edessex
Club RR Member Number: 42
Jun 19, 2019 16:55:19 GMT
I have a Midi, use it as a daily and a workvan. Mine is the 2.4TD, which keeps up with modern traffic, column change 3-seater van. They did a floor shift, but only has 2 seats up front. They are Isuzu. They rot badly, but I think most went for export. Parts are hard to find. Second hand parts are few and far between, and usually knackered. New parts are hard to find, they are out there but no-one has crossed referenced the part numbers properly. For example, you won't even find window wipers listed at EuroCarParts, let alone engine components. There are some photos of mine here: www.facebook.com/2wdOffRoader
Jun 19, 2019 17:01:53 GMT
braaap - Really interesting stuff - thanks for sharing (wishes he spoke German)
Jun 19, 2019 17:13:35 GMT
I have a Midi, use it as a daily and a workvan. Mine is the 2.4TD, which keeps up with modern traffic, column change 3-seater van. They did a floor shift, but only has 2 seats up front. They are Isuzu. They rot badly, but I think most went for export. Parts are hard to find. Second hand parts are few and far between, and usually knackered. New parts are hard to find, they are out there but no-one has crossed referenced the part numbers properly. For example, you won't even find window wipers listed at EuroCarParts, let alone engine components. There are some photos of mine here: www.facebook.com/2wdOffRoaderIf you have trouble finding parts ask me and I can check, I have the GM software to find part numbers and contacts for parts
I still have a new tailgate somewhere, a bit knocked about but not rusty!
Jun 19, 2019 17:40:06 GMT
New parts are hard to find, they are out there but no-one has crossed referenced the part numbers properly. For example, you won't even find window wipers listed at EuroCarParts, let alone engine components. ecp is the problem in that statement.... took me 15 minutes to tell the bint working there that yes they do carry oil filters for my 106. then after being told they could supply me FRONT caliper carriers for swmbo's A4 , decided all of a sudden they only carry REAR ones...all that took 20 odd minutes to plough through. rse and elbow spring to mind!!
edessex
Jun 19, 2019 18:07:18 GMT
Just out of interest, what part numbers do you have for the following, reg no. is G585 WOW: -clutch slave cylinder -propshaft UJs Cheers.
I take it they are 4x100?
Could be wrong but are they not a 6 bolt pattern?
Jun 20, 2019 11:55:14 GMT
Could be wrong but are they not a 6 bolt pattern? I’ve only seen them with trims on. What’s suspension set up also?
edessex
Jun 20, 2019 12:31:06 GMT
They're Isuzu, so 6-stud J pattern wheels.
Rear live axle with leaf springs, front suspension is double wishbones and coil springs.
Last Edit: Jun 20, 2019 12:32:01 GMT by edessex
Jun 20, 2019 17:04:48 GMT
Clutch slave cylinder for the 2wd 2.4TD is 94319307, GM don't seem to list the prop UJ for the 2.4 only a complete prop but I think you can use joint 7156340 which changes to 91109415
edessex
Thank you, the clutch slave cylinder I bought tallies with that. The motor factors got a bit concerned because their system didn't cross reference the cylinder as fitting a Midi!
Just one more thing, they did an LSD as an optional extra, don't suppose that part number is listed is it? Thanks, Ed
Jun 25, 2019 18:02:47 GMT
They list either the Isuzu axle or Salisbury axle, its only the Salisbury axle that had the LSD part number 91149262 I think, should think its mega rare!
Jun 25, 2019 19:17:33 GMT
edessex
Jun 26, 2019 22:26:15 GMT
They list either the Isuzu axle or Salisbury axle, its only the Salisbury axle that had the LSD part number 91149262 I think, should think its mega rare! That is some very useful information! Thank you.
I just bought a 1995 midi with 20000 miles on. It's my 1st diesel, its fairly slow but feels good to thrash around. It will kick the tail out at slow speed in the wet which is fun. Column change is quirky. As for rust.. is there any commercial vehicle that’ll last 24 years as a workhorse without rusting. I’m pleased with mine. Done probably 400 miles or more in the last few weeks no problem. I’ll put some pictures on when I remember how to do it
I just bought a 1995 midi with 20000 miles on. It's my 1st diesel, its fairly slow but feels good to thrash around. It will kick the tail out at slow speed in the wet which is fun. Column change is quirky. As for rust.. is there any commercial vehicle that’ll last 24 years as a workhorse without rusting. I’m pleased with mine. Done probably 400 miles or more in the last few weeks no problem. I’ll put some pictures on when I remember how to do it Seen it on Instagram mate, the one I wanted has gone off Gumtree now. The seller didn’t want to give me a contact number as I’m finding a lot recently which I find really odd. I’ve been using my wife’s Facebook to search for cars, so request a phone number and never get a reply 🤷🏻♂️
edessex
I just bought a 1995 midi with 20000 miles on. Was that the white one used to get car parts for a recovery company?
Jul 28, 2019 22:02:01 GMT
Yeah that’s the one. Loving it so far. Lowered it a tad with some pajero split rims. It’s starting to get some kinda look not sure what kind yet !
Jul 28, 2019 22:18:02 GMT
edessex
Jul 29, 2019 19:11:20 GMT
Looks in really good nick, and was up for a cheap price!
If that was about when I was looking, I would have bitten the guys hand off!
