Body and chassis united. Still considering seat options. I'm thinking make a seat something like a Kirkey stock car seat or maybe cut a section out of the stock seat and put sides on to make a sort of old time bucket seat. It's interesting that the kit is difficulty level 5. I reckon if you chuck everything bar the drive train and body tub away, it's probably a 2.
Jaguar S-Type 3.0 SE
Jan 10, 2022 17:56:58 GMT
Things are progressing nicely. The body and chassis are brush painted matt black. Initially it looked a bit to good so I've gone over a few bits to rough it up slightly. I want it to look as though someone found grandpa's Model T in the barn, tore off everything they didn't need, and went racing. Metallic gold was far too bright for the grille shell so I added a bit of black to get a sort of dirty brass effect. I originally planned to run four straight pipes out of the head for an exhaust but there isn't space for a rear one. Instead I cut the exhaust ahead of the silencer and reshaped it over a tealight into a side exit.
Jan 13, 2022 21:15:33 GMT
Axles are on and I've put the wheels on temporarily. I'm not sure about the white tyres but they are all I have. I may try and get them a bit dirty. You might just be able to make out my side exit exhaust.
Last Edit: Jan 13, 2022 21:17:25 GMT by keithyboy
Jan 19, 2022 18:13:10 GMT
The wheels are on. The only things left are the seat, steering, and pedals. I'm going with the standard seat because the one I made looked rubbish. Hopefully it will look stained and worn because I've used about 10 different colours from black to light grey. I've also put the running boards and a few other bits on the Beetle.
Last Edit: Jan 19, 2022 18:13:58 GMT by keithyboy
Jan 19, 2022 22:27:36 GMT
Both looking good.
Jan 26, 2022 17:52:30 GMT
Jan 29, 2022 13:10:49 GMT
The ground clearance on that puts some 4x4s to shame. Lmao.
Jan 29, 2022 17:45:49 GMT
Jan 29, 2022 17:58:21 GMT
Liking that a lot! I'm going with the standard seat because the one I made looked rubbish. Hopefully it will look stained and worn because I've used about 10 different colours from black to light grey. Looks spot on to me!
