Do any of you clever folk know if 5 1/2 inch 4 stud PCD wheels were used on any cars? the centre bore seem big at 3 11/16 inch, all I can find is new trailer stuff which are a bit pricey!
Its only for a ratty old trailer so I don't need anything special just cheap!
Thanks in advance
The only 4x140 PCD in the list I have are Peugeot 504, 505 & 604 and I'm pretty sure they'll all be bigger than 13".
kenb
5.5 inch PCD is the old Ford 100e 13" wheel, dimensions of which were adopted for many a 60's 70's 80's trailers and caravans until the advent of Alko chassis. Loads about if you ask on the right FB groups for caravans Ford 100e etc.
The Ford route might make it a bit easier to find some, thanks for the input guys
80s Subaru wheels are most often 13" and the PCD is correct.
80s Subaru wheels are most often 13" and the PCD is correct. Thanks I have seen that, trouble is the middle needs to be 95mm ish and I think the Subaru are smaller?
I think Subaru wheels have quite a big centre bore since it looks close to the bolt holes even though the PCD is so big.... But I have never measured so I don't give any guarantee....
^^^I see what you mean, it might be another option but I think they will be hard to find in the UK
