Just brought a sealey mighty mig 150 that came with a euro torch that the owner was going to install. Has anyone ever done this conversion? Any help or advice would be great. Alternatively is the any one you would recommend in the surrey area to do the conversion. Many thanks Tony
Jun 19, 2018 12:21:18 GMT
I did my supermig 150 about a year back. I'm not sure on the difference and also mine is about 15 years old. My case was already to take a euro torch which made it a fairly easy job. Only issue was that the factory holes were out of line with the wire feed. I made a spacer. You then need a gas solenoid and power for it that operates from the trigger the same as the wire feed. I used a 24vdc one and picked up the power from the pcb. Lots of help here www.mig-welding.co.uk/forum/ have a root around in the welding machines section.
Proton Jumbuck-deceased :-( 2005 Kia Sorento the parts hauling heap V8 Humber Hawk 1948 Standard12 pickup 1953 Pop build (wifey's BIVA build).
Nov 30, 2018 15:04:27 GMT
Hi crockpot I'm in the process of doing the gas solenoid the kit came with a 42v gas solenoid that was recommended for the 150 and for the life of me i carnt find the where to wire it to any help would be great
Many Thanks
