Valeted and detailed to perfection with all niggles taken care of, on a good day, I could see this being worth £7-8K to the right person.
The car has a reasonably un-troubling MOT history, it was MOT'd only a few days ago. The MOT tester highlighted as an advisory the fact the car has a MAJOR oil leak of undetermined origin. I imagine this has panicked the current owner into selling or perhaps he's taken advice on the repair and it's an expensive fix, (if he's a top chap of scrupulous morals he might have told you about this or even had the necessary work done).
If you're unaware of this and the repairs have not been effected you'd need to consider; additional expense, the fact the vendor has tried to hoodwink you and the worst case scenario - has the engine been damaged because it's been run with low oil levels.
If it's just a gasket or seal needs renewing and the engine is good then there should still be a profit to be had. If the vendor has tried to conceal the oil leak from you, a chance to leverage a bit off the asking price.
p.s.
I just tried another random B3 3.3 Alpina on MOT check, it's coming up on the DVLA database as a BMW Alpina.
This car is coming up as a BMW 328, are you 100% that it's not a replica?
Is this a long-time owner selling it or an Arfur Daley?
p.s.
