jonomisfit
Club RR Member Number: 49
Sept 26, 2021 20:29:52 GMT
I then spent 30 minutes giving it some test runs up and down the road. Things to think about. The steering is very twitchy. I need to check the toe as I think the tracking is out, but it is cough and you go off the road type twitchy at the moment. The button throttle is very digitial. What I hadnt realised is when you lift off the controller sticks a load of reluctance into the circuit and it braked quite significantly. The brake is almost not needed. The brake needs stripped and re-built. No matter how hard I pull the brake barely funcitons. It was a source of much amusement for my neighbours seeing me driving about in it, and a passer by in a car nearly veered off the road as they went past a little postman pat van. Either that or the sun was shining off the aluminium and blinding them . I took a few pics of the van as I had it out P1050759 by jono_misfit, on Flickr P1050760 by jono_misfit, on Flickr P1050761 by jono_misfit, on Flickr P1050762 by jono_misfit, on Flickr P1050763 by jono_misfit, on Flickr P1050764 by jono_misfit, on Flickr P1050765 by jono_misfit, on Flickr i then spent the rest of the session writting a list of whats needed, and trying out some body mounts. P1050766 by jono_misfit, on Flickr
Sept 28, 2021 22:28:03 GMT
What? Test runs with no video? How very dare you! Great progress
1968 Mini MkII, 1968 VW T1, 1967 VW T1, 1974 VW T1, 1974 VW T1 1303, 1975 Mini 1000 auto, 1979 Chevette, 1981 Cortina, 1978 Mini 1000 1981 Mini City, 1981 Mini van, 1974 Mini Clubman, 1982 Metro City, 1987 Escort, 1989 Lancia Y10, 1989 Cavalier, 1990 Sierra, 1990 Renault 19, 1993 Nova, 1990 Citroen BX, 1994 Ford Scorpio, 1990 Renault Clio, 2004 Citroen C3, 2006 Citroen C2, 2004 Citroen C4, 2013 Citroen DS5. 2017 DS3 130 Plenty of other scrappers!
jonomisfit
Sept 29, 2021 6:46:58 GMT
I tried, but it was a struggle holding the phone and controlling it all. I may look at a mount next time and try recording it.
Sept 29, 2021 8:12:13 GMT
I tried, but it was a struggle holding the phone and controlling it all. I may look at a mount next time and try recording it. I know what you mean. I tried the same thing trying to video me driving our off-road buggy, all very shaky. A camera mount would be a good thing. I was interested to hear your comment about the twitchy steering and we had the same thing with ours. These things must be lethal on the road at 8mph particularly in a crosswind. I'm 99% sure that the problem is that there is no caster angle, certainly the case with ours and that's something we are going to address when we revamp the steering to fit the rack. I was actually quite surprised about this omission because a lot of engineering has been put in by the manufacturers to produce a decent suspension system with adjustable dampers etc. We'll aim for about 5 degrees caster and hope that will sort it out.
tofufi
South West
Sept 29, 2021 8:49:16 GMT
Just read the thread from start to finish. Brilliant fabrication skills and good fun. Bookmarked and in for the journey
jonomisfit
Sept 29, 2021 20:12:56 GMT
I tried, but it was a struggle holding the phone and controlling it all. I may look at a mount next time and try recording it. I know what you mean. I tried the same thing trying to video me driving our off-road buggy, all very shaky. A camera mount would be a good thing. I was interested to hear your comment about the twitchy steering and we had the same thing with ours. These things must be lethal on the road at 8mph particularly in a crosswind. I'm 99% sure that the problem is that there is no caster angle, certainly the case with ours and that's something we are going to address when we revamp the steering to fit the rack. I was actually quite surprised about this omission because a lot of engineering has been put in by the manufacturers to produce a decent suspension system with adjustable dampers etc. We'll aim for about 5 degrees caster and hope that will sort it out. I'm not sure about if its caster angle or not on mine. The front suspension is swing arm hinged in the centre of the chassis (see post 1 on the thread), so the second there is weight on the chassis and the suspension compresses you are into a few degrees caster. This increases as the suspension swings through its arc. I'm going to have a look at the toe as if this was a car i'd say its on heavy toe out. Its also very quick steering which probably doesnt help with the sensitivity. Its ok when you have wide handle bars directly above it, but a small steering wheel (or yoke in my case) will make it feel even faster. its like turning a bike by placing your hands close to the stem on the fork, v's the grips. Bikes feel very twitchy if you do that.
jonomisfit
Sept 29, 2021 20:13:17 GMT
Just read the thread from start to finish. Brilliant fabrication skills and good fun. Bookmarked and in for the journey Thanks! Welcome aboard
jimi
Sept 30, 2021 11:11:20 GMT
When I built this I built the front end with neutral caster (ie none) because I knew nothing about it and it's effect on steering. What I found on the test drives was two things, there was no "self centring" effect on the steering ie after turning you had the straighten the wheel or you kept going round and it was extremely twitchy, slightest movement of the wheel could set off a virtually uncontrollable oscillation on the steering. Eventually discovered this was due to lack of positive caster. I introduced it by shimming the front beam the wheels etc are mounted on. What I discovered was as I increased the the positive caster, the twitchyness disappeared and the self centring effect increased (as did the steering effort, it got harder to turn). I just played with the shimming until I was happy with the steering, bearing in mind my son ( age 4 at the time ) was going to be driving. It turned out really well and the Jeep is easy to drive and the steering is stable at all speeds, the max speed ever recorded on it was 15mph, I had aimed (and geared for 10mph max) but a long downhill path with a 5 year old driving with his foot hard to the floor proved otherwise.
Last Edit: Sept 30, 2021 17:28:05 GMT by jimi
Sept 30, 2021 11:45:22 GMT
I know what you mean. I tried the same thing trying to video me driving our off-road buggy, all very shaky. A camera mount would be a good thing. I was interested to hear your comment about the twitchy steering and we had the same thing with ours. These things must be lethal on the road at 8mph particularly in a crosswind. I'm 99% sure that the problem is that there is no caster angle, certainly the case with ours and that's something we are going to address when we revamp the steering to fit the rack. I was actually quite surprised about this omission because a lot of engineering has been put in by the manufacturers to produce a decent suspension system with adjustable dampers etc. We'll aim for about 5 degrees caster and hope that will sort it out. I'm not sure about if its caster angle or not on mine. The front suspension is swing arm hinged in the centre of the chassis (see post 1 on the thread), so the second there is weight on the chassis and the suspension compresses you are into a few degrees caster. This increases as the suspension swings through its arc. I'm going to have a look at the toe as if this was a car i'd say its on heavy toe out. Its also very quick steering which probably doesnt help with the sensitivity. Its ok when you have wide handle bars directly above it, but a small steering wheel (or yoke in my case) will make it feel even faster. its like turning a bike by placing your hands close to the stem on the fork, v's the grips. Bikes feel very twitchy if you do that. Our front suspension is identical to yours and with the original weight of the scooter plus a lardy driver will compress the springs and produce some caster but the thing we've found is that with everything removed and a lightweight driver, the springs don't compress at all resulting in no caster and a feeling of instability. I agree that the quick steering doesn't help. So what we're going to do is to drop the suspension pivot point so that with no spring deflection there will be some caster and hopefully self-centring and a feeling of control. Should the caster increase due to spring deflection I don't think that will be a bad thing.
Sept 30, 2021 16:59:51 GMT
jonomisfit
Sept 30, 2021 17:45:58 GMT
Thanks.
Its starting to get there.
jonomisfit
Oct 10, 2021 16:33:14 GMT
Ive been busy with work, it was my birthday, and i'm also doing a load of DIY so progress is a bit limited at the moment. Still I did a few bits this afternoon. The main bit I need to do next it mount the body. to do this I need to make sure I'm happy enough with where its all sitting. body off it is P1050767 by jono_misfit, on Flickr trim, align,clamp, and temporary rivet in front wheel arches P1050768 by jono_misfit, on Flickr P1050769 by jono_misfit, on Flickr P1050770 by jono_misfit, on Flickr then rears P1050771 by jono_misfit, on Flickr P1050772 by jono_misfit, on Flickr P1050773 by jono_misfit, on Flickr body back on P1050774 by jono_misfit, on Flickr then a few strategic rivets in place to hold the body down. P1050775 by jono_misfit, on Flickr I c*cked this up and managed to drill it not in the centre of the arch. Which is annoying. I drilled from the inside and thought I had the CROWN, but evidently not. I'll need to weld up and re-drill another time.
sonus
Oct 10, 2021 21:51:46 GMT
Happy birthday!
Last Edit: Oct 10, 2021 21:52:45 GMT by sonus
jonomisfit
Oct 31, 2021 20:46:00 GMT
A bit more panelling needed before I move onto buttoning it all up. A load area for carrying parcells / dollies / engine blocks etc. the normal stuff a 5 year old girl will likely want to move. goes in here P1050777 by jono_misfit, on Flickr a handy note taking location was found P1050778 by jono_misfit, on Flickr I converted it to a piece of aluminium P1050779 by jono_misfit, on Flickr and coloured it in P1050780 by jono_misfit, on Flickr then realised there was a negative probabillity of it fitting in one piece. Cut it in half, then recessed the battery access panel to it'll be flush when I make the lift out panel P1050781 by jono_misfit, on Flickr some drilling cutting and folding P1050782 by jono_misfit, on Flickr a lot of sweary words, shouting, stops, cutting and reforming to get the panels made and in P1050783 by jono_misfit, on Flickr a bit more fettling P1050784 by jono_misfit, on Flickr P1050785 by jono_misfit, on Flickr There is still more fettling needed, and then stiffeners and supports to make.
jimi
Coming along nicely looks very like a Kielder combi in your pic ?
Last Edit: Nov 1, 2021 0:11:00 GMT by jimi
jonomisfit
It is. Its not a bad tool. Better than my old one.
I entered a competition to win some kielder tools where you submitted a pic of your project car. I didn't win but they messaged saying they liked the morris and here's 20% off. It could just do with a touch more torque when I'm trying to drill oversized holes.
jonomisfit
Nov 27, 2021 21:00:46 GMT
After weeks of DIY, family illness etc. I finally got a chance in the garage. Continuing with the rear load space on the postman pat van. A support bracket to fix the bed to P1050791 by jono_misfit, on Flickr trimming out the last bit of this side of the bed P1050792 by jono_misfit, on Flickr P1050793 by jono_misfit, on Flickr bracket for the other side P1050794 by jono_misfit, on Flickr bed in for a test fit P1050795 by jono_misfit, on Flickr some more relieving required P1050797 by jono_misfit, on Flickr all trimmed and showing the access hole for the batteries and elctronics P1050798 by jono_misfit, on Flickr I bought some of these brackets so started bending up P1050799 by jono_misfit, on Flickr tacked a few in P1050800 by jono_misfit, on Flickr P1050801 by jono_misfit, on Flickr used as additional mounts for fixing the body down onto strat rivetting the body onto the chassis P1050802 by jono_misfit, on Flickr P1050803 by jono_misfit, on Flickr then the bed needed some additional supports Cut some ali P1050804 by jono_misfit, on Flickr fold up, ah swagey holes I've missed you, and temp riveted in P1050805 by jono_misfit, on Flickr made another for the other side, then an additional brace for the front edge P1050806 by jono_misfit, on Flickr just need to fix in still, but its a bit tight to drill. Will need the 90deg angle head on next time P1050807 by jono_misfit, on Flickr Will see when I get on it again next time.
Really nice work. I'm loving your project.
jonomisfit
Nov 28, 2021 10:39:34 GMT
Thanks.
I'm getting to the point where I just want this done out the way so I can get back to the escort and the morris!
jonomisfit
Dec 11, 2021 21:28:55 GMT
I've had a fairly pants couple of week laid up with what turned out to be COVID. I was feeling a bit better today, so went out and did some totrod work today. I rivetted in the read bed supports P1050808 by jono_misfit, on Flickr then needed a stiffening strip to support one lip P1050809 by jono_misfit, on Flickr I folded up along the green lines and rivetted in P1050810 by jono_misfit, on Flickr then need a closer plate Cut some Ali and shape it P1050811 by jono_misfit, on Flickr put in some stiffening beads P1050812 by jono_misfit, on Flickr then very carefully drilled and rivnutted the base P1050813 by jono_misfit, on Flickr P1050814 by jono_misfit, on Flickr Its impressive how much it stiffens up the bed a few more rivets in to get it all set P1050815 by jono_misfit, on Flickr then made some little upstands on the wheel arches to finish off and support the front corners further. P1050816 by jono_misfit, on Flickr P1050817 by jono_misfit, on Flickr When I have the whel arches out next i'll weld the tabs on so I don't have rivets sticking through the arches.
