moglite
Club RR Member Number: 144
Jun 18, 2019 18:25:32 GMT
That looks astonishing. Applied over well prepared metalwork it’s probably more durable than chrome too. Ah yes - I've seen that company before - but it slipped off my radar. I like the idea of being able to prep the bumpers with a bit of filler and hi-build, to get them "perfect" before chrome painting them. The paint has the advantage over wrapping, that I can chrome some pot metal parts that cant easily be re-chromed. I'm tempted to rework the headlight bezels very slightly, but want to keep the chrome look. Might have to invest in a kit...... PID - slicing the rear bumper was pretty easy once it is all level. I even saved the settings I used for the R-tech welder we both have - so you've got no excuses
Last Edit: Jun 18, 2019 18:27:01 GMT by moglite
1967 Morris Oxford Traveller 1979 Toyota LandCruiser BJ40 1993 Daimler Double Six 2007 Volvo XC70 2.4D
Jun 18, 2019 21:44:47 GMT
That looks astonishing. Applied over well prepared metalwork it’s probably more durable than chrome too. Ah yes - I've seen that company before - but it slipped off my radar. I like the idea of being able to prep the bumpers with a bit of filler and hi-build, to get them "perfect" before chrome painting them. The paint has the advantage over wrapping, that I can chrome some pot metal parts that cant easily be re-chromed. I'm tempted to rework the headlight bezels very slightly, but want to keep the chrome look. Might have to invest in a kit...... PID - slicing the rear bumper was pretty easy once it is all level. I even saved the settings I used for the R-tech welder we both have - so you've got no excuses I haven't completely dissed this chrome paint stuff - I'm quite willing to take notes has you proceed - and even better if it comes good on the pot metal bits - onwards sir and if it works I might end up eating my words and sending you some gin in a decanter
Jun 19, 2019 21:26:59 GMT
Oooh there's a copper version.. I had always wanted to copper coat my chrome bits on the minor..
That chrome gives me another option for my currently green front bumper though!
Proper chrome on the bumpers please - 'Its Worth It' - Mind the lead times most are quoting several months and the estimated cost in multi digit telephone numbers - I have a good rechomer up in Yorkshire that works on both sensible lead times & money - you just have to get the stuff couriered up there - then collected - but its worth the effort Who do you use?
Jun 21, 2019 10:09:33 GMT
Proper chrome on the bumpers please - 'Its Worth It' - Mind the lead times most are quoting several months and the estimated cost in multi digit telephone numbers - I have a good rechomer up in Yorkshire that works on both sensible lead times & money - you just have to get the stuff couriered up there - then collected - but its worth the effort Who do you use? Prestige Electro Plating, Unit 6 Cliff Street Industrial Estate, Mexborough S64 9 HU. Telephone 01709 577004 - Contact is Brian Perkins - please mention the 'Jowett Car Club' and he will be aware of the referral has this is how he works
Jun 21, 2019 12:12:11 GMT
Prestige Electro Plating, Unit 6 Cliff Street Industrial Estate, Mexborough S64 9 HU. Telephone 01709 577004 - Contact is Brian Perkins - please mention the 'Jowett Car Club' and he will be aware of the referral has this is how he works I used to work there 😉😉😉
norm75
Jun 22, 2019 11:07:59 GMT
You can also remove it with brake fluid without damaging the vinyl. Worked a treat to remove the black paint on the brown vinyl interior of a Golf I had. Works on hard plastics too. Apply a small amount using a toothbrush/nailbrush dipped in the fluid, scrub until the paint comes off, wipe with a dry cloth or paper towel and allow to air dry. DON'T USE WATER. Once you've got all the paint off, clean as normal. If you use water during the cleaning stage it will go cloudy and you will have to do it again, even though it's really counter intuitive. Work on a small area, about 6" square, at a time. Takes a while but it's a dirt cheap solution and can even bring old vinyl up brighter and soft again. sorry to go completely off topic, but saw this picture and realised I read a thread on this car a few years ago on mk1golf forum I believe, is it the one where the interior was changed from later spec clipper tartan to early spec brown cloth?
moglite
Jun 23, 2019 19:21:35 GMT
Not too much to report - just chipping away. The fab on the rear bumper is 99% done (just one edge needs a trim) Here it is all stripped out, with a bar to hold it straight and true I think I'll leave that to one-side for now. There is some pitting, so I think I'll get it blasted when I've done the front one. So it is back to the bodywork, drivers side sill today. This is a pattern sill, and it needed a pie-cut to get it to get a 1/2 decent fit. It needed some slop to flatten it out - or profiling if you are a grumpynorthener The original sill was a huge bodge, so to get it this good, is a major improvement. A Traveller is supposed to have two jacking points in the sill. But those sills are expensive, and I'd never use the factory jack, and I like the smoother less is more look. Thanks for looking
vulgalour
Club RR Member Number: 146
Jun 23, 2019 20:15:55 GMT
norm75 that's the one. Long gone now. I don't miss it at all, it remains the least satisfying car I've ever owned and killed any desire I might've had to own another.
moglite
So the spare front wing has come back from Envirostrip - thanks again Chris..... Rear section just needs a small patch let in. So much better than the other side Front section is a little frilly, but should repair okay. But fitting the passenger front wing is a little way in the future. The rear lower tailgate needs painting this summer. I knew one corner was a bit below par, a patch on the outside is straightforward, bit the inner frame needs some work too, which will keep me busy for a while. One of the areas I've been putting off for a while, was the rear passenger door - prepping the inner frame ready for paint. It was a little bit rough I knew, but this was yet another surprise. How the hell does a door go rusty there ? I guess I'll be cutting that out and putting in a bit of steel - just for a change. Thanks for looking.
Leak from the window and door card holding the moisture?
moglite
jonsey was on the money with a leaking window. Rear quarter light seals are unavailable, so I can only weld so much without needing a new seal. Cut out the worst, and made a panel Welded that in and ground back There are still some holes and weak areas closer to the quarterlight, but those will just get filled, due to the aforementioned lack of seals. It is an area I can revisit in the future if I stumble across some seals. Detailing/repairing the inside of the rear door and tailgate is pretty tedious, so it is time for some retail therapy..... Paint is getting closer each day, and I needed a new top-coat gun. Went a bit blind reading reviews etc. Spent a bit more than I was expecting but went for a A.N.I. F150/F160 with a 1.4 nozzle The availability of a rebuild kit for less than a tenner swayed my decision. Already got a primer gun with a 14CFM compressor with a regulator/water trap, and I've got an on-gun regulator too, so I should be all set With the passenger door laid flat on the bench for repairs, I went off on a tangent, and started thinking about door panels. This is what I had on day one, functional, but not original, and not nice. They won't be going back on. Even the originals - aren't exactly over-designed. With just a couple of horizontal details. I'm going aluminium panels for the doors, kickpanels and boot panels. Spent some time with the measurements, and I can get all the panels from a single sheet. So assuming I don't make any mistakes (fat chance) this will be quite cheap to do. The chance of mistakes are going to be taken the n'th degree as I'm going to bead roll some design into them. Never done any bead rolling, so I'm going to keep it simple, and try and match the design of upholstery. I'm thinking something along these lines . So off to research bead rollers.... Decided on this one, a bit more expensive than the cheapies on eBay But the stand means I can take everything outside, so I've got some room to work. Also that one comes with shear wheels, which might be quite nice for cutting the aluminium panels. The UPS man is going to have a bad day delivering that
Last Edit: Jul 10, 2019 8:08:18 GMT by moglite
So will you when you have another pair of arms fitted so you can use it.
moglite
Jul 10, 2019 10:03:27 GMT
So will you when you have another pair of arms fitted so you can use it. I was born in Dorset - so I've got that covered I think the trick is to replace the handle with a wheel, that makes it a bit easier to grab when you are in a strange position. ....wonders if this will fit..... I plan on some kind of support to hold the panel up. If all of those aren't enough I'll try and work out a routine with my son, and some neanderthal system of stop/forward/back/bu66er
Jul 10, 2019 10:34:48 GMT
Interior panels will look cool. You need to get some advice from metalshapes on here. Check out his last post on the Zagato thread
moglite
Jul 10, 2019 12:12:39 GMT
Interior panels will look cool. You need to get some advice from metalshapes on here. Check out his last post on the Zagato thread Oh yes - I hadn't seen that, but very similar to what I was thinking. I'll have to have a closer look at that once I'm ready to start.
Pid363!
Madness is all in the mind!
Jul 10, 2019 21:40:59 GMT
Not wishing to copy you but I want to do ally panels for the 2 door. I’n exchange for rental of your knowledge and new toy I may have a spare pair of hands and arms! What thickness ally are you using?
Stupid is as stupid does!
From experience I would brace the plate up on the bead roller - every make & model that I have come across with exception of the higher end professional range always flex even when beading alloy sheet - a box section or equal angle frame welded to the back face of the plate prevents this and allows for accurate straight line beading * The steering wheel idea is exactly what is on my roller too and gives it a greater flexibility / workability when single handed * Ask me how I know
A - Apologies I promised to send this link over with regards to rubber seal extrusions - it's probably worth going through their extensive catalogue to see if there is anything that close to what you need coh-baines.co.uk/Chris
Last Edit: Jul 11, 2019 20:00:30 GMT by Deleted
moglite
Jul 11, 2019 19:58:04 GMT
Not wishing to copy you but I want to do ally panels for the 2 door. I’n exchange for rental of your knowledge and new toy I may have a spare pair of hands and arms! What thickness ally are you using? Copy away - it is hardly an original idea, and it'll be perfect for your 2-door - we can sort something out. I think I'm going to go for a full sheet of 1mm 1050 ali. It is about £80 from Metal Supermarkets, and if everything goes to plan I can get all my panels from that single sheet.
