Jul 22, 2021 10:23:56 GMT
Can someone please tell me what this is under the car, whether it should that hole in it (obviously not) and whether this would cause a flood of fluid to promptly remove itself all over the drive? It is halfway down the passengers side of the car just above the exhaust.
Last Edit: Jul 22, 2021 10:25:11 GMT by k11ngsley
Jul 22, 2021 10:35:18 GMT
That's the gearshift housing, is shouldn't have any oil in it just some grease, the cover is only really a dust cover so the holes shouldn't be the end of the world, In fact I think they have a hole somewhere else you can put a pin through to set things up.
If there is oil dripping off it it's likely something further forward is leaking and running back along the shift rods, the seals to the shift rod in the box do leak and are straight forward to change, but it could be leaking almost anywhere best bet is to clean it all up and try to find where the leak starts.
Jul 22, 2021 12:13:29 GMT
Thanks kevinsWell that leaves me to believe the head gasket has gone then. Oh dear…
Jul 22, 2021 19:35:04 GMT
is there oil leaking out of the gasket then?
Which engine is it?
Jul 22, 2021 21:51:04 GMT
It’s a 1.1L if that helps.
I can’t see anything really obvious going on here.
I am pretty confident now that the fluid that was dumped was from the cooling system.
It was all very sudden and unexpected. Had just come back from a 10 mile round trip, reversed onto the driveway. Stopped on the driveway for 30 seconds while running and then it was like a flood.
Turned car off immediately and inspected but other than it looking like it had come from drivers side it was unclear where on earth it had come from.
The fluid was dark, viscous and had a chemical smell to it. On reflection this must be coolant.
I would say that other than the dark colour the evidence of oil is very low. It certainly didn’t leave any multi coloured patches and has dried away in the sun leaving some staining.
Today I have taken off the cooling system hoses, expansion tank and radiator. All of which were thick with deposit and very dirty.
These are all now running clear and will pop back on the car to cycle through before another flush.
If it is from the cooling system and it is going to happen again then I should be able to see quite clearly if fresh water is chucked out instead of the mess that came out yesterday.
Not that it will make it any easier to spot.
Jul 22, 2021 22:03:59 GMT
It’s a CVH engine I believe. Someone has suggested that the core plug might have failed.
Any idea where this would be located on this engine?
And why this might have failed suddenly.
Last Edit: Jul 22, 2021 22:04:21 GMT by k11ngsley
This is A Ford CVH engine, not yours, but, it shows where to look for the core plugs ... and this is what core plugs look like And they are 'sacrificial' i.e they are designed to fail rather than damage the block ..
Last Edit: Jul 23, 2021 10:45:02 GMT by westbay
Jul 23, 2021 10:33:28 GMT
There is one on the back of the engine behind the flywheel as well, it could equally well be a hose or something simple I would fill it up start it up and see where the water comes from, or did it overheat and spit all the coolant out of the expansion tank on the bulkhead?
If it's a cvh the top of the engine will have a silver cam cover where the top is relatively flat, the OHV engine has a narrower more humped rocker cover that is usually black.
Jul 24, 2021 17:10:40 GMT
Thank you.
Today I have cleared out all the hoses until running clear and smooth.
All reassembled and run for 15 mins to get to operating temperature.
I am now thinking that this is an overheating problem as suggested.
Heater working so I assume this confirms the thermostat is working okay.
Fan did not kick in, temperature rose to about 2/3 before I switched it off as I thought fan should have started working by this point.
Next test is to take the fan out and see if I can get it to run.
Fuses checked already and looked fine.
I did notice that there is a pinhole fracture in the part below. Can anyone tell me what this is so I can replace.
Jul 24, 2021 17:12:16 GMT
Jul 24, 2021 18:45:30 GMT
It’s part of the cooling system and is bolted onto the front of the engine (front being the side that faces out towards headlights)
Jul 24, 2021 18:57:33 GMT
Last Edit: Jul 24, 2021 18:58:03 GMT by k11ngsley
Jul 24, 2021 19:22:46 GMT
Any advice on the steps to troubleshoot a radiator fan?
I assume there is (after fuse) a sensor and motor to check?
Can I just extend a wire from jump leads to the plug connection on the fan to see if it turns on?
How would you check the sensor works?
Jul 24, 2021 20:27:31 GMT
Fan checked with battery and *does* operate.
So what is next?
Would a depressurised system prevent the fan coming on? Ie the pinhole on the coolant pipe cause this?
1987 Ford Fiesta Ljohnthesparky
@johnthesparky
Club Retro Rides Member 6
Jul 24, 2021 20:50:33 GMT
There is a temp sensor somewhere, possibly 2! My Astra has one for the temp gauge and one for the fan. Don’t know where the fan thermostat switch is, but google suggests it looks like this From the looks of that, when temp rises it shorts and power goes to the fan, so you could link the wires together to check wiring etc, then either remove the switch and check with boiling water or let it get hotter. The other sensor probably only has 1 wire, and if shorted the gauge will go right up. And depending where the sensors are, if there is an airlock then instead of the sensor being submerged in hot water there would be air in a pocket, so yeah it’s possible that is part of the problem
jimi
Heater working so I assume this confirms the thermostat is working okay. That's not necessarily the case, I'm not particularly familiar with the Ford cooling system layouts, but its very common for the heater take off point to be before the thermostat (ensures quick heating/ demisting) I'd be getting the thermostat out and checked before going further, it's not exactly uncommon for a thermostat to fail. Never assume, assumption is the mother of all f***ups !
Last Edit: Jul 25, 2021 10:00:50 GMT by jimi
Jul 25, 2021 10:31:07 GMT
Thanks both. Great advice.
I now know where the sensor is, I have been told to bridge test it to check the circuit.
How do I check the thermostat is operating?
Jul 25, 2021 11:59:48 GMT
I located what I think it’s the sensor suggested. Filled back up with water. started the car and bridged it with a screwdriver and then with a screw (bare metal) and nothing. Did I do this right? And this means that the sensor is gone? it definitely looks as though it has seen better days.
Jul 25, 2021 12:09:27 GMT
Not my finest hour there, just thought about what I did and I had bridged the sensor not the circuit. Which clearly would do nothing.
Instead I have now bridged the actual circuit and the fan spring into life.
So…up to temp test next to see if the fan ever kicks in.
Is there a test for the sensor should the fan not kick in?
Jul 25, 2021 12:23:26 GMT
Running test complete.
Fan did not kick in and car boiled over.
Same as the other day so confident now that this is what happened.
So now to find a sensor and the coolant pipe that is worn.
