tofufi
South West
Read the whole thread today. Great work, and it looks like it's rather entertaining to drive too. I always remember seeing one parked by the side of the road as a kid. Must have been one of the last survivors before they were withdrawn
i remember going to Beaulieu and getting in touching distance of richard hammonds DamperVan (remember the amphibious car challenge here he made a canal boat made from a T3 camper) every internal cavity other than the cabin was filled with expanding foam. eek.
There's a full set of NOS bodywork for this on ebay now - currently at £100!
Read the whole thread today. Great work, and it looks like it's rather entertaining to drive too. I always remember seeing one parked by the side of the road as a kid. Must have been one of the last survivors before they were withdrawn It's a lot more entertaining - and not terrible - to drive than it's got any right to be given their reputation. Granted I probably get a few additional comfort points with the replacement seat...but it's nowhere near as terrifying, slow, tippy or blatantly unsafe to even walk past as I was expecting. There's a full set of NOS bodywork for this on ebay now - currently at £100! Thanks for the heads up. I actually bid on this last time it came up, but apparently eBay's software can't always keep up with the inevitable sniping in the last seconds as I apparently didn't win it, despite the end bid being a good £30 below the max bid I put in (about two days before the end of the auction... I've not the patience for sniping...if I want something I'll just bid what I'm willing to pay...if it costs me a few quid more then so be it). I'll keep my eyes on this, but I think there are a lot more people interested in these things out there than there were when it came up last time round...so I suspect it'll go for quite a substantial price.
Last Edit: Jun 7, 2019 22:12:41 GMT by Zelandeth
Jun 14, 2019 18:49:38 GMT
See that lot went for close to £700. Do think there was a far amount of schill bidding going on though....🙄
Given it went for £75 odd last time round that's quite a jump!
Never fear, it will be advertised again next week ,”due to time waster” no doubt 😂😂
Last time I was out in the Invacar I got caught in a moderately heavy rain shower which did a really good job of demonstrating how laughably lacking the weatherproofing was. Especially around the windscreen...which is a pain as due to the driving position being quite far forward the water from there drips right on your knees. The main issue here being that the seals have both perished and shrunk. As a result of that the water seeps in between the glass and the seal, there doesn't seem to be much that actually gets in around between the seal and bodywork. The rear windscreen doesn't seem to be so bad - most likely due to the reverse rake of it keeping it mostly dry and any water that does get in tending to just run down the bulkhead. There was however a big gap where I assume there should be a plug at the end of the seal. This gap looks far bigger from inside. The long term solution of course will be to get a new set of seals. However I don't have those on hand currently and I'd like to be able to use the car this week given that I seem to have a lot of cars with gremlins this week...so I can see the Invacar getting a bit more use than it's been used to up to now. Being weatherproof is likely to make it rather more attractive to drive. So I'd like to do something quick. Sikaflex to the rescue I think! I got out some (decent) masking tape to keep the stuff where I wanted it, and set about giving the seals all a good coating to fill all the cracks in the rubber and about a millimetre overlap with the glass and the bodywork...so it should hopefully both keep the water out and the windows in. The windscreen used to have a gap similar to the one I pictured earlier on the rear one, but it was halfway up the offside of the screen - that's now covered up as well. So that should be one less ingress point. Likewise the rear windscreen is now gap-free. While I'm thinking about it, here's a better shot of the interior as it appears now I've got the freshly painted panel above the screen in place and the pillar trims also painted. Think it looks period appropriate and the black is a nice contrast to the light blue. Yes, there are some paint runs in there I need to get tidied up. The switches you can see sitting on the dash are these... These will be for the electric fan I intend to add to the heating system (demister switch seemed suitable for that, and this one will match those already on the dash), and in future to provide me with a low brake fluid warning light (the switch provides a test feature for the lamp itself). Haven't 100% decided exactly where I'll put them on the dash yet, but probably over by the handbrake most likely. Masking tape was removed when the sealant was about 75% cured to leave a nice clean edge without leaving streamers of gooey sealant or tearing half of it off with the tape. Will attack it with the hose tomorrow if it's not raining and see what the results are like...Fingers crossed my knees will remain dry next time I have the car out in the rain. The sealant itself can be removed easily from the paintwork so long as it's not fully set by using those wipes intended to go over a panel with immediately prior to painting. Also useful for getting it off your hand when you hadn't spotted there was a hole in your glove, so you ended up with a glove finger entirely full of sealant. Note to self: Use sturdier gloves next time...
Criticising the previous, having the join at the top of the windscreen (or side) seems like a school boy error too
Might be a bit less noisy too? (he says knowingly, sharing a plastic container with flat oppo engine)
Club RR Member Number: 160
Any windscreen fitter worth his salt will carry or at least have that seal in stock to cut to Length. My local tame glass man does anyway. I need to get him to do my Romini caravan for the same issue. Gap at the top of the seal where it’s shrank over time.
Jun 16, 2019 12:54:17 GMT
If I had a tame windscreen fitter I'd probably have checked whether they had the seal in stock - however I've been struggling massively ever since moving down here to track down competent tradespeople in virtually any field. I've got actual garage and metal fabricators covered now, but not much else.
If anyone wants to suggest a good source in the general area of Milton Keynes I could support with my business, fire away. I'd far rather support them than some nameless foreign corporation via eBay etc.
As for the positioning of the gaps in the seal? Not guilty... that's where they were when I got the car. Guessing the join should be at the bottom ideally?
glenanderson
Club RR Member Number: 64
Jun 16, 2019 15:42:21 GMT
Oddly, I think it’s general practice to put the seal join at the top, and the filler strip join at the bottom. Normally you’d cut the seal at least 2” longer than it looks like it needs to be, and that both compresses it to ensure a good seal, and allows for future shrinkage as it weathers. The screen seals on my Austin have also shrunk, but not quite as dramatically.
Jun 16, 2019 17:13:18 GMT
That type of seal is still widely used in the boating world, there must be boat yards serving the canal network around your way.
Useful to know it's a seal type used in the marine world... I've got friends back up north who work in the offshore engineering field too, so they might well have a supplier they know... Having done a bit of testing it does appear that both front and rear windscreens are now waterproof. Haven't actually subjected it to sustained rain yet, so we'll just have to see how it goes. Finally had a chance to do a bit more bodywork reconstruction this afternoon. The foam based corner now looks like this. Obviously some serious sanding action needed, but definitely heading in the right direction now. Reckon I'll need to take a bit off the outer radius of the bumper, but I've kind of done that deliberately as it's far easier to take a bit extra off than to add extra material. This stuff is *way* nicer to work with than what I was using before. Will see how it sands, but in terms of application it's streets ahead of the stuff I've been used before...it actually holds its shape when upside down which was really handy when forming the lip along the bottom of the body. This is definitely getting bought again in larger quantities as I get a feeling it's going to be a useful addition to the toolbox. Have given the underneath of the service cover a skim over as well, hoping that will help strengthen it a little as it's suffered from being quite bendy so far due to the old damage. Covered over a lot of the pits in the top surface too...have to see how it looks after sanding.
Last Edit: Jun 17, 2019 0:34:00 GMT by Zelandeth
vanpeebles
I am eastbound in pursuit of a white Lamborghini, this is not a recording.
I read on a football forum, that years ago, some grounds would let invacars in, to park by the corner flag in the corners of the ground, so disabled fans could watch the match. I wonder if there are any photos about?
cati69
Jun 17, 2019 16:36:41 GMT
I read on a football forum, that years ago, some grounds would let invacars in, to park by the corner flag in the corners of the ground, so disabled fans could watch the match. I wonder if there are any photos about? yup.....
Jun 17, 2019 17:18:39 GMT
Last Edit: Jun 17, 2019 17:19:09 GMT by strikey
Jun 17, 2019 18:49:11 GMT
unrelated, but kind of related, this popped up on a spotted facebook group, Acoma Comtesse. my favourite things about it are the stabiliser wheels, it also has a gulwing door on the nearside, and is front wheel drive !
Last Edit: Jun 17, 2019 18:56:40 GMT by darrenh
