dikkehemaworst
Club RR Member Number: 16
Mar 26, 2018 21:59:23 GMT
I can't help but think that would look amazing with a full length bit of glass in it instead of the metal panel,,,, However the bodywork involved would probably be a massive ball ache to get right for strength because you'd need to remove the C posts for the seamless look. Mercedes and Renault/vauxhall/nissan vans offer stick on black glass for the back wich is glued to the Sides for the glass look. adapt one to fit, and keep the c pillar. Love the thread! can't wait to see your new vision on an old friend.
delux
There's treasure everywhere!
Mar 27, 2018 21:00:13 GMT
dikkehemaworst I wasn’t aware of that. Thanks for the heads up. Truth is I was leaning that way after coming across this... I reckon this is a suitable deviation from Preston and may be fun to try replicate. There are some challenges to overcome but I reckon this is the direction I’m headed. Chrysler called this the Rambler Suburban.
Are you going to weld up the top of the rear doors later too?
delux
On VW vans, you stick the glass to the panel to the rear, the glass is 2 pieces but because it’s black, once fitted it looks one piece (as the gap isn’t noticeable) I have windows b-c post in my transporter and thought of fitting c-d over the metal panels for a cleaner look but looking at your old advert you may want a small gap to give the appearance of a post..... Looking forward to updates whatever you do
Mar 29, 2018 13:27:39 GMT
I can't help but think that would look amazing with a full length bit of glass in it instead of the metal panel,,,, However the bodywork involved would probably be a massive ball ache to get right for strength because you'd need to remove the C posts for the seamless look There's a company that does seamless glazing for the Land Rover Defender and it keeps the structure.
Ian Campbell
'64 Morris Cooper S Traveller '65 Morris Mini Pickup '83 Austin City E '84 Sinclair C5 '87 Austin "Seven S" 1000 (Retro Rally / Autotester) '04 MG ZR '07 Vauxhall Astra GTE
Club RR Member Number: 160
Retrofuturism: Here we go againRich
@foxmcintyre
Club Retro Rides Member 160
Mar 29, 2018 17:32:27 GMT
I can't help but think that would look amazing with a full length bit of glass in it instead of the metal panel,,,, However the bodywork involved would probably be a massive ball ache to get right for strength because you'd need to remove the C posts for the seamless look There's a company that does seamless glazing for the Land Rover Defender and it keeps the structure. The landrover rear roof tub isn't really structure, the vehicle is modular separate chassis, all it does is vaguely keep the weather out of the back. It doesn't add 'structure' in the way a monocoque car is constructed. Keep this up too OP, the first van was built to a great standard. I'm sure you'll do the same a second time round!
79cord
Flat panel work would make things easy for glass but PT side glass is obviously curved top to bottom & custom curved glass isn't cheap. Polycarbonate sheet with scratch-resistant & UV protective coating would be easy to cut & flexible enough to bond in with curvature. Often see it attached to racers with screw fasteners which usually looks pretty terrible as it flexes around the fastenings & holes rarely oversized enough to account for expansion/contraction. Straight strips on the edges might keep things straight until adhesive sets..
Last Edit: Mar 30, 2018 8:50:58 GMT by 79cord
The landrover rear roof tub isn't really structure, the vehicle is modular separate chassis, all it does is vaguely keep the weather out of the back. It doesn't add 'structure' in the way a monocoque car is constructed. When I said keeps the structure I didn't mean it was "structural". I was referring to the basic structure of the LR's cab remains in place and the glass is simply bonded in place.
Ian Campbell
@foxmcintyre
The landrover rear roof tub isn't really structure, the vehicle is modular separate chassis, all it does is vaguely keep the weather out of the back. It doesn't add 'structure' in the way a monocoque car is constructed. When I said keeps the structure I didn't mean it was "structural". I was referring to the basic structure of the LR's cab remains in place and the glass is simply bonded in place. Well yes, I can see that through the glass, but that in essence isn't any different to having a glazed roof tub. I like the thought of the one piece glass on the PT. not on the landrover. That's trying to hard to modernise something you really shouldn't but in the case of the PT it could work well. It's just the difficulty involved even if you were to keep the pillars and hide them like the Landrovers glazing I suppose of having glass made up to fit.
dikkehemaworst
[/quote] this is really a thing of beauty!! wow!
Yeah, what he said ^^^ There's one like this that I see from time to time in the town, and in all honesty it's not much different to look at than a standard Land Rover, but somehow it's so striking!
delux
Just so you know I’m actually working on this... It’s looking patchy & worse than it actually is but it’s taking a good deal of time getting the complex curves right - which are now starting to feel about right. Good thing I have a second one to use as reference.
munky
Saw this today and thought of you Top shelf. About the only size project I could add at the moment! Loving the progress! Keep up the hard work.
delux
munky snap together! Perfect.
delux
This Project is a slow burn.... Door jams are done & looking oh so tidy. The rest of the body work is also being attended to. Bonnet and front left fender needed some attention and prep work too. No mad rush on this, hopefully have it done by spring.
Oct 23, 2018 17:30:40 GMT
Saw this today and thought of you Top shelf. About the only size project I could add at the moment! Loving the progress! Keep up the hard work. ill have the zero lol top right
delux
Righto, hopefully going to paint next week. Prep is almost complete...I’m starting to get amped now. Patience my paduwan...
delux
Mar 11, 2019 22:55:13 GMT
