May 13, 2017 19:07:01 GMT
Yes another one - this being my own - very original car 42,000 miles from new - was painted about 30 years ago by the previous owner who worked in a Vauxhall main dealers bodyshop - it's weathered rather well - it's not perfect but it's presentable - owned by me for the last 5 years I replicated the crest of my late step fathers taxi business and put it on the car in his memory - he had a black Javelin for a short while in the business but it was soon repalced by a A60 in fact the mainstay of the fleet were A60's of various guises replaced in later years by Mk 1 Granadas along with Mk3 & 4 Cortinas - there was always some room for the odd stray though (Wolseley Six springs to mind) Anyway back to the Jowett - I just keep it smart enough - it lives outside and I will probably do a proper paintjob on it at some stage but I am in no hurry - there are some very minor areas of weakenss in the panels but you would barely know it - I keep on top it mechanically - it's not a quick car but probably the one car that I ever had the most fun in So like all Javelins 1500cc boxer engine, water cooled, 4 speed cloumn change box, quite quirky in it's own right and has I said a whole heap of fun (I love holding the boy racers up in this) Note the missing carbs that I was rebuilding at the time that I took the pic
Last Edit: Nov 22, 2019 21:11:01 GMT by Deleted
May 13, 2017 21:01:27 GMT
So a big push in-between the rest of my commitments to ready the car for coming season - we are heading up to Peebles in Scotland at the end of the month for the annual Jowett Car Club rally - not put a spanner on it since a year ago and it's done about 1'000 mile since which is not a lot but I like to stop on top of any issues - on the last trip in 2016 the car started to pull to the left - so I pulled the front drum on the offside to find both brake cylinders weeping - annoying because both cylinders were new exactly 2 years ago - I run on DOT 5 fluid so there shouldn't be any issues So 2 new cylinders on the offside and a new set of shoes on both sides at the front Proper brake drums (these are original) and they are very heavy Drums back on, brakes adjusted next on the list was the yolk nut - the one on the nearside had worked slightly loose so I checked both sides - backed them both off, cleaned them up and applied some thread lock before tightening them back up Thing that I love about the Jowett's is the engineering extent that they went to - this is the pin that goes through the top of the yolk - they could have just used a bolt - but no it's a proper bit of engineering complete with grease grooves and thread adjustment (something you expect on a prestigious brand built in low volumes but on a everyday family saloon is another thing) Suspension back together, next on the list was a failing front engine mounting Bit of a fiddle to get it off Well on it's way out New one fitted and one more off the list Next was I had noticed a arcing from one of the ignition leads so I made a new set up Critical to a Jowett boxer engine is waterproof spark plug caps - with the heads at a mid wheel level - you need just the one puddle and without the right caps the engine dies Still a fair bit to do but at least I am getting on top it
Last Edit: May 13, 2017 21:20:32 GMT by Deleted
May 13, 2017 21:40:01 GMT
We did a Dutch rally in 2015 with it Along with annual events we do the annual club rally and Goodwood Revival where the car is on duty as one the official period taxis for GRRC members, race drivers & officials. It's a period event (SWMBO is a very well respected film & theatre costumier so no excuses)
Last Edit: May 13, 2017 21:42:10 GMT by Deleted
May 13, 2017 21:48:41 GMT
First 1.40 mins is the car on Goodwood 2016 duties - vid curtesy of 'Petrol Ped' t.co/sErxA5CMvh
May 13, 2017 21:53:05 GMT
Great Video thank you for posting the link.
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
This looks really nice and the sign writing really sets it off, I didn't realise these had a flat four in them.
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
May 14, 2017 18:25:44 GMT
These cars and your threads really do make me smile.
Love the car, and of course the dress up is perfect.
May 14, 2017 20:40:56 GMT
More done today Oil & filter change - the cartridge type filter being horizontal is a pain though There is a release valve to let the oil in the filter housing drain back to the sump - it's operated by winding a bolt back - said bolt is hidden to the right of the hose / clip in the image - you can only just get on to it with a open ended spanner side on and have to play the trick with a ring spanner on the opposite end of the open ended spanner at right angles in order to loosen / tighten said bolt - in reality it only drains two thirds of the filter housing and the rest ends up all over the crankcase valley has you have no choice but to tilt the housing to draw it out from the engine bay And that's after I have spent ten mins mopping up - I could fit a spin on conversion but I really don't want to - so new filter fitted and refilled with oil Next was plugs & points - note the tide mark on the plugs close to the top where water has previously filled the plug holes - points were also changed Air to the carbs is drawn down this tube on each side of the inner wing - the rubber seal contacts with the bonnet when closed Air is then drawn the hole in the underside bonnet panel which in turn is filtered by the oil bath air filter attached to the nose of the bonnet Filter bath removed Separated Certainly doing it's job - I cleaned the oil out gave the bath & filters a good wash through with a degreasing spirit - reassembled & refitted it Removed - washed through & refitted the breather felts on the timing cover cases Then gave the engine bay a good dosing of gunk and left a while to soak Prior to giving it a good wash off Then before making sure it would restart - I got the airline and blew the plug holes out - otherwise I would not have stood a chance - she runs slightly lumpy so I will put the timing light on it next week and balance the carbs at the same time When I first got the car 5 years ago I replaced the crossply tyres on it there were about 20 years old and had failing / perished side walls on them - I could have fitted radials to it BUT to be honest the car is fine on decent set of crossplys - it prevents you from pushing the car beyond it's physical limits - it's a 55 / 65MPH car tops and although it will go quicker it's simply not comfortable - the engine screams it's nuts off and everything in the car vibrates like mad and it's very. very noisy - the ply's are much fun to drive with and keep you on your toes. So the tyres I fitted were a full set of Waymasters 16" x 550 - done less than 6,000 miles and loads of tread still on them Disappointing then when I found the sidewalls failing on two of them Not be buying them again then - new Avon Tourists to replace them - dropped them off at the tyre centre on Fri and will pick them up in the morning - even more disappointing is the fact that when removed the rear wheels today and found the inner sidewalls on these failing has well - more expense - still tyres are not something that I take risks with - more updates next week
Last Edit: May 14, 2017 20:47:28 GMT by Deleted
vulgalour
Club RR Member Number: 146
May 14, 2017 21:43:24 GMT
Shame about those tyres, pretty much only good for rolling restoration projects around on with those cracks. Interesting to get a more in depth look at the quirks of the mechanical side of things on this car.
logicaluk
May 14, 2017 22:20:17 GMT
Lovley car Bookmarked Dan
May 21, 2017 21:13:45 GMT
More done today - brakes bled and final adjustment, new rubber boots for the nearside front suspension yolk The rocker box stud gaskets were weeping but wanted to check the tappet gaps anyway - so I took the rocker box covers off & set the gaps up Replaced the gaskets on the covers at the same time Simple valve gear All sorted with new stud gaskets Noticed the offside headlamp was condensing / weeping water on the inside of the lens Dropped the lamp out and the lens was parting from the reflector - I cleaned both up and rebonded them together (thay are an original matched pair of Lucas 700's so wanted to retain them - checked the bulbs and the offside main beam was out - although BPF (british pre focus) fitting - halogen replacements are now available - I carry spares so that was a quick fix checked a load of other stuff, lights, set the tickover speed, lubed all the hinges & catches, checked wheel nut torque, tyre pressures etc - then put her up in the air to do the grease round underneath - also had a look over / checked for bolt / nut tightness etc and it's a good job I did - hidden up behind the bellhousing I found this Stabiliser bar for the column gearshift completely adrift Went back on ok and I fastened it up with a nylock Gave the inside a quick clean out, sorted the boot out and checked my spares box - left on the list to do is change the faulty battery master switch and then give the paintwork a good clean up - probably want to do a few runs in it too - before leaving for Scotland on Thursday.
Last Edit: May 21, 2017 21:14:56 GMT by Deleted
May 30, 2017 22:21:14 GMT
Last Edit: May 30, 2017 22:31:58 GMT by Deleted
May 30, 2017 22:47:26 GMT
Sorry to hear of your troubles
May 30, 2017 23:10:13 GMT
An unfortunate end to what looks to have been a lovely weekend! Hopefully you Javelin hasn't fared too badly, and will be up and looking smart again in no time.
vulgalour
May 30, 2017 23:11:25 GMT
What a rotten stroke of luck. Surprised how well the Jowett fared against the modern and at least you have the parts and skill to replace what little is damaged.
May 31, 2017 11:15:17 GMT
Great car - a bit different from the norm in all the little details.
Sorry to hear of your bump -do you think the last round of brake bleeding finished the master cylinder off?
mgmrw
May 31, 2017 15:23:12 GMT
Lovely car. Word of caution w/r abusing the RAC...
the AA are far worse. What broke down in the Rover GTI up above Ullapool in Scotland, some 14+ hour drive from home.
Parts were not available, so AA happily offered to ship the car home without us, so we could finish our honeymoon.
Mistake. Collected the car 06:00am on the Friday, local agent recovery firm who were brilliant.
08:00am driver switch to an exhausted guy who was double shifting & dangerous.
Vehicle arrived home at 16:00hrs on the Saturday, damaged, filthy and by 6 different relay teams.
45 phone calls to/from the HQ team, who even admitted at one point that they had LOST the car for several hours after leaving it in a layby unlocked with the keys in the glovebox.
Zero compensation, zero apologies, and "10% off next year as a goodwill gesture".
So dropped the master cylinder off which is under floor hung to the side of the chassis And stripped it down Obvious wear / grooves to piston Cleaned the housing up and fitted a new seal kit along with a new piston - drained the brake system of fluid to clear any debris within the fluid - system has been on Dot 5 silicone for the last 5 years - rebled the system but they are very difficult systems to bleed of air - for some reason air becomes trapped in the back of the master cylinder - to combat this we filled the master cylinder with fluid and purged as much air has we could from it before connecting it up - we bleed the system a couple of times before getting a pedal - On Keith' s advice (50 years of multiple Jowett ownership under his belt) we left the car overnight - apparently with the fluid reservoir being mounted high in the bulkhead / inner wing corner any traces of air in the master cylinder should find there way out via the reservoir when left for several hours - seems strange but having tried the pedal this morning I would say that we have a result - will road test on the private lane that we reside on a little later. Has Quaggers stated in his post it could well have been the previous round of brake bleeding when doing the front cylinders that finished the master cylinder off - probably drawing debris into it and then the damage to the piston / seal occurring on the drive up to Scotland - but the failure was sudden not something that continually got worse - anyway hopefully now sorted.
Last Edit: Jun 1, 2017 8:28:13 GMT by Deleted
stu67
Pleased you got it sorted, how bad was the grill damage? My grandfather had a Jowett like that when we were kids in the early 70's, dark red colour. I can remember he traded it in for a then new FIAT 128, it wasn't a happy relationship!
the nose crunch made me sad period costume is fascinating. you don't see 1920's "flapper" style still used in todays fashions, so it seems quite easy for a lady to dress in period costume. (just an example, i know the wife isn't dressed like that). but how do you "make" a mens post WW2 shirt and trousers, when those things kind of still exist.
Last Edit: Jun 1, 2017 10:48:45 GMT by darrenh
