Mar 23, 2018 11:05:09 GMT
It's great to have a table function on RR but it is a little awkward to use.
I know other forums use a Columns to Text type of table builder using the pling ( |) as the table delimiter.
Is there a way to do that on RR, or a similar kind of solution?
Last Edit: Mar 23, 2018 11:05:22 GMT by ChasR
Mar 27, 2018 23:32:53 GMT
It's great to have a table function on RR but it is a little awkward to use. I know other forums use a Columns to Text type of table builder using the pling ( |) as the table delimiter. Is there a way to do that on RR, or a similar kind of solution? I'm not entirely sure what you're asking here, perhaps easier to explain what you want to do? 'Pling' = !
Mar 29, 2018 11:33:49 GMT
Sometimes I'll put stuff up on a table like below: MOT Standard | 2016 | 2015 | 2014 | 2013 | CO=3.5% | 4.73% | 3.71% | 3.10% | 0.33% | HC=1200ppm | 503ppm | 283ppm | 317ppm | 256ppm |
But the table through the ProBoads function takes age to do and it can get very confusing once you start making larger tables. What I was asking is if there was an easier method to put a table in with. On a couple of forums you can use the pling as a delimiter for getting the things together, like so ||MOT Standard||2016||2015||2014||2013|| ||CO||4.73||3.71||3.10||0.33|| ||HC||503||283||317||256|| As a bonus they are much quicker to use than the above IMO and easier to follow. If you use MS Excel and possibly Google Sheets they are also simple to convert a spreadsheet into the above or vice versa.
Mar 29, 2018 12:05:57 GMT
ignore, tried a few ezcode options but nothing doing.
