Sept 10, 2019 21:11:15 GMT
I know I’m the wrong side of the pond, but vices often go for not much here, I guess because they’re heavy and a pain to ship. Old grubby ones especially so. Today I’ve sold an old bench, with an old-skool 5” metal vice, as well as a wood work vice, and I eventually got £50 for the lot!
I’m following your project with interest Phil 😀
Sept 11, 2019 0:53:57 GMT
Got home late tonight, so cleaned the garage up a bit and started on a bit of metalwork. Only a little because it's already hot as hell outside and working with flames and hot metal is, well, hot work. Took 2 pairs of pliers and bent it as neatly as I could. It's now been left to cool naturally. Gas can in shot of flames and stuff. That needs to move, looking at it in retrospect... Phil
Last Edit: Sept 11, 2019 0:55:36 GMT by PhilA
Sept 11, 2019 2:06:24 GMT
As a youth, we once had a bonfire which we started with fuel, as you do. Jerry can was removed to a safe distance and forgotten about. Couple of hours and few beers later, someone set off a bunch of small fireworks, that shot up in to the sky. One wizzed back down again, bounced off the handle of the Jerry can, narrowly missing the open neck, as someone had forgotten to put the lid back on..
Sept 11, 2019 23:44:02 GMT
Made 4 pieces. Slowly becoming a bracket. Drill, file, drill. Finished painting radiator also. Ran out of time for anything else. Phil
Sept 12, 2019 23:45:37 GMT
Bracket almost complete. Just needs another bolt putting through the alternator rear bracket and the lockwashers putting on. Tightens up ok. I'm going to try get it running and see if it squeaks and if it still charges okay. Phil
Sept 13, 2019 0:41:53 GMT
very nicely done!
JP
Sept 14, 2019 0:33:33 GMT
Assembled and running. Alternator appears to be putting out. Phil
Sept 14, 2019 22:18:49 GMT
Will you paint it blue as well?
Sept 15, 2019 1:50:35 GMT
Funny, you're not the first person to ask that.
I think I'll paint it engine turquoise with the fan and pulley black.
Phil
Sept 15, 2019 5:38:45 GMT
Alternator appears to be putting out. Phil Did you get lucky... ? I think that's my coat...
Sept 16, 2019 12:02:38 GMT
Funny, you're not the first person to ask that. I think I'll paint it engine turquoise with the fan and pulley black. Phil Sounds an excellent choice.
Sept 16, 2019 15:44:38 GMT
Just placed the order for a replacement front oil pump.
The shop had a dig and found a brand new old stock pump, so that's making its way to me, along with a new front oil seal to fit because the one in it is 68 years old and may no longer have the required elasticity to seal long-term.
Also a couple thrust washers and hopefully that should see the gearbox able to be reassembled.
Phil
Sept 16, 2019 16:32:35 GMT
Fair enough to them, he said the pump was jammed solid. The anti corrosion stuff applied to it had made it all stuck together, including the screws that hold the case together. He said it took an impact screwdriver to undo the screws. I don't have one so it would have been a right fight otherwise.
Phil
Sept 17, 2019 22:30:33 GMT
Found my timing light.
Discovered someone has connected the spark plug leads one lead indexed backward.
That would explain why it was running a bit lumpy. I'm surprised it ran at all, it was 45 degrees advanced...
Phil
Sept 18, 2019 1:04:08 GMT
Cleaned up and painted the timing markers on the pulley and the pointer. TDC in red, then 3 and 6 degrees BTDC. Runs much better now, really smooth set to 6° BTDC.
Sept 19, 2019 21:11:10 GMT
Oil pump porn. Brand new old stock 1951 front Hydra-Matic oil pump. Mmm. Phil
Last Edit: Sept 19, 2019 21:11:44 GMT by PhilA
Sept 19, 2019 22:36:40 GMT
Re the oil pump: my simpleton mind always struggles to grasp epicyclic gears; is the crescent shaped bit stationary or does it move round with everything else?
Re a vice: question of the obvious, I realize, but are you watching Craigslist for a nice used example? I've scored all kinds of cool tools from my local CList...up here in Connecticut.
Best, John
Sept 19, 2019 23:12:13 GMT
Only the dark bits in that move- the oil is drawn in just where the gears begin to open up "furthest away" from you as viewer; the oil is drawn around through past the little island and then as the teeth close up it's forced back out of the outlet pipe through the long opening in the top- the hole visible in the side is for the pressure control valve. The little popped up piece on the far side is the mega-mega overpressure relief in case something gets jammed it will relief off all the fluid pressure.
Phil
Sept 20, 2019 2:03:40 GMT
Well, found the problem. It's of my own doing. The old oil pump bearing didn't sit fully in. It's about 15 thou' proud but I didn't notice because it sits in a concave indention. The manual diagram does NOT show that as a bearing edge, which is odd. New pump, new washer and I'm at 35 thou' clearance. Limits 4 to 15 thou'. Nuts. Only saving grace is that washers are available in ± 0.002": #1 0.057 #2 0.065 (fitted) #3 0.073 #4 0.081 #5 0.089 #6 0.097 #7 0.105 #8 0.113 So, middling of the tolerance range is about 0.009 clearance. What I have now minus what needs to clear 0.035 - 0.009 = 0.026 Current width washer minus difference 0.065 + 0.026 = 0.091 To the nearest size washer => 0.089 == 11 thou' Next thickness up is 8 thou' more, which would leave 3 thou' so that's no good I need a #5 washer Double nuts. Gonna order that tomorrow. Should be here Monday, Tuesday hopefully and that then will be good. Chalk it up to experience Phil
Last Edit: Sept 20, 2019 2:13:19 GMT by PhilA
Frankenhealey
Club RR Member Number: 15
1951 Pontiac ChieftainFrankenhealey
@frankenhealey
Club Retro Rides Member 15
Sept 20, 2019 9:03:08 GMT
Chalk it up to experience Just think of how fast you'll be able to do it next time
