totti
Hi! Looks like the welding come to an end Rear door and load bed finished! After painting the welded area's the loadbed gets some new,or used, wooden planks in the middle. Meanwhile i took some things of the engine apart for cleaning or overhaul... Removed the valve cover... Looks very good,no sludge anywhere.Got regulary oilchanges in the past...! Loaded the parts in my 203 Commerciale... At work we have a washing machine... Greet
65 'Ford Taunus 17m 66' Ford Taunus 17m Turnier 73' Ford Taunus 63' Ford Taunus Transit 1250 72'Ford Escort 2000cc 71'Ford Escort 1700 4 door 89'Ford Escort Express 87'Ford Fiesta Diesel 64'Ford Cortina 1500 deluxe 57'Volvo PV 444 Califonia 54'Peugeot 203 Commerciale 2004 Harley Davidson Fat Boy 78'Zündapp ZR 20 88'MZ ETZ 250
voodoo57
That's not 2 metres! come a little...Closer!
Club RR Member Number: 137
1952 Peugeot 203 Pick up...voodoo57
@voodoo57
Club Retro Rides Member 137
Take a break! tea, biscuits, and lots of dunking! well done, excellent work!
totti
Jun 10, 2020 20:17:27 GMT
Take a break! tea, biscuits, and lots of dunking! well done, excellent work! That's a good idea... Maybe we take some beers and "Bratwurst" on the open fire in the garden to celebrate that milestone,too! Greet
Last Edit: Jun 10, 2020 20:18:08 GMT by totti
Jun 11, 2020 10:53:07 GMT
Dunking bratwurst in to beer just doesn't have the same taste, though..
Jun 11, 2020 15:01:12 GMT
very nice progress!....looks great. cant wait to see the clean parts!
JP
totti
Jun 25, 2020 14:27:53 GMT
very nice progress!....looks great. cant wait to see the clean parts! JP Look! Gearbox clean,waterpump overhauled... All seams on the chassis got sealed and primered. The loadbed got some filler and is ready for paint now... The inside from the wings got 2 layers of primer.... Inner sill gets paint.... Fabricated the bracket for the spare wheel... Time flies.... Greet
Last Edit: Jun 25, 2020 14:29:04 GMT by totti
totti
Hi! still prep for paintjob.... and...yep there is filler at some places My mate can't help doing that.... Underside.... Loadbed underside..... The loadbed is already primered.... There is a problem with the first batch from the paint....it's not dull enough. Hope the secound one is better... Greet
Dr.AK
Club RR Member Number: 62
1952 Peugeot 203 Pick up...Dr.AK
@docak
Club Retro Rides Member 62
Amazing job. Love what you've done so far, quite impressive. Teach me to weld? I'll bring beer.
totti
Amazing job. Love what you've done so far, quite impressive. Teach me to weld? I'll bring beer. Aaah....Beer.... I drink the beer,you weld!But not on zinc plated cars like yours.....! The first paint went on ! Paint will go more dull ...and when you put Owatrol on the old paint you will not see the difference between old and new.... Greet
Jul 10, 2020 20:48:56 GMT
Totti u r my hero what a project again. I am just doing a 210 Duett it is no where near that bad but still needs some work and I want to keep the patina from the Swedish former owners but as u know for the German H we have to make it look smartish!!! The Cortina is ready for paint so it will need attention when the Duett is up and running again after 15 years in a barn. Cheers Gav
totti
Hi! The plans for a roll out THIS year are now abandoned....it's simply not viable So,next spring is more realistic..... Removed all things in the engine bay for painting.... After sanding it looks like there was a yellow phase in the past... Inside...the steering wheel is on it's last legs....cracks all over and no chance to get another good one.It's rare like hence teeth. Solution?I think we will have a try with those repair kits for steering wheels. The nice "Christopherus"Badge on the glove box..... Lovely!Pre '53 cars had the Speedo in the middle! Even the center cap is warped.... Thanks for looking! Greet
Last Edit: Aug 2, 2020 11:06:19 GMT by totti
Great job on the car! That steering wheel looks really bad. I have my doubts on the steering wheel repair kit on the long run. It looks like the rim is made out of a classic kind of polyester resin which is not strong and will keep schrinking so new splits will occur, The best way is to repair it with epoxy, then make a casting jig out of polyester with a gel coat and then fill the jig with epoxy. This will look original and will last. But it takes a fair bit of work and time but making a jig allows to restore relatively easy steering wheel for fellow owners as making the jig is a fair bit of work.
If you choose for the resto kit, i would advice you to give therim a few coats of epoxy as this will give strength to the original rim material. You can add some pigment to the epoxy to get the original color
A less time consuming option is to make a rim out of mahogony wood. I made one for a Traction Avant some time ago. Before the resto And after
Peter
totti
Great job on the car! That steering wheel looks really bad. I have my doubts on the steering wheel repair kit on the long run. It looks like the rim is made out of a classic kind of polyester resin which is not strong and will keep schrinking so new splits will occur, The best way is to repair it with epoxy, then make a casting jig out of polyester with a gel coat and then fill the jig with epoxy. This will look original and will last. But it takes a fair bit of work and time but making a jig allows to restore relatively easy steering wheel for fellow owners as making the jig is a fair bit of work. If you choose for the resto kit, i would advice you to give therim a few coats of epoxy as this will give strength to the original rim material. You can add some pigment to the epoxy to get the original color
Peter
Thanks for the advise.... There is a reproduction planed from a french club....but it will cost over 500 euro... So ,i think it will be the repair,first.Only to get it useable. Looking for a good one furthermore.... Greet
totti
Thanks! Removed the steering column and all the rest out of the bay. Sanded all the yellow paint down by hand... Ready for primer now... Puhh...it's too hot over here....36°c... Greet
totti
Hi! One step further.... Primered with Brantho Nitrofest.... And the paint.... Thanks for looking.... Greet
Peter
Thanks for the advise.... There is a reproduction planed from a french club....but it will cost over 500 euro... So ,i think it will be the repair,first.Only to get it useable. Looking for a good one furthermore.... Greet I was going to suggest you chat to petervdv about making you a new one as that seems to be his thing now, but I see he's already been! You could still ask him, but you've gone and told him what the competition is charging now! Looking forward to this getting some more love while it's up on stands.
Last Edit: Sept 1, 2020 4:05:01 GMT by varelse
totti
Guten Tag! Still prep work on the inside.... Meanwhile i cleaned/blast/painted some suspension parts at work.... Painted and ready! Cleaning the wheel bearings.....every part inspected! The rear lever arm shocks get some new oil... Greet
