Jun 23, 2017 13:02:05 GMT
Wish was that simple dark speed It can only be plumbed in one way as it's a std regulator and fits on end of rail and can only go on one way
rude
Jun 23, 2017 13:32:34 GMT
All this discussion, reading and that... my eyes are hungry, any chance of a few pictures of the naughty thing?
1986 Haunted BMW E24 635CSi 1999 Povo spec BMW E36 1.8i Touring Work Hack 2001 Petrol annihilating Discovery V8 2000 Jaguar S Type 3.0 V6 ~NEW~
Jun 23, 2017 14:09:16 GMT
Will post some pics later as photobucket and this phone just don't like each other it seems
Jun 23, 2017 14:13:32 GMT
Quick peek as only picture will let me see before it logs me out ??
Jun 23, 2017 14:26:03 GMT
Jun 23, 2017 14:26:52 GMT
Jun 23, 2017 14:27:47 GMT
rude
Jun 23, 2017 14:47:43 GMT
I should think it's probably just jealous of the other cars. Perhaps hide them all next door and see if the problem is still occurring?
Jun 23, 2017 15:16:00 GMT
I should think it's probably just jealous of the other cars. Perhaps hide them all next door and see if the problem is still occurring? Hahaha I prefer to see it as in good company myself
Jun 23, 2017 19:32:58 GMT
yep a damaged, kinked pipe would give you a pressure reading the same as it should be but you would lack flow. External fuel pump fittings been fitted with PTFE? is some in the pipe causing a flow restriction?
Jun 23, 2017 19:47:32 GMT
yep a damaged, kinked pipe would give you a pressure reading the same as it should be but you would lack flow. External fuel pump fittings been fitted with PTFE? is some in the pipe causing a flow restriction? Yeah gonna check the fuel lines under car for kinks when I get chance The pump and filter runs doughty seals and banjo affair with plastic pipes until further along under chassis were they are metal
Jun 23, 2017 19:48:55 GMT
Not sure how plausible this is as I've only ever seen it on a rally car after a big hit/dent, but could the fuel pickup be vacuuming itself to the bottom of the fuel tank? Pump is externally mounted :/ Yeah the pickup in the tank isn't though.
Jun 23, 2017 20:12:05 GMT
Pickup from tank to pump is a 5/8 ish size boss coming out of side @ lowest point of tank directly - fuel pump then through filter and reduced down to 8mm plastic pipes Actual tank outlet is clean and free
Jun 24, 2017 18:44:38 GMT
May have this problem solved hopefully Will post up remedy once I know it's cured
May have this problem solved hopefully Will post up remedy once I know it's cured Did you have any joy in the end?
Yes partly although just waiting on parts to arrive to double check Amongst other things inc a leaky fuel feed pipe Faulty fpr and also a faulty ecu temp sensor that was new
Like I say waiting for a new regulator to check if it's cured it
Watching this with interest as I also have a laid up Cossie that will hopefully see the light of day at some point!!!
Sounds like you're on the right path but it's always worth (not saying you haven't already) from the ECU wiring back, ie ECU unplugged, test sensors that way, often highlights poor connections etc.
I helped a chap it before with his one and it turned out to be a melted lambda sensor section of wiring (late 4x4 saph) dragging the voltage down.
We found a load of other things wrong too on a supposedly new wiring loom.
Can't wait to see the positive outcome of this.
BTW proper dream selection of cars in that garage!!!!
