cactus
Closing my shop soon so clearing out.. Few engines first...
Ford Sierra 1800 Turbo diesel.. Removed from a Singer Vouge!!! Very good runner,complete
£150
Triumph 2000 engine. Removed from a mk1 estate showing 54000 miles Ran well no knocks etc.
£100
Ford Pinto 2000 Choice of 3 One is a recon only run for an hour...£350 One removed from a kitcar Good runner no problems
£250
Rover V8 SD1 3500cc Perfect runner no inlet etc
£200
Sherpa Diesel 2500cc engine Removed from a series Landrovef Perfect runner.
£200
interested in the mk1 2000 engine ..more details please
bit of triumph nut
Wreckit
MK1 1200 bandit, T120 Boneville, E39, NB MX5
Dec 11, 2018 21:16:04 GMT
where abouts are you and is either of the pinto blocks a 205 ?
new workshop incoming
Dec 12, 2018 15:58:31 GMT
Ive sent you the correct phone number now
bit of triumph nut
Dec 12, 2018 20:06:22 GMT
Triumph engine still available? Does it have carbs, flywheel, dizzy etc?
Koos
cactus
Dec 17, 2018 19:16:30 GMT
where abouts are you and is either of the pinto blocks a 205 ? Yes it is...
cactus
Dec 17, 2018 19:19:17 GMT
Triumph engine still available? Does it have carbs, flywheel, dizzy etc? It is an automatic engine a d has o carbs/manifolds. Provisionally sold.....
Dec 20, 2018 20:58:40 GMT
Triumph engine still available? Does it have carbs, flywheel, dizzy etc? It is an automatic engine a d has o carbs/manifolds. Provisionally sold..... Still sold?
Koos
It is an automatic engine a d has o carbs/manifolds. Provisionally sold..... Still sold? I picked it up on Saturday..it's actually a MK2 engine..ME prefix ..shoved a camera down the plug hole and bore looks good
bit of triumph nut
Cool! I really need a mk1.engine anyway!
Koos
it def came out of a MK1 car...front plate has been changed for a MK1 one ,with the engine mounts on, i was hoping for a MK1 engine too .as a spare for my saloon, as we do the odd historic rally ..
bit of triumph nut
cactus
Found some gearboxes to suit the engines. Need all these gone so started to list on ebay now.
Wreckit
Unless I am being special what area are you in matey and do you still have the 205 pinto ? Cheers Steve
Jun 11, 2019 16:06:57 GMT
Following PM, do you have any gearbox(es) to suit the V8 Rover? Slip yoke etc? Thanks.
Last Edit: Jun 11, 2019 16:07:37 GMT by moosevan
cactus
Jun 20, 2019 14:27:49 GMT
Yes....205 Pinto still here...
cactus
Jun 20, 2019 14:32:03 GMT
One Pinto sold...
2.5 Shepa/LDV engine sold
Recon Pinto and 205 Pinto still here.. Good C3 Auto box from the Pinto available...
