So got hold of this 1989 16V GTE a little while back. It was built in 2007 to be a rally or rally cross car but was never actually used. With 800miles on the engine there really hasn't been a great deal to do to the car but being built so long ago I decided to service it with new clutch, cambelt and waterpump, fluids etc etc. Anyway the car now just needs some final touches including some stickers removed and then geo setup before we give it a shakedwon on Nov 6th at Castle Combe.
Thought it was worth a share due to the steel wide arch kit and decent spec.
Rough Spec:
Engine:
- 16v XE Redtop
- Twin 45 Weber Carbs
- K&N Filters
- DTA Management
- Head Ported/Polished/Gas Flowed/Skimmed
- Piper Race Cams
- Piper Vernier Pulleys
- Omega High Comp Pistons
- ARP Bolts
- New H/P Oil Pump
- Mocal Oil Cooler
- New Cambelt & Waterpump
- Alloy Coolant reservoir
Transmission/Suspension:
- F20 Gearbox
- Koni Adjustable Dampers
- Adjustable Pillow Ball Top Mounts
- Eibach Springs Front
- Spax Springs Rear
- Fully Polybushed
- Front & Rear Strut Braces
- Front & Rear Grooved Discs
- Ferodo Racing Pads
- E marked Semi Slicks
- Shell Fully Seem Welded
Interior:
- Safety Devices 6 Point Cage
- Brake Bias Pedal Box
- OMP Bucket Seats
- OMP Harnesses
- OMP Steering Wheel
- Hydro Handbrake
- Battery Box in Rear
- Battery Cut Off Switch
- Fuel and Brake Lines Inside
Exterior:
- Steel Wide Arch Kit
- Very Clean Shell
- Poly Carb Windows
- Momo 15” Wheels
Rough Spec:
Engine:
- 16v XE Redtop
- K&N Filters
- DTA Management
- Piper Race Cams
- ARP Bolts
- New H/P Oil Pump
- Mocal Oil Cooler
- F20 Gearbox
- Spax Springs Rear
- Fully Polybushed
Interior:
- OMP Bucket Seats
- OMP Harnesses
- Hydro Handbrake
Exterior:
- Very Clean Shell
- Poly Carb Windows
- Momo 15” Wheels
