Coils wound (hopefully for the last time). With a not insignificant quantity of pfaff, the gauge now reads accurately across the range to match the new sensor. I matched the gauge to the sender unit, hopefully that'll be good. Tonight I also cleaned up the cigar lighter because it was filthy and that had been annoying me for a while, seeing it sat on the bench. Phil
Last Edit: Dec 23, 2018 0:19:27 GMT by PhilA
Dec 23, 2018 13:26:18 GMT
Nice work, I don't think I would have your patients when it comes to the gauges but its great when stuff is that simple you can fix it if you have the time and knowledge!
Dec 25, 2018 15:51:19 GMT
Well, so far this has been a moderately fun diversion in repair- I have the time so it's been cheaper than trying to buy a replacement pair of gauges, too.
Phil
Got busy with the fine line tape and the satin black paint tonight. Looks better now. Phil
Last Edit: Dec 27, 2018 6:12:54 GMT by PhilA
jamesd1972
Club RR Member Number: 40
1951 Pontiac Chieftainjamesd1972
@jamesd1972
Club Retro Rides Member 40
Looks ace now.
Phil [/quote]
Fixed that for you !
A car that deserves the level of attention to detail you are putting into it, thanks for the updates.
James
Dec 27, 2018 18:05:10 GMT
I saw some places where I didn't paint very well last night, so I took the dash apart again and started to mask it up. Once it was all done, I rubbed the paint back with 1000 grit paper and wiped it clean. Gave it a nice even coat of black. Heated the paint with my heat gun on low to get the surface to flash nicely matte, then lifted the masking tape off. Greased up the gears in the odometer. Painted the speedometer bucket because all the paint was flaking off. Finally, reassembled and all lit up. Waiting for the paint to fully harden, but that can go back in the dashboard now. Phil
Dec 27, 2018 18:14:53 GMT
That's better than the Oxford Street lights!
Dec 27, 2018 18:21:28 GMT
I keep coming back, and loving what I see.
Dec 27, 2018 18:51:21 GMT
Love when old dials get some decent bulbs behind them, they looks so much better.
Dec 27, 2018 20:34:51 GMT
Very nice - how about green (led?) bulbs as a further enhancement?
1951 Pontiac Chieftainpeteh1969
@peteh1969
Club Retro Rides Member 107
Dec 27, 2018 21:14:40 GMT
Very nice - how about green (led?) bulbs as a further enhancement? I would say Blue Led with a resistor in series to make them a paler shade of blue in keeping with the colour of the car would be good.
Great work on the dash Phil.
Dec 27, 2018 23:30:39 GMT
I could- if it were to be changed, I think pale green or pale blue. Picture above is with the correct incandescents in, for reference. Phil
It's a lovely dash whatever the colour!
I was thinking "ice blue", like in my Jeep. Camera only slightly destroyed the color. Phil
Last Edit: Dec 28, 2018 0:47:27 GMT by PhilA
Those instruments would look very nice just illuminated on a shelf.... They will look much better in the car obviously ! Love your work mate
That looks superb. Nice job!
Wiper motor time! First, the control needs to be removed from the top of the dash. Then the linkages come off, held on by a spring clip, and the whole thing drops out after two bolts holding it in are removed. Seriously one of the easiest wiper mechanisms to remove. Stamped Trico. Took the side panel off to reveal the mechanism that flip-flops the valve over to move the vacuum motor. Oiled up the control cable and gearbox as it was a little stiff to operate and wouldn't spring back from the "washers" position. Left it dangling through a hole in the bench for gravity to work its magic. Took the lid off. The grease inside had solidified and was no longer allowing the vacuum flap (ooh, matron) to slide smoothly. It also partially relies on the grease to seal. Greased up the valves and put it all back together. Got the Renault running and connected it up to the vacuum tee on the brake booster. Runs nicely now, to and fro with a good amount of force. Even the self-park works! I'll have to wait and see how it works with the wipers connected. I think I'll need to grease the spindles too. Phil
Last Edit: Jan 1, 2019 1:54:04 GMT by PhilA
What a great thread! Your Pontiac has clearly found the ideal owner, and I appreciate learning how all the elegant parts work. The American auto industry was tops in component- and production-engineering when your car was made. Kind regards, John, Connecticut.
Thanks. It's surprising how many people have made complaint (not here, on other fora) that it's been "horribly modified" and they're mortified I am not considering undoing some of the things done to modify the car (lowered, 12V refit, interior, paint) yet that's probably the only reason this vehicle survived. The modifications aren't new (well, the 12V "conversion" is probably the last ten years) but the lowering, paint, interior have all been done well and are now part of what the car is. It's not anything like a Barris hot rod, it's a sympathetic custom. I'm just trying to redo it properly. It's also fun learning how it all works- tonight, for instance. I had no idea how the wiper motor worked. So I took it apart, cleaned and re-greased it. Thankfully it's in pretty good shape inside so has been returned to working condition with a couple of hours work.
As I have stated before- this car came from an era where it was financially feasible to actually strip down and repair component parts of the car. Granted, in-depth repair like I did in the gauges would likely see the gauge sent off to the manufacturer and they'd either rewind it replace the coils and reissue it as a repaired part. My point is very little of the component parts of the car are designed to go together just one time. The body itself is welded and doesn't qualify for that but overall the wear parts can be fixed.
I've seen immediate post-war vehicles from the UK also and while they do rival the technological advances the USA made during the war, the implementation of that technology was often left to the more expensive marques, often due to severe austerity. This is a well engineered car with good fit and finish. There's a lot of really neat touches gone into the design because of the competition the brands had here in the mid fifties.
Glad you've enjoyed reading though!
Phil
Last Edit: Jan 1, 2019 2:23:04 GMT by PhilA
Phil,
Really enjoying the care you're showing to this old beauty. Looking forward to coming installments...
Vacuum wipers... reminds me of those in my 57 Chevy. Should you road trip the car one State north, to Arkansas, to visit friends who may be taking advantage of the new law permitting recreational Marajuana use, take them for a spin on a rainly day, pop in some music and modulate the wiper speed with the gas pedal to match the beat of the tunes, then wait until the friends realize that the wipers are in time with each song.... Great fun!!
Happy and healthy New Year,
Lance
