apr 19, 2017 21:41:39 GMT by Deleted
vulgalour
Club RR Member Number: 146
Apr 19, 2017 22:43:17 GMT
Absolutely right to do that hinge box repair, it would have been horrible to leave it in with the high quality of the rest of the work. Sometimes the customer isn't always right
eurogranada
Absolutely right to do that hinge box repair, it would have been horrible to leave it in with the high quality of the rest of the work. Sometimes the customer isn't always right What he said! +1 Why even bother with the rest of the work if you'd be willing to leave such an ugly repair behind... Do it right or don't do it at all is my motto and from your own response you live up to that as well.
Apr 20, 2017 20:53:56 GMT
Last Edit: Apr 22, 2017 20:56:59 GMT by Deleted
Apr 22, 2017 20:55:10 GMT
Last Edit: Apr 22, 2017 20:57:42 GMT by Deleted
Apr 23, 2017 20:10:40 GMT
B post grot removed, repair sections tacked in and then refitted temporarily to the car Then hung the door which initially fitted ok to the rear but very poorly at the front Spent several hours making adjustments to the sill, A post repair & B post Slowly making progress but still way of alignment in both the aperture gapping & side profile The lower 300mm of the rear shroud will be remade both sides are suffering from corrosion and are weak at the point the rear wing bolts up to it Crease to the lower section of the door was throwing the side profile & alignment out But eventually I got to the stage where with the bottom hinge drilled and bolted up to the A post repair that the door hung / opened and closed close to tolerance - still some further adjustment to be had but I need the sill welded in and the A & B posts tacked to the sill before I can achieve the adjustment - Sports roadsters of this era are notorious for poor door & panel fits - getting them right at the restoration stage just take a lot of patience More to follow tomorrow
Last Edit: Apr 23, 2017 20:13:28 GMT by Deleted
Apr 25, 2017 10:19:31 GMT
Door, repair sections & sill back off - blanking plates fabricated & welded to sill ends and everything cleaned up / painted with weld thro' primer - sill going back on Lower section of B post patterned up & repair sections made up With the sill on the B post was trialed for fit again A post repair ready for tacking up Door refitted & along with rear shroud panel and all aperture gapping / door operation trialed / corrected as required With just some very minor areas of welding left to do on the main shell structure the temporary supporting framework between the A & B posts & cross bracing could now be removed This allowed access to weld the rear inner sections around the overdrive & battery boxes - these had been cut to part the rear frame from the centre section when the car was stripped so that everything could be sent for shot blasting I will complete the welding on the frame structure today and can then make a start on the outer panels
Last Edit: Apr 25, 2017 10:22:39 GMT by Deleted
vulgalour
Apr 25, 2017 11:30:04 GMT
It's amazing how simple this looks stripped down compared to a modern shell.
Apr 25, 2017 13:58:30 GMT
Is the slot in the A pillar for a trafficator?
Apr 25, 2017 14:39:01 GMT
To have that kind of patience requires a great deal of knowledge!.....I cannot even imagine, much less see the areas that require the kind of fine adjustments you have been making to the key areas of this cars structure...but the work you are doing will help me key into making better adjustments in my own projects.
thanks for sharing your techniques on some very technical work
JP
Apr 25, 2017 19:54:09 GMT
It's amazing how simple this looks stripped down compared to a modern shell. Yes but it's pretty typical of the period for manufacture - most sports roadsters of the era were based on a decent separate chassis with a body bolted to it - floors tended to be timber ply bolted over a framework - has in this case - vehicle manufacture has moved on significantly since and continues to do so with bodyshells now being of a riveted & bonded construction in some cases.
Apr 25, 2017 20:08:55 GMT
Is the slot in the A pillar for a trafficator? Very much so - the owner has yet to decide if he wants to retain them
Apr 25, 2017 20:18:00 GMT
To have that kind of patience requires a great deal of knowledge!.....I cannot even imagine, much less see the areas that require the kind of fine adjustments you have been making to the key areas of this cars structure...but the work you are doing will help me key into making better adjustments in my own projects. thanks for sharing your techniques on some very technical work JP Not a problem - when working with closing apertures the key is break the task down in separate areas rather than look at a panel that is a poor fit in several areas and thinking that it is going to be a nightmare to obtain a good fit all round - start at the point that is fixed or has little / no adjustment and work from that there - it's not easy has the adjustment to get one area correct may well throw another area out - patience is big factor but working both methodically & logically also helps - I probably need to do a in depth 'How to correct a poor fitting panel / door' in my Body & Paint thread - at some stage
Apr 25, 2017 20:34:40 GMT
Side return on the bulkhead had a few non original bolts through it - I removed them and found that the spotwelds had failed on this length and the bolts had been added to keep the panels flush - so cleaned the panel & flanges up Turned the power up on the spotwelder and rejoined the panel to the flange then welded the holes up left by the bolts Rot to the underside of windscreen mounting - cut out Fresh metal let in & cleaned up Again a weak repair had been made to the bonnet hinge box aperture Cut out and a double skin repair fabricated and let in Aperture holes for previous mountings to the horizontal bulkhead panel Welded up & cleaned back Structural repairs complete Used the airline / blowgun to remove the loose dust - quick mask off of the chassis tube and applied construction primer over the new / reworked areas So I can now crack on with the outer panels Found the body number on the bulkhead - Jowett numbered all of the production runs in this case '630' out of the circa 830 cars built
vulgalour
Apr 25, 2017 20:51:42 GMT
It's nice to see all the extraneous holes disappearing and the car returning to a cleaner original look.
How is the Jupiter going?
How is the Jupiter going? Just back on with it - back injury has restrained me for a week or so but just getting back up to speed - update following
Last Edit: May 8, 2017 19:56:43 GMT by Deleted
With the main structural work sorted I commenced repairs to the lower front sections of the rear shroud With the repairs welded up - I cleaned the underside of the shroud panel off With a multiple of panels to prep - I like to stop of top of the process rather than do one panel at time only to recommence the same process again on the next panel I always try to stage process 2 - 3 panels at a time as this saves with drying times - one can be drying whilst the others are being worked on and I just keep advancing the process in rotation - so next was the underside of the bonnet (which had been the subject of damage via a engine fire) Took a while but carefully removed the support frames so that these could be shotblasted This now allows unrestricted access so that I can prep all of the underside - a couple of edge splits in the alloy need welding up and there are numerous dents / creases that require some careful hammer & dolly work The face side of the bonnet although largely stripped of paint have had a good work over with the DA / P80's Revealing a patchwork of redish colours - the car has been bright red for the last 50 years + however it would now appear that the car was originally a maroon metallic - spoken to the owner and he is all for adopting the original colour scheme - so I am currently doing some research into a paint formula for 'Jowett Maroon Metallic' which apparently is no longer available but I will find a way somehow Meanwhile the rear shroud was treated a session with the DA to remove the last of the paint Plan for the next week is to concentrate on the rear of the car - get the shroud refitted to the steel work - refit the rear wings temporally and work / correct the profiles on the car from the doors back
vulgalour
This is going to look really special in metallic maroon, it looks pretty special to begin with! The latest round of updates have been good to catch up on
