Monday 3rd June. Project 2 complete, collected and off to sea, well a lake / river / pond somewhere.. Difficult to tell if the repairs have been 100% successful until its been dunked, wouldn't fit in the bath Trailer has been stretched by a metre, all of which is on the drawbar. New upstand to support the bow and prevent it sliding forward under braking. Heaven forbid there are any issues but should it come to a sudden stop and the dinghy does break free it should either ride up and clear the towing vehicle or impale itself and avoid hitting the towing vehicle. A couple of bolts on a lump of Unistrut fixed to support the spare. This in turn, although well clear of the ground in use, does keep the hitch off the ground. Back end was what caused the damage to the hull in the first place. The box section supporting the rear rollers penetrated the hull, both sides needed grinding out and re-glassing. Twin rollers removed, single rollers put back in the right place for this dinghy. Trailer board is easily removable but may switch to R clips or lynch pins after the first test. Cable is in spring clips all the way up to the front hull support, then cable tied. I can always put more clips in if needed. I managed to lift the entire back end including the trailer by the bottom edge of the transom so it's not that heavy. Hopefully, now the rollers have been moved, it won't perforate when it bounces. The hull repairs were just ground out, washed out with acetone to soften the old resin a bit and then matted in again. Once set, this was roughed up with a rotary file before the filler went in. I used a new Isopon junior glass fibre kit as my old resin is showing signs of age. Gone lumpy. Filler is Plastic Padding, marine gelcoat filler. Very soft and easy to mix, dries much harder then normal P38. Big repairs were filled and covered with polythene sheet then rollered flat with a stainless 1" bar. Still had to take the air file to some of them. Might have added a little too much filler on a couple. You can see in this photo how much further forward it now sits compared to it's original position. Everything from the spare wheel forward has been added. To find out if I had reduced the leaping in the air issue we tested it over a handy speed ramp. I'll add the video when I've trimmed it a bit. So, happy customer, boat and trailer gone. Night off tonight, next job is flatting and clear coating that Fiesta bonnet. Once that is done I can take a serious look at the 'office' wall with a big hammer.
1988 DUTTON LEGERRA MK1 - SPARES DONOR 1989 DUTTON LEGERRA MK2 - CURRENT PROJECT 1990 DUTTON LEGERRA ZS MK2 1990 DUTTON LEGERRA ZS MK2 DUTTON PHAETON S2 - Resting DUTTON PHAETON S4 - Resting DUTTON PHAETON S4 - PROJECT X DUTTON SIERRA S2 - Resting
Thursday 6th June - Today it rained in my unit. It must have been inside because I don't see that amount of water getting in any other way. Went round this evening to put some more racking up and cleared flood water instead. This is the pedestrian entrance door which is completely covered by a steel roller door. There is a 3 inch drop to that grid outside which runs straight into the main drain. Bottom of shot is the one inch high step where the bitumen floor stops, the concrete is one inch down from the bitumen floor that runs through into the office. Taken from the 'office' looking back towards that door you can see it's made progress all the way across the floor... and into the 'workshop' area. That is the lowest part of the old floor, sadly it's lower than the shutter edge so some fettling required to stop that happening again. Time to call the man with the mixer I think. Behind the door into the office you can see the sunlight coming through the two inch gap which currently runs floor to ceiling. I know the floor needed another wash but I wanted to do it in my own time What concerns me more than the water on the floor is how much got down between the back off the office wall (with live electrics) and the big metal door on the outside which can not be moved as the rollers are stuffed. Todays downpour was spectacular, short and vicious as the thunderstorm was directly overhead, it was bad enough 14 miles away at work, must have been pretty intense here. Once the water, or the worst of it, had been swept out I put some racking in the office, I seem to be a few shelves missing but sure they will turn up as I clear the pallets.
Jun 13, 2019 22:48:29 GMT
Thursday 13th June - Not reported in for a week so bit of news, mostly good Over the last week I have been making yet more shelving and bolting it to the wall in the 'office'. Most of the identified boxes (the ones I labelled) are now tucked away and away from the flooding should it happen again. Some of these will need going through as they were stuffed with tat thats not listed on the outside. Nice man from the skip hire firm dropped a little skip outside for me on Tuesday so the prevent other people from filling it up I lifted it with the engine crane and dragged it inside. Now I've got somewhere to dump the tat I don't need and the plasterboard from that dividing wall I could have just had at it with a 14lb hammer but decided that as I still have the fiesta bonnet in the office I'd not take the chance of stuff landing on it. I moved the double socket from waist height right in the centre of the wall to 'arms reach' next to and above the pedestrian door. I then fitted one of the larger LED flood lights next to it and wired it in on a plug. These won't get used very often as there is plenty of light from the overhead tubes and the two LED floods already fitted. Using the traditional hammer and screwdriver method I punched through the plasterboard where I thought the joists went, then used a wallboard saw to follow the lines to make this. As well as the plasterboard all the horizontal noggins have been removed apart from the one with the live circuit ring main running through it. That needs daylight as I will have to isolate all the lights in the office and all the sockets. The horrible picture lights in the office look worse from behind, just a hammer hole in the wall and two lumps of cable All this has to be done with care because there is already one car in the workshop along with the tools and racking. Plenty of room in the skip for the other side bits of plasterboard and nearly all the timbers will be repurposed so all the screws and nails are being removed as I go along, less work later that way. The reason I'm being careful with the dust and debris is the Fiesta bonnet which is still awaiting the second clear coat. Considering it was done with rattle cans I think this is fair for a first clear coat. I'd like that gone so I can have at the wall but with the weather being so moist I was reluctant to do clear coats in case it bloomed. You can see my nice tidy labelled racking in the background, luckily it was a perfect fit behind the door. 3 bays, 3 boxes per shelf, 5 shelves per bay. I have a similar layout planned for the other side of the room but may have to relocate depending to car widths and the hole in the wall. Going to move that bonnet and have that other bit of the wall down tomorrow. With all the water that came in the other day and the unevenness of the floor I think I need to get it levelled. Either screed or self levelling compound or both. The office has one L shaped patch thats not level which should then become part of the workshop floor.
Jun 14, 2019 22:24:29 GMT
No photo's tonight as no one wants to look at stacks of tyres. That was tonights mission, move all the wheels, tyres and load them onto the racking again. Lifting 16" transit wheels up onto tyre bay racks is a good workout. I think there is about 50 odd rims, tyres and complete wheels altogether, my fitbit went mental. Second coat of clear applied to the fiesta bonnet, shut the door and went to move stuff. came back two hours later and it's got a couple of fisheyes They were not in the first coat so must have picked up some muck even after being tack ragged just before paint.
Jun 16, 2019 21:37:08 GMT
Sunday 16th June - Got a couple of hours in today. I have been asked to vacate unit 7, the temporary storage area, by the 24th of this month. Unit 6 is not yet watertight, does not have a flat floor. Neither of those I can rectify on a Sunday afternoon with no budget If I move all my stuff into 6 I'm effectively blocking it up entirely, no way the floor is getting done once all the junk is moved. I need the floor down ASAP. Time to finish getting that wall down then. I'd already cut the plasterboard so it just needed the electrics moving out of the way. Switched off at the consumer unit and removed the crappy wall lights which have been skipped because they were awful. Wiring was all terminated in block connectors so pulled the wires up and fixed the slack back above the ceiling. I've done the same with the socket sort of, left the socket attached and pulled that up too. With those out of the way I finished cutting the plasterboard, grabbed a crowbar and did this. I'm a little wary about removing that many vertical joists even from a stud wall. The only bit of timber that will span the gap is supporting the joists and fixed to the floor Working in towards the centre I took four out, two each side, which made no perceptible difference whatsoever, nothing seemed loose so took one more out. This time the saw started to stick a little on the last 1/8th". It came out without too much bother though. Put it back in place with a small ally wedge under it to take any tension and went for the last one which again came out without even binding the saw. Left to its own devices the last wedged support was no tighter than before, still no weight resting on it so pulled that out too... not a twitch from the roof, all stayed in place. That was a releif. The joist going across the bottom was freed off and removed, denailed and then screwed up to the stubs I left between the two bits of plasterboard. Now it looks like this. That'll do for now I will fit some diagonal supports at the sides, just in the corners. That'll have to wait until I decide how to make a door for it. All that and home before dark.
Jun 19, 2019 22:52:50 GMT
Tuesday 18th June - Those moments when you realise the shelves that took hours to put together are in the wrong place. Bad planning on my part. I thought I had enough shelves to rack out two and a half walls leaving some spare uprights over for another ,smaller depth, rack in the entrance hall. Turns out some of the shelving has bolt holes in the wrong place and it throws the racking out of line making it awkward to get the bolts in. Decided it was better to move and re space some of the stuff that will work properly and use the odd ones as a second standalone unit somewhere else. Tonight has been spent taking to right ones apart again after clearing all the stuff off them. These are the ones that are being relocated. Wednesday 19th June - Spent this evening putting those shelves back together in the new location and humping boxes from unit 7 onto them. This is the relocation in progress, opposite side of the room backing onto the entrance hall. There is enough room for one more bay on the right which will need another six shelves. Thats space for another 15 - 18 boxes. The boxes on this rack are full of 'carplan' 400ml aerosols, all very old stock but still serviceable . No more than two of each colour so at some point there will be a rainbow effect car rolling out of the shop. These are the ones I did last week. It's dead handy having a source of white boxes to put stuff in, makes labelling so much easier. I've got a dozen more boxes to fill with stuff thats lying around the place then i'll have to bring more home. I think there will be space for another 18 boxes using the first set of shelves. Each box gets a rough list of contents scrawled on the outside and eventually i'll work out what order I want them in.
Jun 19, 2019 23:33:41 GMT
Can you see how the ceiling joists are supportive did you look in from the top? I wouldn't be putting anything on top unless there's a beam spanning that gap inside the plaster...
You could fix a bracing plate along the length of it if needed.
Can you see how the ceiling joists are supportive did you look in from the top? I wouldn't be putting anything on top unless there's a beam spanning that gap inside the plaster... You could fix a bracing plate along the length of it if needed. There's nothing on top apart from cables and dust. Ceiling rafters run the other way, there is a 3x2 across the top of the wall in the void and a second one on the bottom which will form part of the door frame. (The one i lifted from the floor) I'll brace that in the corners once I work out how the doors are going to work. The space above the office area is wasted anyway, Might use the high side which is supported, lay some boards to slide panels on but nothing heavy. Area above the kitchen looks stable but there no real space as the roof is lower that end.
Jun 20, 2019 23:21:50 GMT
Thursday 20th June - Days pass so fast when you have to move loads of stuff by a deadline and have nowhere to store it Tonights mission, to move the partly filled skip, move Project X, but first to lob some more shelves up and fill some boxes. Collecting all the bits brought up from Brum on my last trip into boxes was fun, found a few bits that may come in useful later when I'm doing the NCF. With all that stuff that was lying around on the office floor moved into labelled boxes I then had space to start moving stuff. There is still a massive pile of gear next door in the temporary unit, somehow it all has to go in the unit or the skip. I don't want to block myself in and have no room to work so something will have to give. Stuff needs to be moved... I've reclaimed a few of the shelves and filled them. I need to take the rest down and put them out of the way. Rolled Project X outside to move the skip. As I'd half filled it I lifted one side with the engine crane and put a little trolley under it, they're not supposed to hold that amount of weight but apparently they do if applied gently. Moved the engine crane to the other side and managed to manhandle it across the floor, this time it's sat on the 3x2's I took out of the wall. Wiggled the Phaeton around and reversed it back in, rolling it back into the 'office'. Somehow the space looks SO much smaller with a car in it, Its not like the phaeton is large or anything. It only fits part way in until I move the wishdasher and that shelving... It just looks massive. I'm sure I'll manage to squeeze all the stuff I want to keep into the space, in the mean time I guess it might just get put on pallets in the workshop. The dust levels are decreasing too, possibly down to sweeping up everytime I go in there.
Any area you you can erect scaffolding over a car or something for a bit of attic space?
I had enough space in the old unit but it won't fit in this one. Roof is a lot lower, square area seems smaller. there will always be that one leg in the way in the middle of the room.
I really wanted to get the floor done before I had to move everything into the space but in keeping with tradition, I have to comply with the letting agent / Landlord's decision and move in a rush.
Friday 21st June - Started by rolling the car into the workshop and clearing the area behind it. Cleared and removed the shelves so I have more room to manoeuvre. The content was mainly odds and ends from the 'I have no home for that yet' pile so they have all ended up on the big table. They'll keep there until I get the rest of the stuff in from next door. With all that gone the car fits much better. While it was out I fixed the storage boxes to the wall too. These came from a BT van just like the one I had as an engineer back in the 90's. There is a steel bracket behind them, one for each stack. These screw to the wall and the storage boxes slide down into them. If any one has some of these they wish to part with let me know. They come in two sizes. large ones three wide, smaller ones four wide. They have a wire retainer that keeps them shut in the van. Could really do with another couple of banks like the ones above so going to try Ebay as well, see whats about. I have yet more shelving which is narrow and can go in the kitchen, entrance hall or behind the wheel polisher as well as the stuff I took down tonight. Another single bay which is much wider, that is what went over the top of the polisher in the other unit..
Aug 30, 2019 20:30:18 GMT
Neglected to do this for a bit as I've been tied up doing other stuff. I was going to do a massive update but... From the beginning of this thread I have been using Tinypic to host the photo's. Well it turns out that actually belongs to photophuket and as from the 29th of August access from 3rd party websites (such as retrorides:( ) will be stopped, what a surprise. Now I have to open a second Flickr account, move loads of images from one site to another, re-do all the links Grrrrr. Massive update will have to wait until I sort a new photohost.
That was fun, still got to move the old ones from tinypic but I now have room on Flickr for a few so here goes. This may start a little randomly but I will edit stuff in tomorrow. First off, meet my new assistant. Bit nervous, won't come withing 20 ft of me but is happy to grab the odd treat off the floor outside. Despite being a cat person I don't really want to encourage the local moggies inside in case they stay in when I lock up, there are an awful lot of boxes lying around and anyone with a cat knows what happens if you leave a cat and a box alone in the same room This is the best shot I have of my primary assistant and currently chief critic. I've take to calling him Shadow (think it's a him... not going to worry about checking) I've had to still frame a video to get one as every time I get the phone out he comes and butts it with his head. He is quite happy to be close when I'm banging and grinding so either completely deaf or doesn't give a fig. I'll go with the latter as he answers when I talk to him. ( I work alone... see what happens ) Shadow turns up pretty much every time I go round now, especially when I'm in the Transit. This is going to get awkward as I don't want to shoo him out or scare him off. At some point he will need medical attention as he looks like he's been on the rough end of a beating, There's not enough trust yet to capture him but it will come. A proper yard cat, I'll have to train him to look the other way when i'm welding. He follows me round, meows away like a nutter until I get the treats out then I can entice him outside, leave a few treats and shut the door. Project 1 update - well on it's way to being restored, suspension, engine, gearbox and part of the body refitted. I'll edit in pictures when they arrive. Project 2 update - the dinghy. went away and on it's second or third trip had an argument with the trailer tie down loop. This involved more fibreglass and an angry grinder, followed by welding the loop back on in a different location. Adding two sets of twin rollers to assist with loading. Thats been tested and all seems fine so hopefully thats finished now. Project 3 update - the paint suppliers gave us some sort of scratch resistant 'memory' clear coat. Sadly it would appear that sanding it down then mopping out means it will forever return to a flat state. I don't understand how but thats what's happening, looks like i'll be doing the job again but with a different clear coat. Project X - The Dutton Phaeton. Last time we left it like this with 2 inches of rubber poking outside the front arches and nearly 3 inches at the back. I've not done the back yet as i'm having a set of extentions laminated up using the original moulds. The front however has undergone a slight alteration. Theres more temporary bracing on there than a buck tooth teenager. Wheel radius and arch radius matched, lowered by 30-50mm and widened by 100 mm in total. I'll go into more detail as I put it back together. I've not quite finished chopping bits off yet. The bonnet is series 4 Dutton Phaeton, the replacement body skin is Eagle P21. Now essentially they are the same on the surface however where the bonnet rests on the body skin it's all wrong. The bonnet needs bracing into shape then altering to fit the body skin. Once the back is matched it'll improve. I'll write more tomorrow, been a long day and it's 1.30 am or near enough.
Last Edit: Sept 2, 2019 21:23:27 GMT by Rebuilda: Edited in a Shadow.
Darkspeed
Club RR Member Number: 39
Thankfully when I made the front track on the B+ wider I had the option of taking the easy route with cycle guards. The rear of the car had already had the arches stretched 2" - Now the new owner has decided that Starmags are the order of the day, same as he had on an S1, instead of the very wide Comp split rims we have the job of reducing the rear width by 2" !!
Nice to see the project getting some attention - messing about with an S4 takes me back a few years.
Sept 2, 2019 21:12:46 GMT
The bonnet section became very flexible when I sliced the wings off it. I decided it needed some structure so I've got 2 22mm alloy tubes curved into the edges of the long part. They're just clamped in at the moment but will be glassed in along with a couple of cross braces. If I'm feeling really brave I'll break out the ally mig and weld the frame up once its got all the bits cut in. Here you can see just how far it's been stretched. I'm hoping to retain all of the elements on the front that define it as a Phaeton. The air intake area will be larger and the indicators will be replaced with LED DRL's. I'm hoping to use the LED headlights with the built in angel eyes that turn amber when the indicator is engaged but we'll see. The section to the rear of the wing will be ducted into the engine bay to evacuate some of the hot air from the radiator.
Sept 2, 2019 23:20:00 GMT
On the building front I reckon we are about 90% watertight. I still get a little creeping under the back door if the wind is wrong but the front has been clad and they are currently adding the finishers to tidy it all up. The cladding stops above my front door and that leaves a section of wall they need to finish too. If the wind is blowing in the wrong direction and its tipping down I still get leaks around the front door shutter and as the floor of the unit is below the frame it gets in and puddles I'll perfect the door seal in due course. Upto now I have been using the much recycled bits of two V twin 50ltr compressors. One works, the other has been cannibalized for parts to make that happen. A customer came into work and asked if I wanted a big compressor, he is down sizing and only needs a 2hp 50tlr now instead of his old one... Intrigued I went and took a look at this 'old one' and he wasn't kidding. I'll post pictures tomorrow but it's mahoosive, 3 phase and belt driven. 13mm V belts, yes belts, three of them. Its also about 50Db quieter that the V twin. It's lived outdoors under a canopy since 1968 and can still build 200psi fairly quickly, properly engineered to last. I bought him a new compressor to his spec and loaded the monster into the transit with a forklift. It's now on a pallet inside the unit until I can get the 3 phase socket repaired out in the shed where it will be installed. Whilst on the subject of compressors, we have a couple in the shop. A 160ltr Clarke dated 1996 which has been converted to single phase with a new motor from Machine Mart (that cost more than the replacement I bought Bob) and a new 100ltr Draper. Both are belt driven. We now do headlight polishing and I needed air tools. I only really need one so the other will either end up in the garage at home or get mothballed incase one of the two monsters fail.
Sept 3, 2019 21:32:19 GMT
If you're not into compressors skip this bit. This is the plate on the tank of the 'new' compressor. It has a date stamp of 31st June 1968 which makes is 5 and a bit years younger than me or 51 years old depending on how you look at it. It weighs a lot. I haven't tried moving the pallet yet but it's gonna be some lump to manoeuvre. I've been told it switches off before 200psi which is scrawled on the side as the safe working pressure. I'll see when I fire it up I guess. No pressure there then So apparently it's an Ingersoll Rand type 30 and the motor is... The motor must weigh a bit, it's got its own lifting eye. The actual compressor engine is massive and has two odd sized cylinders. But you only get a proper idea of scale when it's sat next to a 24l 2hp modern compressor. I think that'll do to whizz round a few airtools
Darkspeed
Sept 3, 2019 21:44:49 GMT
Is that mud hole inspection cover I can see in the side as well? 3" and 5" cylinders 3 1/2" stroke perhaps - with that up at 200PSI that's a massive amount of stored air - and energy - looks a well engineered bit of workshop equip that's for sure.
