For sale – Vauxhall Astra GTE 16v Track Car
This GTE was built by a wealthy gentleman as part of his collection back in 2007 for we think rallying or rallycross, maybe even sprints and hill climbs. The shell was strengthened and seem welded and wider steel arches fitted along with a roll cage. And engine was also built at the same time alongside a decent handling package. The red top engine has only done around 800miles since it was built and run in, it runs very well.
Since the car was built it has seen a couple of trackdays and then dry stored by its previous owner. To bring the car up to mechanical standard we have had a fresh clutch kit put in, new cambelt and water pump, Fresh gearbox oil, Engine oil and filter, new track rod ends, new adjustable front top mounts, inner and outer CV boots, coolant change, fresh Federal RSR Semi Slicks and a new MOT.
This would make an excellent retro road legal track car ,or with a few updates to safety would be eligible in rallying, rallycross and various saloon and hot hatch series in the UK and Europe.
Rough Spec:
Engine:
- 16v XE Redtop
- Twin 45 Weber Carbs
- K&N Filters
- DTA Management
- Head Ported/Polished/Gas Flowed/Skimmed
- Piper Race Cams
- Piper Vernier Pulleys
- Omega High Comp Pistons
- ARP Bolts
- New H/P Oil Pump
- Mocal Oil Cooler
- New Cambelt & Waterpump
- Alloy Coolant reservoir
Transmission/Suspension:
- F20 Gearbox
- Koni Adjustable Dampers
- Adjustable Pillow Ball Top Mounts
- Eibach Springs Front
- Spax Springs Rear
- Fully Polybushed
- Front & Rear Strut Braces
- Front & Rear Grooved Discs
- Ferodo Racing Pads
- E marked Semi Slicks
- Shell Fully Seem Welded
Interior:
- Safety Devices 6 Point Cage
- Brake Bias Pedal Box
- OMP Bucket Seats
- OMP Harnesses
- OMP Steering Wheel
- Hydro Handbrake
- Battery Box in Rear
- Battery Cut Off Switch
- Fuel and Brake Lines Inside
Exterior:
- Steel Wide Arch Kit
- Very Clean Shell
- Poly Carb Windows
- Momo 15” Wheels
An excellent car ready for heavy use. Only issues we can point out are that some of the Digital Dash does not work, Carbs need balancing we think but the runs really well on the road and pulls strong if a little rich and the bodywork has its imperfections but the shell is solid.
£6500
Rough Spec:
Engine:
- 16v XE Redtop
- K&N Filters
- DTA Management
- Piper Race Cams
- ARP Bolts
- New H/P Oil Pump
- Mocal Oil Cooler
- F20 Gearbox
- Spax Springs Rear
- Fully Polybushed
Interior:
- OMP Bucket Seats
- OMP Harnesses
- Hydro Handbrake
Exterior:
- Very Clean Shell
- Poly Carb Windows
- Momo 15” Wheels
£6500
