Feb 14, 2019 10:46:37 GMT
I have these steps which are hinged at one end and want to store them horizontally I could use a rope and a pulley to lift them but I would like to have a break in the system in case the rope slips etc I've been using a 1 ton block and tackle but it's SLOW A scale at one end says they weigh 15kg Are there setups for lifting this sort of weight?
Phil H
Club RR Member Number: 133
Feb 14, 2019 22:26:56 GMT
Spring balancer? That will be able to be adjusted to have a slight lifting effect meaning to need to weight/lock it in the down position but only take a couple of kg to pull down?
Either that or play around with a couple of tailgate struts to get the angles right?
Iām assuming it either is, or can be, hinged at the upper end?
Last Edit: Feb 14, 2019 22:27:50 GMT by Phil H
Yes it's hinged at the top
Thanks for your input. I'm thinking about a counter weight extended past the pivot point
Feb 18, 2019 17:49:53 GMT
Hand winch Like this Mount it on the wall with a pulley wheel in the rafters etc And you can just wind it up and down Very cheap to buy off eBay/Amazon We use them at work for the lorry load levellers
1992 240 Volvo T8 1955 Cadillac 1994 BMW E34 M5 (now sold ) 1999 BMW E36 sport touring x2 1967 Hillman imp Californian "rally spec" 1971 VW bay window (work in progress) 1999 Mazda 323F 1987 Jaguar XJ12 All current
Feb 18, 2019 18:57:34 GMT
if its only a 15kg lift you need , i would simply rig a couple of pulleys and rope which will give you enough mechanical advantage for an effortless lift. if you are worried about it slipping out of your hands when raising just run the rope through a cam block , on lowering simply take a single turn around a cleat which will act as a brake .there's no need to over complicate it , proper k.i.s.s principlal stuff
Feb 18, 2019 19:15:16 GMT
Great stuff
If I hadn't gone with a pulley system I would have bought a winch like that
But I saw this video and knew what to do
I've ordered an old industrial triple pulley for the top and when it arrives I'll find a double pulley for the bottom
