Alright,
My garage door is an up and over door, it has a big old dent in the front (suspect someone reversed into it), the lock is broken so I have some internal security stuff, which makes leaving annoying as I have to go back through the he side door to lock the garage and then back through it again to open it.
All of which leaves me vexed.
So I am thinking of replacing. They seem to be one of those things you can spend an infinite amount of money on though. So what are your dream garage doors, what are the more affordable ones and what aesthetically pleasing ones have you got/seen (I live in a conservation area so nice doors could be useful!)
Personally i have always loved the look of the 1930s semis with double wooden doors with windows at the top .Something much more appealing to me about two side opening doors than up and over .
Mar 17, 2019 15:17:43 GMT
I have a sectional insulated garage door with Liftmaster LM 8400 opener, remote opener and the power lock deadbolt.I am fairly sure the door is a Hormann unit. You can get optional high lift kits that would allow you to follow the rooflines the garage is of appropriate construction. If I were to do it again, I would wire in for a light to come on when the door opens and also hard wire a button at the person door entrance too. Of late I have been wishing for a keypad external override option too.
MiataMark
Club RR Member Number: 29
Let's talk garage doors!MiataMark
@garra
Club Retro Rides Member 29
Mar 17, 2019 19:29:21 GMT
I went for a roller door, cost me ~£1200 for a single garage, but doesn't take up much space inside, looks good, is probably more secure and very convenient (wireless operation).
Mar 17, 2019 21:46:46 GMT
Can’t say garage doors are something I dream about particularly but I put a sectional roller one in soon after moving in. Put a properly strong header joist in too.
The big advantage is they can be opened vertically. Put a magic eye and sensor lighting in too.
The previous up and over didn’t actually close because it was too tall for the opening! A neighbour said it had been like that since the day it was fitted back in the seventies. Forty years of never being shut!
Mar 17, 2019 21:55:39 GMT
I've got 2 aluminium 20mm insulated roller doors on mine you might see them in the background on my van thread. They are remote opening and alarmed. I paid £2700 for the 2 and they are both just over 3m wide. You'd probably get a single for £1000 ish
Badger
Mar 17, 2019 22:19:21 GMT
I've got a roller door on mine; I can't remember how much it cost, but it's OK. Positives are that it's easy to open, relatively secure and doesn't take up very much floor space (so I can park a car right up against it and still open it). Negatives (in my case) are that it's a bit drafty, it's not insulated and since my garage is quite low it does limit what I can drive in; a "normal" saloon or hatchback is OK, but no larger!
I have a 4 section up & over - 4.3 metres wide - 2.15 metres high - it was already fitted to the garage when we purchased the property For its size it's moves freely by hand and is double skin insulated and I can maintain a reasonably draught free workshop when its closed (critical for someone who undertakes quite a bit of paintwork in his workshop) only downside is that it reduces the ceiling height by 300mm when open - so if I have anything large in the workshop like the Range Rover or a van it gets somewhat tight for headspace I would avoid anything that is only locked from the outside from a security point of view if you value what is inside the garage - I would much rather trapse through the side door to secure the side bolts on the inside of the main door than compromise the security of what is within the workshop
Last Edit: Mar 18, 2019 8:15:10 GMT by Deleted
Wish I could afford doors. One of my garages has a gate to keep the sheep out, the others are all open.
slater
Club RR Member Number: 78
Let's talk garage doors!slater
@slater
Club Retro Rides Member 78
Mar 19, 2019 19:36:25 GMT
We put roller doors on ours a few years ago. Was relitivly expensive but the fact you didn't need to shell out for a frame aswell helped with that. It also makes the opening wider by 4 odd inches which is more useful than you might think also no headroom issues. They arnt insulated but really they don't need to be unless your heating the place.
Hotwire, perhaps the easiest way for a suitable result is to contact the planning department directly (as it's a conservation area) and find out what your not allowed to have. That will narrow down your options and then you can fine tune your priorities, do you want security, sound/heat insulation or ease of use, etc.
It's a sweetshop's worth of options out there (I have the similar problem as currently going through the planning process but for two garages with different uses) and sometimes someone neutral (planning department) focusing your mind can pay dividends. Good luck and remember it'll be three times what you want to spend and twice as much as you budgeted!!!!
mungo
Mar 22, 2019 16:02:30 GMT
I made mine out a couple of sheets of marine ply and painted them green (because Cotswolds ). The opening was just about 7 foot by 7 foot. About £200 all in inc paint, marine ply sheets are 60 a piece !! I got 3 and had a bit left over for some shelves .
56' bug 2332 +ida's 56' lowlight ghia 72' bus 1600 devon 67' type 3 square - gone 83' gti - gone 90' gti 16v - gone 82' chevette - gone 70' GP1 Beach buggy -gone 78' lightweight landrover 3L v6 -gone 89' gti - gone 83' gti - gone
Mar 22, 2019 17:20:41 GMT
I've got 2 aluminium 20mm insulated roller doors on mine you might see them in the background on my van thread. They are remote opening and alarmed. I paid £2700 for the 2 and they are both just over 3m wide. You'd probably get a single for £1000 ish Seems spendy? Found a five metres sectional insulated kit for £800 including opener. They’re an easy install.
Mar 22, 2019 20:54:30 GMT
I've got 2 aluminium 20mm insulated roller doors on mine you might see them in the background on my van thread. They are remote opening and alarmed. I paid £2700 for the 2 and they are both just over 3m wide. You'd probably get a single for £1000 ish Seems spendy? Found a five metres sectional insulated kit for £800 including opener. They’re an easy install. Yep. Very pricey. But a sectional door would take up lots of space when it's open and as I have a 2 post lift I wouldn't be able to have a car in the air with the door open. I would have been cheaper if I'd fitted them myself as they're probably charging a good wedge for 2 people's labour for a complete day, and also the alarm bit was extra too. Not the cheapest but it was all fitted by the time I came home from work.
Mar 23, 2019 21:17:37 GMT
Ah, I missed the “roller” bit - thanks, my mistake.
Nice to come home to as well of course...
May 22, 2019 15:12:55 GMT
When i built my garage a couple of years ago i was looking at all the options.
I decided on an insulated roller door for the following reasons:
Electric Didn't take up ceiling space Sealed along the bottom so prevented droughts and mice.
The sealing all round and insulating were key factors to me and it was a close choice between a roller or a sectional. No toher door can really do this especially traditional up and over doors or two half swing doors. In the end the ceiling space impacted the overall garage height so i went for a roller from Hormann.
Hormann wasn't cheap at all but there were some advantages i could see over others. Be very careful with roller doors as alot of cheap ones being sold are actually shop shutters and rattle and don't have safety cutouts.
The Hormann:
comes in a range of colours Is sealed inbetween the slats Has built in rubber seal at the bottom Furry seals in the guide rails and in the hood The safety cutout works on motor resistance and doesn't rely on a pressure strip added on usually with an ugly bungee cord (optical sensors are illegal) 10 year guarantee Efficient motor Built in light The remotes are programmable to also work gates etc. The door can build itself using clever packaging and an installation program. I did it myself over a fun weekend.
Let's talk garage doors!fr€$h&m1nt¥
@freshandminty
Club Retro Rides Member 99
When i built my garage a couple of years ago i was looking at all the options. I decided on an insulated roller door for the following reasons: Electric Didn't take up ceiling space Sealed along the bottom so prevented droughts and mice. The sealing all round and insulating were key factors to me and it was a close choice between a roller or a sectional. No toher door can really do this especially traditional up and over doors or two half swing doors. In the end the ceiling space impacted the overall garage height so i went for a roller from Hormann. Hormann wasn't cheap at all but there were some advantages i could see over others. Be very careful with roller doors as alot of cheap ones being sold are actually shop shutters and rattle and don't have safety cutouts. The Hormann: comes in a range of colours Is sealed inbetween the slats Has built in rubber seal at the bottom Furry seals in the guide rails and in the hood The safety cutout works on motor resistance and doesn't rely on a pressure strip added on usually with an ugly bungee cord (optical sensors are illegal) 10 year guarantee Efficient motor Built in light The remotes are programmable to also work gates etc. The door can build itself using clever packaging and an installation program. I did it myself over a fun weekend. Sorry to bring this thread back up but I'm currently looking to replace my doors. Did you go for the Horman rollmatic? And are you still pleased with it? Cheers
Oct 23, 2020 13:15:12 GMT
When i built my garage a couple of years ago i was looking at all the options. I decided on an insulated roller door for the following reasons: Electric Didn't take up ceiling space Sealed along the bottom so prevented droughts and mice. The sealing all round and insulating were key factors to me and it was a close choice between a roller or a sectional. No toher door can really do this especially traditional up and over doors or two half swing doors. In the end the ceiling space impacted the overall garage height so i went for a roller from Hormann. Hormann wasn't cheap at all but there were some advantages i could see over others. Be very careful with roller doors as alot of cheap ones being sold are actually shop shutters and rattle and don't have safety cutouts. The Hormann: comes in a range of colours Is sealed inbetween the slats Has built in rubber seal at the bottom Furry seals in the guide rails and in the hood The safety cutout works on motor resistance and doesn't rely on a pressure strip added on usually with an ugly bungee cord (optical sensors are illegal) 10 year guarantee Efficient motor Built in light The remotes are programmable to also work gates etc. The door can build itself using clever packaging and an installation program. I did it myself over a fun weekend. Sorry to bring this thread back up but I'm currently looking to replace my doors. Did you go for the Horman rollmatic? And are you still pleased with it? Cheers Hi yes, it was the Horman Rollamatic. I was very pleased with it and although i've recently moved house, i'd have another in a heart beat. The buyer of my previous house acknowledged the door too, so it can help with house values. For me it was the quality of the build, the ease of installation and the way it had better details than others, such as the safety cutout, the spring tensioned counter weight, the quietness and the seals.
