Dec 15, 2018 12:27:52 GMT
Hi all have had a steady couple of days on the Vivaro the 12 volt fuse box is fitted and wired and the inverter is mounted and wired. I have been running the heater whilst working and it works well.I should start fitting the units on Monday afternoon subject to the weather.I am currently working on the curtains for the side door and kitchen area. I am using a new curtain system that#s light weight and neat once fitted. I have trial fitted the first curtain and they look promising. The one I have made will need a dart adding so it fits better in the corner. Have finished for today as its 1 degree and starting to rain. Cheers - mike b
Dec 16, 2018 15:30:20 GMT
Hi Mike, Thoroughly enjoy reading your camper builds... the standard you work to is excellent.
Thanks for updating 😁
Dave
Dec 16, 2018 15:42:03 GMT
That air heater looks the business, eBay or a better brand?
Dec 18, 2018 12:56:50 GMT
That air heater looks the business, eBay or a better brand? Hi there its a Planar heater, basically a eberspacher clone. I have fitted quite a few over the last 2-3 years and not had any issues.They work well and so far have proved very reliable. Cheers - mike
Dec 18, 2018 12:59:47 GMT
Hi all still plodding along with building the cabinets for the Vivaro. All the panels for the kitchen unit are finished, just waiting for the laminate for the work top. I should be starting the wardrobe unit this afternoon, weather permitting. Cheers - mike
Dec 18, 2018 15:19:55 GMT
Hi all got the fridge housing trial fitted. That's it for today as the weathers turned poor. Cheers - mike
Dec 19, 2018 21:14:24 GMT
Hi all
I did the final install of the fridge and fridge unit earlier. Its good to see bits going in permanently.
I ran the fridge for a couple of hours and used the inverter to power my jig saw and all was fine.
The electrics for the water pump / tap and the sockets and volt meter are all finished. They are in a separate self contained loom.
I also spent an hour drilling out all the random holes if the rear doors to 8mm so I could plug them with 8mm grey plugs which I have purchased.
The blank for the top cupboard is made, just the hole to cut out.
The laminate for the work top and table arrived earlier so thats everything here now apart from the table leg and base.
I'm of to Whitby until Sunday for lots of beer, fish and chips and pre-christmas fun. I should get back onto the Vivaro on Boxing day hangover permitting!!!
cheers - mike
Dec 29, 2018 12:35:46 GMT
Hi all got back onto the vivaro today. Didn't get anything done for a couple of days as my one year old grand came to stay. Anyways, had a steady morning and made the door for the top cupboard. Have trial fitted it and am happy with the fit so it just needs fixing now. I cant fix it permanently unto the ceiling is in which is the job for tomorrow. I should have the wardrobe end panels cut and ready to go in later and maybe the front of the kitchen unit. I'm working outside today as the weather is good, 12 degrees and sunny!! makes a change from my workshop. Cheers - mike
Dec 29, 2018 15:45:27 GMT
hi all got a bit more done the front panel for the kitchen is finished and the pattern for the wardrobe end is made. Tomorrow morning should see the interior panels for the kitchen made. The battery and heater need boxing in plus a few odds and sods. Cheers - mike
Dec 29, 2018 17:07:25 GMT
Hi Mike - which heater are you using for this? EDIT - read further on and found out!
Last Edit: Dec 29, 2018 17:08:43 GMT by OAY842F
1968 Mini MkII, 1968 VW T1, 1967 VW T1, 1974 VW T1, 1974 VW T1 1303, 1975 Mini 1000 auto, 1979 Chevette, 1981 Cortina, 1978 Mini 1000 1981 Mini City, 1981 Mini van, 1974 Mini Clubman, 1982 Metro City, 1987 Escort, 1989 Lancia Y10, 1989 Cavalier, 1990 Sierra, 1990 Renault 19, 1993 Nova, 1990 Citroen BX, 1994 Ford Scorpio, 1990 Renault Clio, 2004 Citroen C3, 2006 Citroen C2, 2004 Citroen C4, 2013 Citroen DS5. 2017 DS3 130 Plenty of other scrappers!
Dec 31, 2018 15:30:26 GMT
Hi all had a steady day on the camper the wardrobe / kitchen end panel is fitted and I have boxed in the heater and leisure battery. The wiring for the heater control panel has been routed and modified. Tomorrow should see the wardrobe front and rear panel finished and fitted. Cheers - mike
Hi all spent the day finishing the wardrobe panels and a few odd and sods. The doors for the wardrobe are made and hung and everything has been trial fitted. Just the interior panels for the wardrobe to make tomorrow then it can be fitted for good. Cheers - mike
Very neat, are the panels for the wardrobe / fridge / cupboard doors, a kit??
Very neat, are the panels for the wardrobe / fridge / cupboard doors, a kit?? Hi there the panels are all made by me to fit the particular conversion I'm doing. Cheers - mike
Hi all
had a steady morning today
have made the worktop for the kitchen.
This afternoon should see it fitted along with the tap,waste and pop up mains socket.
Cheers - mike
did a bit more whilst waiting for my dinner to warm up
cut the hole in the worktop and fitted the pop up socket.
This one's an upgrade from my usual ones as it has an aluminium casing instead of plastic.
Just got to add the plug later.
Anyways i'm off to fit the sink and cut the holes for the waste pipes etc.
Cheers - mike
and some pics
and a bit more done whenever I fit a Dometic sink I have to modify the tap to fit as they make the hole in the sink an odd size so that only their mixer tap fits. This is no big deal unless you only want a cold water tap which has a slimmer body so I have to make a couple of spacers. The sink is now fully fitted with both the tap and waste connected. Next job should be final fitting of the worktop but as its cold and raining i'm going to retire to my workshop and make the table top. That should be about it for today. Cheers - mike
Hi all made and early start today did a bit of tidying up and measured up for the wardrobe internals. Got the table finished. Cheers - mike
