Aug 15, 2019 12:09:10 GMT
Cheers for the links folks, I'll keep them in mind in the future. As it is I've got 20m of cable and a heap of ends on the way so should be set for a while hopefully once they arrive. In other news, I have paint! Took a bit of discussion to come round to what was probably the best compromise in terms of being sprayable with the equipment I have, being suitable for the substrate, and not being horrifically dangerous so as to require a respirator with a remote air supply. We got there in the end though. £11 for a litre if I remember right - and a litre should go a lot further in a proper spray gun than in rattle cans if my prior experience is anything to go by. The Halfords rattle cans were the best part of a tenner each. Yeah...this should save me a few quid. This paint has really good high build properties apparently, so all the better for scruffy fibreglass. Picked up a suitable mask while I was there too. Didn't even come close to having time to get the spray gun out yesterday, but couldn't resist having a peek to see what the colour match looked like. It's really hard to tell in the can obviously (especially under artificial light), but it looks a decently close match for my purposes. If anything it's slightly lighter than the Halfords paint, which if it's not a perfect match is what I'd prefer. Worth noting that the engine cover in shot there has several coats of clearcoat on as well, which this paint shouldn't require. So that may also explain why it looks a bit darker. No, there would have been nothing to stop me getting them to mix up the original colour at this point - sticking with this Ford colour is a purely personal choice at this stage. I just like it better. No idea if I'll have a chance to get anything done today at this stage....but I'd obviously like to get some spraying done. Another part for the Invacar arrived this morning in the post (which I'd totally forgotten ordering). The blade I'd been using was stuffed despite having been on there only a few months and nobody locally stocks 10" ones any more. Nor do any of the refill kits I have fit (the blade is too fat to fit in the retainers)...so I just ordered one. Figured if I was doing that anyway I may as well get something that looks vaguely in period. I'm not holding out much hope for it actually being even vaguely useful in terms of actually clearing the screen - but at least it won't scratch it when I forgot the existing blade is knackered and turn the wiper on in error again. I've already got very lucky in that regard twice.
Aug 15, 2019 14:14:37 GMT
well if it gives you any comfort ive used loads of HMG 1k and its been fantastic. i even rollered my garage doors with it! (and one of them is wood!)
Last Edit: Aug 15, 2019 14:26:15 GMT by darrenh
glenanderson
Club RR Member Number: 64
Aug 15, 2019 15:13:07 GMT
Series 2, 2A and 3 Land-Rovers use 10” blades (as do 2CVs I think), and they’re as cheap as chips from mail order suppliers. That said, my local factors had some at under £2 each too, the last time I needed any.
Aug 16, 2019 21:46:20 GMT
Had an opportunity to do a very quick test of the paint yesterday evening - which was basically 30 minutes setting up the spray gun, wiping the panel down, then the same to clean the spray gun out. Actually painting covered about five minutes. It's pretty obvious that this is going to be an order of magnitude easier than messing around with rattle cans. The green blob on the floor is a fair amount of the original paint matching test, spilled courtesy of next door's cat. She is a menace. No huge loss though given the neon peppermint colour didn't seem to really match anything well on the car. It's not been put down nearly thick enough, I'm fully aware of that. This was just a quick test - a bunch of masking and cleaning will be done before I hopefully do a reasonably complete run round the car. Shouldn't take me long to establish how far the paint is going too so I can see if I need to go and get more well before actually running short. It's been a while since I've had a decent A2 rated respirator on. Having a bit of equipment which successfully totally filters out the smell of solvents is *weird* I tell you. You kind of expect goggles to restrict your vision, ear protectors to muffle sound...but to have a little plastic thing that does little to restrict air flow essentially be able to turn smell on and off is something which messes with my head a bit. Effective though - was utterly oblivious to how strong the garage was smelling until I took the mask off (after airing the garage out a bit too)... should be effective though given that's why I bought it. That was where we left things yesterday. This evening I had a bit of time to do a bit of further testing. Step one was to get everything masked off so I can stop worrying about getting paint where I don't want it. Bit further spraying was done. Definitely looking a million times better now the front end is mostly one colour. If you ever wondered if it's worth wearing a mask...well here's what the particulate filters look like now after about an hour and a half. They were white when we started, and this process has produced about a quarter of the amount of garage fog that the rattle cans do...so yes, make sure you're wearing the correct PPE. It's somehow reassuring to actually see evidence of the filters doing their job. The only issue I seem to be having is actually getting enough paint onto the car. Think I'll need to experiment with a bit more thinners than the instructions actually recommend to see what happens. Will do a bit more experimentation with paint mix over the weekend and see if I can get a thicker layer put down (without ending up with runs of course). Feels like we're heading in the right direction, even though there's a fair way to go yet.
Aug 17, 2019 19:39:06 GMT
Definitely struggling with the spray gun a bit. I don't seem to be able to get any sort of a wet edge laid down no matter what I've done with the settings and the paint doesn't seem to be atomising all that well, hence the pebbly texture we seem to be getting most of the time. When covering other colours (like the grey primer on the roof front edge) it was immediately apparent how thinly the paint was going on too. I did a little experimentation with thinners and found that I could get a decently "wet" spray - but at such a point that the paint was watered down to the extent I wound up with odd effects where the pigment had run...so not really a solution. I think the £18 spray gun may need to be eyed as a possible contributor to these issues...I don't think air supply is an issue as I've verified I've got suitable pressure at the delivery point (not just shown on the regulator). Every now and then it will sputter for a second then give me a few seconds of actually decent spray...so there are some spots where things are actually glossy. Bit frustrating to be honest as so far I've not come close to matching the finish I was getting from rattle cans (admittedly at about ten times the price) beforehand. As demonstrated by the engine cover below, where it caught the rain a little yesterday evening when the back end was sticking out the garage door a bit. We'll get there I'm sure...just going to take some time and experimentation I think.
Aug 17, 2019 20:06:21 GMT
I'm in no way an expert on these matters but if its not atomizing nicely might the nozzle be too big?
Edit, i only say this as when i painted my van i got great results using my little (cheap) gravity door shut gun bit stuggled with my mates (cheap) suction gun. It was only after i realised the nozzle in my mates gun was a bit too big for what i was doing. It was doing the same kind of thing yours is.
Last Edit: Aug 17, 2019 20:08:16 GMT by VW
glenanderson
Aug 17, 2019 20:24:31 GMT
I'm in no way an expert on these matters but if its not atomizing nicely might the nozzle be too big? Edit, i only say this as when i painted my van i got great results using my little (cheap) gravity door shut gun bit stuggled with my mates (cheap) suction gun. It was only after i realised the nozzle in my mates gun was a bit too big for what i was doing. It was doing the same kind of thing yours is. I was going to ask if you’d tried adjusting the needle setting on it. Play with just some thinners on something that doesn’t matter.
Aug 17, 2019 21:03:28 GMT
Have you tried rollering it on, I`ve used rollers with polyurethane on boats to good effect.
Aug 17, 2019 21:39:53 GMT
lets see a picture of the spray gun.
Is it gravity fed or suction?
Do you strip it down completely after each job?
Gravity feed, and this is the third time it's ever seen paint. Everything that comes off has done so after each use. Bought new a couple of weeks ago, so not been sitting with old paint clogging it up for decades.
Just the thinners sprays lovely. It's just with the paint it struggles. I did get it to behave well at one point, but that was watered down to nearly 1:1 rather than 5:1 (paint:thinner) which is the maximum recommended dilution on the sheet which came with the paint.
The only way I seem to be able to get any appreciable flow through it is to have the needle wound wide open, though from the comments about jets being too large I do wonder if there's mileage in further experiments at the other end of the scale. Though I've always started out as per the manual with everything fully closed and just increased until I get acceptable results...though I've never really got that far to be honest. Yet.
Yeah photos of the gun will help. Also, pressure through the gun is crucial. Aim for approx 2 bar at the gun. This will require a higher pressure on the tank regulator due to pressure drop through the line
Regards paint, too much thinner will actually cause the colour to become dull as it dries or 'drop back' in painter terms. Mixing cups can be bought for pennies each and provide an accurate way to mix paint if you don't have any.
Try 10% thinners but slightly warm the paint in a tub of warm/boiling water, you want the paint to be 20 odd degrees. This also lowers the viscosity without over thinning the paint.
Incase your not familiar with spray guns you have three main knobs - one on top/side to control spray pattern (wide fan & jet like) this should be set to wide fan. - next one is inline with the tip on the rear and is the fluid needle , this controls amount of paint passing through gun. Full clockwise is closed and typically 2-3.5 turns out from here is suffice depending on paint. Turn in if you want less paint & turn out for more paint. - final knob at bottom controls airflow through the gun. This should stay full open. Any adjustments should be made at the regulator.
Once again,this is my advice and some people may do it differently. But if you have any questions don't hesitate to ask 👍👍
Edit** Sorry, I didn't see your reply above until I posted this. Apologies for sounding condescending with the spraygun explanation.
Last Edit: Aug 18, 2019 0:42:51 GMT by kent24v
Not condescending at all. It's really useful advice and confirms I'd translated the Chinglish from the manual properly. Air pressure was set based on having a T-piece attached at the gun with it wide open. 30psi the manual asks for was about an indicated 40psi on the reg - though it goes to 150psi, sothe gauge probably isn't the most accurate. I've seen exactly the effect with too much thinners in the paint, so am aware of the dangers of that. Our garage is well insulated, ambient temperature was 23C, even before the compressor started chucking heat out. I'll try to snap a couple of photos tomorrow if I get time, but this is the gun I've been using if that's useful for anyone.
Aug 18, 2019 13:32:54 GMT
That's a 1mm nozzle, which may be a source of the problem. The fluid needle will need wound out a fair bit but even so this may not get the paint to lay as wet as you would like.
Try winding the needle out almost full and slow your travel speed across the panel down with a 75% overlap on the spray pattern. This along with warming the paint and 10-15% thinner should go a long way in achieving a better finish
Aug 18, 2019 14:01:47 GMT
1mm nozzle? I was using celly, my little gun has a 0.6mm nozzle and sprays nicely and the paint lays down well. My friends bigger gun had a 0.8mm nozzle and it wasnt atomizing fine enough to leave a decent gun finish, like your saying yours is doing.
I know paints differ and ive no idea what your paint would need but this all seems familiar to me.
I'm a total novice at this paint spraying thing though.
Aug 18, 2019 18:17:41 GMT
Spray painting is a real art, i'm a pro and sometimes it just throws a curved ball. Paint is very fickle 1mm nozzle isn't ideal for full panel spraying, my guns are small detail ones as i now work as a Smart Repairer and these require samll nozzle sizes. Paint should 'break away' from the edge of your mixing stick as you pull it out of your thinned paint, The colour should remain covering the main area of the stick but the alloy/ stick colur should be visble on the very edge. sorry for the vagueness but it's just a 'by eye' thing i've learnt from 31 years (man and boy, oldest job in the world ) 50% overlap on each pass with a slow arm movement about 30 cm off the panel. I'd offer to help spray your Invacar but i'm a fair way from you.
1980 Vauxhall Cavalier MK1 1970 Mobyleete 40T custom 1978 Mobylette 50V 1965 Moulton Standard 1979 Raleigh Grifter custom 1980 Raleigh Grifter 1982 Raleigh Grifter BMX custom 1982 Raleigh Bomber 1987 Strida
Aug 18, 2019 19:04:54 GMT
That sort of eyeballing the mixture trick is the sort of thing that it's invaluable to pick up on.
I've done a bit more experimentation today and I think the observation that it's not an ideal setup for full panels is spot on. I've been using a random box in the garage as my test area and have had a nice spray laying down there - but it's a very small area. Back on the car it felt like I was blowing paint down a straw again.
If the surface was pristinely smooth it would probably be fine, but being less than stellar glass fibre (even discount my ratty repairs) I think is making throwing a reasonably wet layer down more important than it otherwise would be.
I do wonder if some of the modern paints are just thicker by nature, this stuff is obviously far thicker than any cellulose I've used (which is the only thing I've sprayed with before - albeit a couple of decades ago and was handed the gun already set up). Obviously that can be somewhat compensated for by adding thinners, but there are limits to what you can get away with there...though the trick mentioned above is definitely something I'll try.
Aug 18, 2019 22:46:06 GMT
1mm is small - as stated it's ok for touch ups etc. I don't know how viscous the paint you are using is - but I'm assuming fairly viscous.
You really need a 1.4 or 1.6mm tip for doing full panels, especially if paint is on the thick side.
It is moderately thick. I can pull numbers from the datasheet tomorrow, but I don't have it in front of me right now. Someone didn't spot this came with two nozzle sizes. Here's the same thing but with a 1.5mm nozzle.Wish I'd spotted that before I bought the 1mm one. Oops.
Aug 19, 2019 13:47:44 GMT
Previous owners??!!
Aug 19, 2019 20:53:32 GMT
