shoey
Aug 19, 2018 16:28:44 GMT
clearance issues with the stock manifold,tried beating the strut tower in a bit but it turned out to be paper thin in places chassis rail and part of the inner wing also gone luckily still go the ice blue strut towers and in stead of panel beating in I pinched part of the O/S tower which is dimpled in blended in, still needs welding to inner wing made the gear linkage,turned a sleeve and made the rest from 1/2" key steel welded and blended in the gear lever bracket,its moved it forward 11" job for next week,steering rack to sump clearance,luckily this is just a web area and can be ground away without breaking into the oil pan,thanks for looking.
Last Edit: Aug 19, 2018 16:31:13 GMT by shoey
shoey
Aug 19, 2018 17:21:37 GMT
Does the gear change work as you expected it to? Yes Pete ,1st to 2nd or 3rd to 4th are exactly the same as before,going across the gate say 2nd to 3rd is slightly sloppy-er because of the strong self centring spring to neutral is acting against the clearance in the sleeve fit but its still pretty good
Aug 19, 2018 21:32:50 GMT
Great work so far dude always wanted a 2-door Toledo (so much so that I've got a NOS door under my bed in case I need it). Looking forward to seeing this inch back to life
shoey
Sept 16, 2018 17:33:36 GMT
small update,removed bulky outlet flange and heat shield tabs cleaned up,going to weld on secondary's and join up just after the bulkhead. coil overs from Rimmers and rear links powder coated notched out sump with 30mm belt sander and 40 grit to clear steering rack rebuilt steering joint plenty of room for lower steering shaft front suspension components powder coated and new poly bushes new camber shims cut from s/steel. NOS lower front panel off ebay to match the upper I've got,thanks for looking.
mk2cossie
Club RR Member Number: 77
71 Triumph Toledo with Beamsmk2cossie
@mk2cossie
Club Retro Rides Member 77
Sept 16, 2018 17:41:04 GMT
Loving this build thread! The car should be a corker when its finished
shoey
inner panel repair sections and g/fibre eyebrows from the dolly club,welded in the headlamp sections and fitted eyebrows with M4 bolts then this turns up on eBay,NOS won for 51 quid so off with the welded up panel much better fit MX5 calipers again but this time with Toyota Starlet discs which have a better off set and are slightly smaller diameter fitted some of the ancillaries to check clearances thermostat outlet needs modifying to clear battery will now face the front,just needs tig welding ,thanks for looking.
71 Triumph Toledo with Beamspeteh1969
@peteh1969
Club Retro Rides Member 107
Wow keep the progress pictures coming please?
I'm glad you are pushing through with this build you work and vision on this project is top notch.
Shoey, serously impressive project, just read it from the first page. I admire how well you've sectioned in recycled parts from the donor car (never as easy as it looks...just getting them off the donor without ruining them is a task) and how your cuts and repair panels never have hard, right angle corners.
First time I've seen the innards of a Triumph unibody and it must have been pretty state-of-the-art for it's time? Looks better designed to me than Austin or Ford shells of the same period and more like a German car....(compliment!).
Here in the USA the natives weren't given the opportunity to sample/buy the Dolomite, which in Sprint form would have competed with the BMW 2002 or Alfa GTV; maybe you Dolly enthusiasts have read the writings of Jamie Kitman, a contributor to "Automobile" magazine with a well-considered collection of old European cars? He has a Dolomite Sprint and rates it highly. Yours will be fantastic with the drivetrain you're fitting and I look forward to following along. Kind regards, John, Connecticut/USA
shoey
Wow keep the progress pictures coming please? I'm glad you are pushing through with this build you work and vision on this project is top notch. Cheers Pete should be on it more now the Pike/Perch lure fishing as gone a bit quiet .
shoey
Shoey, serously impressive project, just read it from the first page. I admire how well you've sectioned in recycled parts from the donor car (never as easy as it looks...just getting them off the donor without ruining them is a task) and how your cuts and repair panels never have hard, right angle corners. First time I've seen the innards of a Triumph unibody and it must have been pretty state-of-the-art for it's time? Looks better designed to me than Austin or Ford shells of the same period and more like a German car....(compliment!). Here in the USA the natives weren't given the opportunity to sample/buy the Dolomite, which in Sprint form would have competed with the BMW 2002 or Alfa GTV; maybe you Dolly enthusiasts have read the writings of Jamie Kitman, a contributor to "Automobile" magazine with a well-considered collection of old European cars? He has a Dolomite Sprint and rates it highly. Yours will be fantastic with the drivetrain you're fitting and I look forward to following along. Kind regards, John, Connecticut/USA Thanks John, I read somewhere that they stopped exporting the Stag to the U S because of warranty claims ,being as the Sprint and 1850 share alot of engine components/problems with the Stag it may of put BL off risking it,
Great work so far dude always wanted a 2-door Toledo (so much so that I've got a NOS door under my bed in case I need it). Looking forward to seeing this inch back to life This ^ surely had to be one of the most random things someone has under their bed.. Ever!
coil overs from Rimmers and rear links powder coated One of my favourite projects on here - really nicely done with great attention to detail. Are the discs and calipers in the pic from MGF? Or something else? Also (and I deleted one pic too many) to say that I've never had much luck with rebushed steering joints - I use a second UJ on my Vitesse, Spit, GT6 etc - should fit yours too..... Nick
shoey
Dec 16, 2018 19:28:44 GMT
there was no way the exhaust manifold was going to fit close enough to the body with the Toyota cross member so came up with this Dolly Sprint solution took the Toyota mount and cut the rubber off drilled and welded on a 7/16" bolt much better fitted some good s/hand wings with M5 bolts started tackling some rot around the windscreen frame had to remove part of the dashboard mounting panel to access this rust new metal let in trial fitted s/hand Sprint rad ,good fit modified thermostat housing now facing forward.thanks for looking
Dec 17, 2018 13:45:08 GMT
I'm starting to sound like a stuck record - every thread I comment on is 'that is outstanding work'! And this is the same - really is outstanding work. Plus I like the lateral thinking and attention to detail.
It's a beams engine - but which one (forgotten!) - 180bhp or thereabouts? More? Should make that Toledo fly. My dad had a sprint in 77 or 78 (new) and I have vivid memories of seriously travelling in one through the mountains from Anglesey to Mold.
Dec 17, 2018 16:16:23 GMT
You must be a lucky man to get that pannel for £51! Rare as poor quality wobbly children's play pony poo.....
14 Audi A3 Sportback - Easy driver 05 Audi TT MK1 3.2 DSG - Damn quick 73 Triumph 2000 - Needs work 03 Range Rover 4.4 V8 petrol. Had to get it out of my system.
shoey
Dec 17, 2018 17:09:58 GMT
I'm starting to sound like a stuck record - every thread I comment on is 'that is outstanding work'! And this is the same - really is outstanding work. Plus I like the lateral thinking and attention to detail. It's a beams engine - but which one (forgotten!) - 180bhp or thereabouts? More? Should make that Toledo fly. My dad had a sprint in 77 or 78 (new) and I have vivid memories of seriously travelling in one through the mountains from Anglesey to Mold. Its a 3sge gen 5, I think its got about 200bhp so should motor,sprints back then were pretty quick saloons let down by there front brakes so should image that trip through the mountains was pretty hairy!.
shoey
Dec 17, 2018 17:12:49 GMT
You must be a lucky man to get that pannel for £51! Rare as poor quality wobbly children's play pony poo..... Yer thats for sure,never seen one for sale before,couldnt believe it.wish I could find full outer panel for that money.
shoey
Jan 11, 2019 18:36:21 GMT
modifying radiator brackets to move it over 2" so top hoses line up repair panel welded and cleaned up O/S frame rot metal let in wasn't happy about cutting into floor pan so went and bought a second g/box to see if it was possible to shorten it cut off rear seal and bearing housing re positioned it inboard and moved actuator as far forward as it would go,still needs housing making to mount gear lever and then tig welding up trial fitting Kenlowe fan thanks for looking
