Feb 19, 2018 20:34:41 GMT
I have bought myself a MK2 Escort Rally car model kit Its been about 3 years since I last made a model kit which was a Sprint car sprint caranyway, as I am into oval racing I thought I would build my escort as a Classic Hot Rod, like this, which almost has the same side graphics, and most of the same sponsor decals. as it wont be using the "glass", I thought I would use the models windscreen glass but cut it down and use the top part to make a visor as in the pic above, it would be painted with the body, it would also fit properly with the right contour. My question is, as per my topic title is; How can I cut the glass, without breaking it? I have a dremel, will that do it with a cutting wheel?
markbognor
Club RR Member Number: 56
Feb 19, 2018 21:33:02 GMT
jpr1977
Club RR Member Number: 18
Feb 20, 2018 13:02:00 GMT
Or a mini saw like this again with tape as a guide/marker
Feb 21, 2018 19:11:45 GMT
thanks, I had never have thought of making my own graphics, so have put that onto my "watched items" along with some plastic rod that I may use to alter the roll cage.
cutting with dremel, yes I think it would melt the edges, I didnt think of that initially.
the mini saw looks ok, suppose I could use a mini hacksaw blade and take it easy
Feb 21, 2018 19:46:45 GMT
That paper is brilliant. Complete replicas of your own cars reproduced in miniature!
Feb 21, 2018 20:14:45 GMT
the mini saw looks ok, suppose I could use a mini hacksaw blade and take it easy Better to get a proper micro saw, they are designed for the job and you will find loads of uses once you have one.
Rover Metro - The TARDIS - brake problems.....Stored Rover 75 - Barge MGZTT Cdti 160+ - Winter Hack and Audi botherer... MGF - The Golden Shot...Stored Project Minion........ Can you see the theme?
Feb 21, 2018 21:04:11 GMT
a few mins after my last reply I went on ebay and bought a set of modelling saws, and also some modelling files too on the transfer paper, I will wait until the kit arrives and see what I can do with the supplied transfers, erm, oh sod it I may as well order some!!
markbognor
Feb 22, 2018 18:19:03 GMT
White waterslide transfer paper was used on these, with the body colour round the outside to hide the white edge when trimming.
Laters
Head Droid Builder and Bottle Washer
Club RR Member Number: 115
I use a razor saw like the one pictured above. They are a lot sharper than you think and make quick work of cutting plastic.
I use my razor saws for a lot more than modelling.
Club Retro Rides Gti Member
Garage Queen, 1987 Quantum Saloon
steveg
Be careful when cutting the glass bits as the plastic is normally much more brittle than the rest of the kit.
Mar 12, 2018 17:40:46 GMT
Be careful when cutting the glass bits as the plastic is normally much more brittle than the rest of the kit. tell me about it! luckily the part I was cutting was taped up and I got it sorted here is a link to the pics of my build, updated often at the moment, descriptions with each pic, I AM NO EXPERT, its on facebook but its a public album so anyone can view it regardless of whether you are registered or not ford escort model build linkquestion about the transfer paper, I have bought some, theres no problem with me scaling down potential graphics as I can print them on normal paper first to help get them the right size, my question is what do I coat the transfer with when printed? I am using ink jet printer. will nail varnish be ok? thinned? tell me more. ta
markbognor
Mar 12, 2018 21:34:36 GMT
I've used a clear spray sealer, velspar I think. This (fortunately) didn't react with the Halfords clear lacquer top coat.
Laters
Mar 14, 2018 10:39:39 GMT
For the ink jet printed stickers and decals I make for my models I give them a coat of ink jet fix before use.
Mar 25, 2020 13:58:13 GMT
its only taken me just over two years to make a build video, which actually just took 5 mins.
its just basic, no descriptions.
has sexy content
I'm building the same kit and have to say the quality and fit of things isn't great.
I spaced out the rear wheels with some tiny washers but there isn't scope to do that with the front so I'm not sure what to do.
Jaguar S-Type 3.0 SE
I'm building the same kit and have to say the quality and fit of things isn't great. I spaced out the rear wheels with some tiny washers but there isn't scope to do that with the front so I'm not sure what to do. I agree, the mouldings are curse word the front end is pap and far too narrow, if I were to build again I think I would just make longer front arms from the sprue. or pack out the stubs, or just glue the wheels on as far out as possible.
