Ray Singh
More German exotica in my garage now
It seems that the early 986 boxster has a known issue with air con pipes going pourus.
I have spoken to the forum and at least 5 other chaps have similar issues.
Can anyone on here make up air con pipes and cut/splice in replacements? It cant be that hard, can it?
Any help appreciated.
Ray Singh
Seven Boxsters now in need of treatment - can anyone help please? Potential money to be made.....
longman
Club RR Member Number: 3
Have you spoken to Jonny at Classicretrofit might be something he can help with
Paul 98 500 SL 86 911 Carrera/sold 23 Octavia Phev
take the pipes off and take them to your local hydraulics supplier, they will be able to match them i would have thought? if you where up here i would have said goto manflex in warrington but you not...
Contact your local automotive air con specialist most of these guys have contacts and ways of repairing pipes.
If it is just one local area such as around a clamp there are repair fittings you can buy.
mk2cossie
Club RR Member Number: 77
Or just try Porsche themselves? Cant beat the fit of OEM pipework from experience, and they may have superseded the part to be better as well
alloy or the rubber part? alloy bit is tricky , but hosing is simple for an AC specialist , for Wiltshire try Halls Auto Electrical at Yate or DBS in Swindon
retired with too many projects!
Or just try Porsche themselves? Cant beat the fit of OEM pipework from experience, and they may have superseded the part to be better as well Ray Singh should know this, but you knever know; as being a time long guy, OPCs tend to be cheaper than most people think, with quite a few specialists who should know better, charging more! A great shout about the updates to the hoses. Otherwise, I can recommend two other people: Motorite in Warwick - they may tell you to go to the dealer however . dickdasterdley ; he makes hoses for a living ; PAS hoses is what he cuts his teeth on, but he does do AC hoses, and that is for some very prestiguous cars. Say you are from RR and see what he can do. Rich is a pretty sound chap really.
